Old 02-18-2006, 01:06 PM   #26
fourdegrees
Member#: 49662
2005 FEALing fine
I'm also lucky enough to have a redline dealer in town.
fourdegrees is offline   Reply With Quote
Old 02-18-2006, 07:21 PM   #27
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by desert pirate
I would definately trust the UNCLE i've met him and he REALLY know these subys!
HIS NM friend
Old 02-18-2006, 09:38 PM   #28
StillBoostin
Member#: 46177
2002 WRB WRX
99 RSTi Coupe
I like to use 2 or 3 qts of shookproof and 1-2 qts of Motul 75-90. we have found this to work very well.While you under your car don't forget the rear diff. You only need one qt of 75-90 for the rear diff. Trust me just replace the fluid.It will save you abuch of money later down the road. Good Luck.
Later
James
StillBoostin is offline   Reply With Quote
Old 02-19-2006, 08:16 PM   #29
Hagwag02
Member#: 63445
2002 WRX Wagon
Uncle Scotty... Have you already replaced the fluids in your transmission with your cocktail, and your differentials with M1? And if so, have you needed to adjust the formulation for your new TR's tranny
Just curious.
I presume the concoction in post #1 is "Uncle Approved" for a 2002???
Thanks.
Hagwag02 is offline   Reply With Quote
Old 02-19-2006, 08:21 PM   #30
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Hagwag02
Uncle Scotty... Have you already replaced the fluids in your transmission with your cocktail, and your differentials with M1? And if so, have you needed to adjust the formulation for your new TR's trannyNo...not broken in yet
Just curious.
I presume the concoction in post #1 is "Uncle Approved" for a 2002???Indeed
Thanks.
Old 02-19-2006, 08:25 PM   #31
Hagwag02
Member#: 63445
2002 WRX Wagon
Originally Posted by Uncle Scotty
Super. Many thanks.
Old 02-19-2006, 11:38 PM   #32
totalburnout
Member#: 72861
When do you think the cocktail is best to start using?
I have an '02 WRX with 28k on it and was thinking about doing the cocktail for my 30k maintenance a bit premature.
totalburnout is offline   Reply With Quote
Old 02-20-2006, 01:11 AM   #33
WRX-Traterrestrial
Member#: 80358
2005 18G EJ25WRX 6sp
Tuned by Bobby @ PRE
Can somebody PLEASE tell me where to find the Castrol Hypoy C gear oil? I've been to Schucks, Auto Zone, Baxster Auto, GI Joes, and some local auto parts place...no luck. Can I just use redline gear oil? I can find Valvoline gear oil everywhere, and even found Penzoil gear oil at another place, but NO Castrol. Please help me out...plan on changing it out tomorrow. Thanks guys!
WRX-Traterrestrial is offline   Reply With Quote
Old 02-20-2006, 01:20 AM   #34
fourdegrees
Member#: 49662
2005 FEALing fine
Pep boys.
Old 02-20-2006, 01:35 AM   #35
WRX-Traterrestrial
Member#: 80358
Originally Posted by fourdegrees
Pep boys.
Unfortunately there are no Pepboys near me. Closest one is 150 miles north. Any other places? I think I heard WalMart of all places may carry it, so I'll try them tomorrow.
Old 02-20-2006, 10:44 AM   #36
Uncle Scotty
Member#: 16200
OK buy Nates beans
NAPA might order it fer ya....or use the Penzoil one
Old 02-20-2006, 12:39 PM   #37
Division By Zero
Member#: 7555
Guys, (and not to take anything away from Uncle Scotty ) this mix of different oils may work fantastic and I'm sure it does. But why, why, why have to go through so much trouble tracking so many items down when you can get equivelant (and dare I say better) results from mixing part Redline LW Shockproof, part Redline MT-90. Just mix50/50 and you will be able to shift into first above 20+ mph with a blip of the throttle, completely eliminate gear shift grinding, etc. Others have used this (or close to it) as well with exact results. You can buy both of the prouducts at the same store and be done with it!
Division By Zero is offline   Reply With Quote
Old 02-20-2006, 01:19 PM   #38
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
I have straight MT-90 in my 6 speed and it feels awesome. I can get into first just like I was able to on my stock 5 speed. Just push lightly and I can get into first at 10-15mph, haven't tried more since I've only been driving easy on the street.
dan avoN7 is offline   Reply With Quote
Old 02-20-2006, 01:33 PM   #39
Division By Zero
Member#: 7555
Yeah, I think that the majority of the benefit is the MT-90 and not the LW Shockproof FWIW. I only tried going with the 50/50 mix to lessen any potential negative effects (and I don't know that there is any) on using non-stock 75-90w recommended oil. However, we all know that the recommended oil doesn't work too well for most of us
So anyway, I found that the 50/50 was the threshold to wear the grinding would be eliminated on my particular transmission, and I might add that it was more prone to grinding than most everybody elses that I've heard of.
Old 02-20-2006, 01:44 PM   #40
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
What? You guys not getting enough power out of 2nd gear at 20mph?
Asinine is offline   Reply With Quote
Old 02-20-2006, 01:50 PM   #41
Sir_Xenon
Member#: 9666
02 WRX
Ver. 7 STi swap'd bugeye
I'm running 100% Redline Shockproof Heavy and no grinding, ever, but still can 't get'r into 1st at low speeds. Maybe go with a mix later.
Sir_Xenon is offline   Reply With Quote
Old 02-20-2006, 06:19 PM   #42
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
LOL well on back roads with tight turns or tracks with one slow turn, 1st is very usefull. Especially when you have a big turbo that doesn't hit full boost until 4500-4700rpm
Old 02-21-2006, 01:39 AM   #43
totalburnout
Member#: 72861
Anyone have an answer?
Old 02-21-2006, 02:06 AM   #44
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....just do it
Old 02-21-2006, 08:21 AM   #45
Sir_Xenon
Member#: 9666
02 WRX
Uncle, how does this mix compare to the Neo Synthetic gear oil, which the vendor claims does the same thing? I know it costs more but do you have any experience with it? Thanks!
Old 02-21-2006, 10:28 AM   #46
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....don't know nuthin about da neo.......most syn lube in da tranny is bad juju....da cocktail works.
Profit???
Old 02-21-2006, 10:32 AM   #47
Sir_Xenon
Member#: 9666
02 WRX
heheh, no profit, in fact it'll cost me as I'm looking to change up soon myself. I'll go with your cocktail then, guru.
Old 02-21-2006, 11:06 AM   #48
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
While I'm a fan of the cocktail, I use 100% Redline lightweight shockproof and get the same results albeit for much more money. While I'm no tribologist, the KEY ingredient seems to be Redline lightweight shockproof. So to modify/help, if you can't find XXX ingredient in the Uncle Scott's Cocktail due to your location and you don't feel like mail ordering fluids, substitute Redline lightweight shockproof for the XXX ingredient.
***This formula NOT Uncle Scotty approved***
Try the lightweight and all will be fine.
Old 02-21-2006, 11:10 AM   #49
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
And as to why Redline lightweight shockproof? Simon at PPG in Aussie land suggested it to Andrew at www.gearboxtech.com and he tried it out. After seeing the results, he convince me to try it. I did a full swap just before my cruise and was able to normally downshift into first gear at 25MPH, which prior to the fluid change, was a pipe dream for me. How Uncle Scotty chose it, I don't know, but I suspect that it's the key in the Cocktail. Not even Simon at PPG knows why it works so well with Subaru trannys, but it sure does.
Old 02-21-2006, 11:15 AM   #50
Sir_Xenon
Member#: 9666
02 WRX
I remember reading that people had varying results with just one particular fluid. I think the temperature, age of the tranny, and other factors had to do with it. This was a few years ago.
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
