Old 03-04-2006, 09:02 PM   #76
Hagwag02
Member#: 63445
2002 WRX Wagon
Originally Posted by subbyspeed
Gear lube smells horrible.. Thats probably what your smelling. And yeah, its normal to have some shavings and what not on the drain plug magnet. As long as they aren't big chunks!
I've changed it in large trucks and never experienced this particular aroma. Nasty.
On a side note, that Redline Lightweight Shockproof is an odd duck what with the blue color and weird consistency.
Hagwag02 is offline   Reply With Quote
Old 03-10-2006, 06:25 PM   #77
norcaliwrx
Member#: 46374
02 WRX
just curious, what are you guys putting into the read diff? syn or dino? is there a recommandation from uncle scotty?
norcaliwrx is offline   Reply With Quote
Old 03-10-2006, 07:10 PM   #78
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....any good 75w90 syn GL-5 like the M1 is good for the rear end
Old 03-11-2006, 11:18 AM   #79
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
erase me. how come i can't delete posts anymore.grrr.
scoobystas is offline   Reply With Quote
Old 03-14-2006, 07:04 PM   #80
mdurbahn
Member#: 88680
I have a question....So I used the "cocktail" on my 03 WRX with 53k. I was having trouble with grinding going into 5th gear before I used it. Now it is perfect. My question is how long does this work? Should I get rid of the car because it will come back soon? Or is this a fix that will work for a while?
Matt
mdurbahn is offline   Reply With Quote
Old 03-15-2006, 01:56 AM   #81
Uncle Scotty
Member#: 16200
OK buy Nates beans
Matt
...well....ya should change the tranny lube after 15k miles or so to maintain the sweet shifting action
....other than that.....just drive it
Old 03-15-2006, 09:19 PM   #82
njskatchmo
Member#: 94618
2002 Bugeye
is it just me or does engine braking make a horrible noise with the cocktail?
njskatchmo is offline   Reply With Quote
Old 03-15-2006, 09:26 PM   #83
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
suby trannys always make horrible noises under deceleration
Old 03-15-2006, 09:34 PM   #84
njskatchmo
Member#: 94618
2002 Bugeye
no i mean it soudns worse now, sounds sandy.
Old 03-15-2006, 09:56 PM   #85
Sir_Xenon
Member#: 9666
02 WRX
Ver. 7 STi swap'd bugeye
check your tire pressures - set to what it's supposed to be, front and rear, then try again. This worked for me and is agreement with theories around.
Sir_Xenon is offline   Reply With Quote
Old 03-15-2006, 10:01 PM   #86
Uncle Scotty
Member#: 16200
OK buy Nates beans
...set the fronts to 3psi MORE than the rears and see wassupwidat....and the 'cocktail' does NOT 'fix' broken tranny's
Old 03-16-2006, 09:54 PM   #87
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
and this will make the tranny sound better? will this also cause more understeer?
Old 03-16-2006, 10:19 PM   #88
Sir_Xenon
Member#: 9666
02 WRX
Nothing to do with understeer; the relative difference between the front and rear axle speeds, as determined by your relative tire pressures, takes the slack out of the center diff gear(forget which one) when you're decelerating. This is the likely cause, not the only one. Do a search and you'll get a better explanation
Understeer can be caused by a multitude of factors, one major one being our open front diff and 50/50 torque distribution between front and rear. I doubt your noise has anything to do with understeer.
Old 03-17-2006, 01:48 AM   #89
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
gotcha, thats why manual says 32psi fronts and 29psi rears. i currently have all four corners around 33psi. i'll try pumping the fronts up a few psi over the rears and report on any sound differences.
Old 03-17-2006, 01:57 AM   #90
Uncle Scotty
Member#: 16200
OK buy Nates beans
which is just absurd in any case
that is for fat dumb armchair americans that can't drive their way out of a wet paper bag and MAD-MAD understeer
I have never run less than 37f/35r on either of my WRX's and with the MX's, they liked ~41f/39r
Old 03-17-2006, 09:12 AM   #91
Sir_Xenon
Member#: 9666
02 WRX
Add more negative camber in the front, anti-lift kit, or "flick" it and you wont get as much understeer..
wow.. this got off topic real good...
Old 03-17-2006, 09:18 PM   #92
nix-hex
Member#: 67809
1999 2.5 RS coupe
I just swapped out the M1 out of the tranny cus I heard of the problems it causes. Good thing it was only in there for like 130 miles or so. I put conventional Valvoline in cus thats the stock fluid. I wasnt sure on the synthetic cus I couldn't find anything on the bottle about friction modifiers which I hear that screw up the synchros. I needed to change it and my school, UTI, only had 80W-90 on hand, is that alright that i put that in instead of 75w-90. Please say it is, i dont want to waste more money with fluid. It has 87k miles on it and would it be better with Uncle Scotty's cocktail or just let the Valvoline ride? I plan on swapping out the engine and tranny for STI parts, when I have the money and/or find the connections for parts. Let me know if I'm good to go.
Thanks
nix-hex is offline   Reply With Quote
Old 03-17-2006, 11:34 PM   #93
Uncle Scotty
Member#: 16200
OK buy Nates beans
Thanks
...no problemo
Old 03-24-2006, 12:27 AM   #94
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Another satisfied user here, Uncle Scotty. Thanks again for sharing your knowledge.
specialev is offline   Reply With Quote
Old 03-24-2006, 02:12 PM   #95
ptirmal
Member#: 82243
07' Acura TL-S
Since it's hard to get 4 qts in what should go in first, the shockproof and syncromesh? Also saying you fill it up a little over whats the bad?
ptirmal is offline   Reply With Quote
Old 03-24-2006, 04:19 PM   #96
Demian_w
Member#: 45792
2002 WRX Wagon
Another satisfied customer for the Uncle Scotty cocktail!
I changed the fluid about 45 days ago and it is definitely good for my 2002 stage 4 wagon.
I am currently, March 24th 2006, at 78,000 miles. During 34,000 I took it to Grease Monkey (what a fool I was - I was in a hurry is my lame-o excuse) for the first transmission change. Bad mistake. My tranny acted up immediately. I was so scared my tranny was going bad because of the crap fluid Grease Monkey used that I took my car to a Subaru dealership within a week, getting another transmission fluid change. At the dealership I got the oem-stock fluid. It was much better.
Using Uncle Scotty's formula was a chance to make up for my double fluid change 44,000 miles ago and get some of my money back. I am very pleased with the results and this statement comes from a guy that has had three fluid changes in 16 months. I went here for my fluid online www.midwayautosupply.com (great prices) and got the Redline in my hometown.
Demian_w is offline   Reply With Quote
Old 03-24-2006, 04:43 PM   #97
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
I've been putting this off for a while but I really got to do it. Sounds like everyone really likes this formula.
digitalmethods is offline   Reply With Quote
Old 03-25-2006, 12:05 AM   #98
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 03-25-2006, 01:05 AM   #99
Sir_Xenon
Member#: 9666
02 WRX
All this over a cocktail... sheeech...
Old 03-29-2006, 10:29 PM   #100
totalburnout
Member#: 72861
Whats the best bet if we can't find the redline lightweight shockproof?
Also is the Castrol SYNTEC Full Synthetic Gear Oil, 75W90 recommended for the rear diff. by anyone?
totalburnout is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
