Old 08-10-2006, 07:16 PM   #301
IIdiceII
Member#: 90438
IIdiceII is offline   Reply With Quote
Old 08-12-2006, 02:40 PM   #302
lobelsteve
Member#: 31992
2007 STI
UGM
Replaced 6MT filled with Redline 75w90NS with my custom cocktail.
4th gear synchro issues after only 2k miles on the redline and never any problems prior to that with 34k on factory oil.
Used custom cocktail because I have Auto-X tomorrow and didn't want to wait for RL shockproof and other oils.
I used Valvoline 75w90 0.3qts, Valvoline dino 80w90 x 1 qt, Valvoline synthetic 80w90 x2 qts, and Penzoil Synchromesh x 1 qt.
After 1 mile the synchros were better. I felt bad watching the expensive redline drain out as it was as clean as when it went in.
I may replace the oil in a month with the Uncle Scotty's cocktail, at least the gears are working better for now. I hope the 80w90 holds up and that I don't have to replace it, but with ramps and a good jack, it's a 15 minute job.
lobelsteve is offline   Reply With Quote
Old 08-19-2006, 01:05 AM   #303
gopsu
Member#: 96448
02 WRX VF34
anyone knows if you can get Scotty's cocktail from Wallmart? What's best site to order all?
Updated: amazon.com
gopsu is offline   Reply With Quote
Old 08-19-2006, 01:07 AM   #304
gopsu
Member#: 96448
02 WRX VF34
Here are links for them.
Red Line Synthetic Oil RED-58404: Gear Lube, Shockproof Lightweight Gear Oil, 30W, Limited Slip, Synthetic
http://www.amazon.com/gp/product/B00...375225?ie=UTF8
Pennzoil Synchromesh Manual Transmission Fluid quart
Castrol Hypoy C Gear Oil quart
http://www.amazon.com/gp/product/B00...8&s=automotive
Old 08-19-2006, 01:18 AM   #305
gopsu
Member#: 96448
02 WRX VF34
anyone knows if you will get one package containing all of them or 3 separate boxes from 3 different vendors?
Old 08-19-2006, 01:20 AM   #306
spelk3
Member#: 19835
2012 WRX sedan
sold '02 WRX wagon
spelk3 is offline   Reply With Quote
Old 08-19-2006, 01:21 AM   #307
gopsu
Member#: 96448
02 WRX VF34
spelk3, thanks for the link!!!
Scotty makes 5% commission for that?
Old 08-19-2006, 01:23 AM   #308
spelk3
Member#: 19835
2012 WRX sedan
sold '02 WRX wagon
Scotty's not involved...
Old 08-19-2006, 01:25 AM   #309
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
"Finally, a transmission cocktail all in one kit! This mixture was created and tested by an aircraft mechanic to be the best.
While it can't do magic, this cocktail can mitigate gear grinds and difficult shifting. Suncoast Autosport's own WRX was experiencing gear ginding in 1st while sitting still. There was no way to shift into 1st at anything faster than a dead stop. After putting in the cocktail, there are no gear grinds and the car can be shifted into 1st gear at up to 20 MPH.
This is just one of the success stories that this mixture has generated. There are dozens of other cars that have been running the cocktail for up to 3 years. It just works."
Old 08-19-2006, 07:15 PM   #310
Kavoom
Member#: 123443
Default Red Line, Syncromesh and Lucas Oil
Well, I ordered the Red Line items off Amazon for right at 26 including shipping. I wasn't going to order the other due to the three suppliers.
There is no HYPOYC in Kansas, but as someone else noted there is a product from Lucas Oil that is an 80W-90 (dino) which appears to match up very well with the Castrol.
(I tried to submit a Lucas Oil URL and I don't have enough submissions.)
So I tried NAPA and found they had the Pennzoil synchromesh ($6.00) and went to autozone for the 2 qts of the Lucas 80w-90 ($14.00) and they also had the synchromesh as an fyi. So, did it all for less than 50 bucks. Not bad.
So Scotty or someone could you take a quick look at the Lucas Oil product?? and see if any "contraindications" jump out... I tried to put the link in.
Now I just have to wait for the Red Line products and they said they would ship on the 22nd or 23rd. I hope I have them by next Mon or Tues.
And then when I take my 3K miles towing trip to Glacier, I'll let you all know when I get back how it went.
Kavoom is offline   Reply With Quote
Old 08-19-2006, 08:14 PM   #311
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The above is 100% true.
Old 08-20-2006, 09:07 AM   #312
Kavoom
Member#: 123443
Hi,
Here are the specs on the Dino oil part of the cocktail. I dislike substituting ingredients in a cocktail, but am left with little choice. Will the Lucas Oil product be a good substitute?
They are letting me post URL's now... I'm kind of scratching my head on reading the Hypoy specs but.
Lucas Oil 80/90 page
http://www.lucasoil.com/products/dis...tid=4&loc=show
specs
http://www.lucasoil.com/images/media...0_gear_oil.pdf
Hypoy C web page
http://www.castrol.com/castrol/produ...tentId=6004016
Specs
http://www.castrol.com/liveassets/bp...pds_HypoyC.pdf
Old 08-20-2006, 05:12 PM   #313
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Kavoom
Hi,
specs
Hypoy C web page
Specs
..seems like a good match to me....try it
Old 08-21-2006, 12:15 AM   #314
lawrence131
Member#: 122154
Hmmm, I just put in 3.5 qts of SuperTech 75w90 Full synthetic API GL-5 an hour ago. Is this bad? Do I need to drain it and put in something else real soon or is it ok to drive for a week or so until I get more time?
lawrence131 is offline   Reply With Quote
Old 08-22-2006, 11:24 PM   #315
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
Originally Posted by Uncle Scotty
...juust do it....and remember.....do NOT dump 4 qt in the tranny!!!!!!!!
That WILL overfill it---bad juju.
Add ~3.3 - 3.4...drive the car---check....repeat a couple times....make SURE it isn't too much before ya add more.
Add the lube SLOWLY into the dipstick tube or you WILL get more UNDER the car than IN the tranny
...and the rear diff can use GL-5 whatever.....I'd use a syn like M1
When you say dipstick... do you literally mean a dipstick in yoru tranny? or the dipstick where your motor oil is?
jc8587 is offline   Reply With Quote
Old 08-22-2006, 11:28 PM   #316
EROC263
Member#: 96887
look under where the turbo is and you should see a small dipstick hidden down there on the side of the trans. at least thats where it is on my 04 sti idk about others
EROC263 is offline   Reply With Quote
Old 08-22-2006, 11:31 PM   #317
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
thanks! also, do you use this cocktail in your rear diff as well... since your tranny and front diff use the same resevior, im geussing the rear diff is safe with the cocktail as well?
Old 08-22-2006, 11:31 PM   #318
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
it's the same on all of them.
under the intercooler ish.
ImprezaRSX is offline   Reply With Quote
Old 08-22-2006, 11:33 PM   #319
Uncle Scotty
Member#: 16200
OK buy Nates beans
donotputanygearlubeintheoildipstick!!!!!!!!!!!!!!! !!!!!!!!!!!!1
Old 08-22-2006, 11:34 PM   #320
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
lol, ok ok
Old 08-22-2006, 11:34 PM   #321
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
no point.
no synchros.
just use a good quality oil. I have a cusco rear LSD and run royal purple synthetic gear oil
Old 08-23-2006, 07:06 AM   #322
Kavoom
Member#: 123443
Default Rear Diff
Actually I believe the Red Line 75W/90 "NS" goes in the rear differential. Everything else goes in the transmission. But don't overfill.
Or at least that's what I'm going to do when it gets here.
Old 08-23-2006, 08:34 AM   #323
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
i thought the extra hypoi C went in the rear diff.
Old 08-23-2006, 09:35 AM   #324
Uncle Scotty
Member#: 16200
OK buy Nates beans
no....but it CAN....won't hurt a thing
Old 08-23-2006, 09:53 AM   #325
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
Is anyone putting this together as a package anymore so I don't have to chase down individual things? Someone was doing this before. I am long overdue for this change out.
digitalmethods is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
