Old 02-22-2006, 11:23 AM   #51
totalburnout
Member#: 72861
Do you guys mix the cocktail outside of the car or just pour one bottle of it in at a time?
totalburnout is offline   Reply With Quote
Old 02-22-2006, 07:49 PM   #52
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 02-27-2006, 01:34 PM   #53
athakur999
Member#: 88307
2005 Saab 9-2x Aero
Arctic Silver
Originally Posted by Uncle Scotty
...juust do it....and remember.....do NOT dump 4 qt in the tranny!!!!!!!!
That WILL overfill it---bad juju.
Add ~3.3 - 3.4...drive the car---check....repeat a couple times....make SURE it isn't too much before ya add more.
Add the lube SLOWLY into the dipstick tube or you WILL get more UNDER the car than IN the tranny
...and the rear diff can use GL-5 whatever.....I'd use a syn like M1
Should we pour in the full bottles of shockproof and synchromesh and use the hypoC for "topping off"? Or should we pour them in in equal proportions?
Does overfilling hurt anything or does it just make a mess of your floor?
athakur999 is offline   Reply With Quote
Old 02-27-2006, 06:12 PM   #54
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Well, if you put 1 quart of each in you are gonna be pretty close to full. Overfilling is definetely not recommended, it might not do damage but will not promote proper operation. In order for your bearings and synchros to perform correctly, stick to the full line on the dipstick.
I did exactly what you said, and it worked very well. It ended up being about 1.2 quarts of hypoyC and a quart of both the others. So it was really only a difference of .2 quarts which is almost equal proportioned
Gfunk720 is offline   Reply With Quote
Old 02-27-2006, 08:01 PM   #55
fourdegrees
Member#: 49662
2005 FEALing fine
After a few hundred miles, this stuff feels pretty good. Felt like it took a few days to "mix," but now I definately feel confident in my choice to go this way.
fourdegrees is offline   Reply With Quote
Old 02-27-2006, 08:43 PM   #56
Hagwag02
Member#: 63445
2002 WRX Wagon
I had to adjust the ingredients as my local selections are limited. No Castrol or Pennzoil 80/90. 75/90 synth choices limited as well.
So... Will be trying Redline Shockproof Light, Pennzoil Synchromesh, and Lucas 80/90 in the transmission. Lucas 75/90 synth in the rear.
Lucas is a popular brand in this part of the country.
I'm anxious to feel the results.
Hagwag02 is offline   Reply With Quote
Old 02-27-2006, 09:46 PM   #57
MikeC5
Member#: 104702
95 Legacy
Green
Anyone have any experience with this:
Shell MTX Fluid
Product Code: 59419
Shell MTX Fluid is a fully formulated synchromesh transmission fluid (STF) for use in manual transaxle/transmissions. It offers excellent synchronizer performance, oxidation stability, yellow metal compatibility, and low temperature performance. This product will satisfactorily lubricate manual transaxles/manual transmission from 40F to +300F.
It sounds like what we're looking for.
MikeC5 is offline   Reply With Quote
Old 02-28-2006, 01:49 AM   #58
Uncle Scotty
Member#: 16200
OK buy Nates beans
...if the Lucas is syn....it may be NFG to use
Old 02-28-2006, 06:17 PM   #59
Hagwag02
Member#: 63445
2002 WRX Wagon
No. I made sure the 80/90 is Dino, and it lists hypoid gears for one of its applications. 75/90 synth will be OK in rear diff, right?
Thank you for making sure I don't f-up!!
Old 02-28-2006, 06:33 PM   #60
Hagwag02
Member#: 63445
2002 WRX Wagon
Shell MTX Fluid
Product Code: 59419
Nearly word-for-word as the Pennzoil. Except Pennzoil specifically lists GM and Chrysler applications. Interesting, huh??
Old 02-28-2006, 08:00 PM   #61
Uncle Scotty
Member#: 16200
OK buy Nates beans
perfekt
Old 03-01-2006, 01:26 AM   #62
70sixspeed
Member#: 76986
2006 STI
Black with gold wheels
Ok Uncle Scotty, what if I found 1 bottle of the Redline, 1 of the Pennzoil, and after searching every store even close to my house, only 1 of the Castrol? Is there something I can top it off with? Or should I not use the Castrol and try something else for the 2 bottles instead?? Please help as my cars been draining all day and I want to fill it tomorrow afternoon!! Thanks...
70sixspeed is offline   Reply With Quote
Old 03-01-2006, 02:36 AM   #63
ultrasonic
Member#: 18006
I poured Scotty's cocktail into my 115k mile MY91 Legacy turbo about 500 miles ago. Not a dramatic improvement. I was hoping that my sketchy 3rd. gear synchro would be smoothed out, but it still requires patience and attention. I used:
1qt. Redline Lightweight Shockproof
1qt. Pennzoil Synchromesh
~ 1.7qt. Castrol 80W90 Hypoid
I'll post again if I have further information to add.
ultrasonic is offline   Reply With Quote
Old 03-01-2006, 04:10 AM   #64
Uncle Scotty
Member#: 16200
OK buy Nates beans
....add the rest of either other ingedient, whichever is cheaper or more available.
exact ratios aren't really important
Old 03-01-2006, 04:11 AM   #65
Uncle Scotty
Member#: 16200
OK buy Nates beans
I hope it gets better for ya....but if it is abused or worn out, nothing but a re-build will really fix it.
Old 03-01-2006, 11:16 PM   #66
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I've been trying to track down all of these indredients with no luck. Is there an online source from where they can all be had?
Thanks!
specialev is offline   Reply With Quote
Old 03-02-2006, 01:28 AM   #67
Uncle Scotty
Member#: 16200
OK buy Nates beans
Thanks!
google is yer friend
Old 03-02-2006, 01:32 AM   #68
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Google is my best friend; I've been googling the bejesus outta it. I guess I'll have to bite the bullet and order from multiple vendors.
Thanks again Scotty!
Old 03-02-2006, 01:44 AM   #69
totalburnout
Member#: 72861
CVR Motorsports, a great vendor on this site has redline products. They're out of stock until next week but if you can wait, I highly suggest buying from CVR Motorsports and picking the rest up locally or through google/ebay.
I've only bought my carbon fiber hood from Chris @ CVR, but I'm already putting the finishing touches on buying a big package from him that includes the redline fluids I need for this cocktail.
He's the cheapest price and best service that I've ever encountered online.
Hope that helped.
Old 03-02-2006, 07:01 PM   #70
Hagwag02
Member#: 63445
2002 WRX Wagon
Thanks!
They might not have all of the items, but Summit Racing Equipment and Pegasus Auto Racing Supplies deal in Redline and other brands. Summit even included a hat and some neat-o stickers! That's at least 10 hp! Whoo hoo!!!
Old 03-02-2006, 07:08 PM   #71
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Hey Scotty, i just tried your out the cocktail in my car on monday..
Another satisfied test subject! My tranny issues are gone!
You rock
subbyspeed is offline   Reply With Quote
Old 03-02-2006, 10:34 PM   #72
Uncle Scotty
Member#: 16200
OK buy Nates beans
You rock
Old 03-03-2006, 08:19 PM   #73
Hagwag02
Member#: 63445
2002 WRX Wagon
My little darling is up on stands draining as I type this.
The old fluid (25,000 miles), while not black, smelled absolutely putrid, and I swear there was 1/4 inch of ferrous sludge on the magnetic drain plug. I didn't change it myself the first time, but is this amount "normal".
Looking forward to finishing the transfusion in the morning.
Old 03-03-2006, 11:44 PM   #74
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Gear lube smells horrible.. Thats probably what your smelling. And yeah, its normal to have some shavings and what not on the drain plug magnet. As long as they aren't big chunks!
Old 03-04-2006, 03:49 PM   #75
STI05
Member#: 76649
08 Z06
Victory Yellow
Originally Posted by bluescoobywagon
Is it recommended to put a blend into the 6mt as well?
Mike Robinson
Has this question been answered? Searching for a 1/2 hour now for definite confirmation. Waiting to go to Autozone.
I plan on using Torco SGO w/ the LSD additive for the rear. 6MT STi Tranny is still the question.
STI05 is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
