Old 04-02-2008, 05:08 PM   #1376
DS1
Vendor
Member#: 111780
REVNU- Hypoy C does not meet any of the lubricant requirements for the Subaru 5mt.
007WRX- If you have a grind, you have a bad syncro
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 04-02-2008, 05:30 PM   #1377
REVNU
Member#: 82147
2005 WRX Sedan
-Dylan @ DS1
Ok. I guess I'll change over to some Valvoline this weekend. Luckily it isn't very hard to change.
~ REVNU
REVNU is offline   Reply With Quote
Old 04-02-2008, 06:25 PM   #1378
prometheum
Member#: 92003
04 bicycle!
Originally Posted by REVNU View Post
DS1 or anyone else,
What are your thoughts on the Castrol Hypoy C 80w-90 gear oil for our tranny/diff?
Any reason why I should/shouldn't be using it?
I just changed out mine the other day, so far it feels great.
~ REVNU
hypoy c is a hypoid gear oil which is very harsh on yellow metals (like the brass your synchro is made of)
prometheum is offline   Reply With Quote
Old 04-03-2008, 01:58 AM   #1379
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
-Dylan @ DS1
Could you name a couple of good fluids for people that constantly drag?
kike_ej20 is offline   Reply With Quote
Old 04-03-2008, 02:10 AM   #1380
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
i talked to Andrew from andrewtech auto and i told him i was having a problem getting all my gears to go place im using lucas 80w90 and he told me to get rid of it ASAP cause it to slippery for my tranny and im running a 98 sti version 4 he told me to run straight redline shock proof oil.
now DS1...your saying you and andrewtech do the most tranny rebuilds in the country but you say not to use redline shock proof but andrew tech tell me too that leaves me at a very confused state cause i just ordered 4 quarts of it.
i plan on using it no matter what cause my tranny goes into gear really hard but doesnt grind so i know i dont have bad syncros just the gear oil im using is to slippery.
additional info would be great thanks
Brandon
03WRX-WRB is offline   Reply With Quote
Old 04-03-2008, 02:50 AM   #1381
XanTium
Member#: 83891
2006 RX8 2001 rs25
Damn can we just get one answer lol. "What tranny oil to use" apparently is on par with the meaning of life. 56 pages of contradictory crap.
XanTium is offline   Reply With Quote
Old 04-03-2008, 09:13 AM   #1382
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
^ yup.
Old 04-03-2008, 09:22 AM   #1383
BryanH
Member#: 993
On my last Suby I tried the cocktail for a little bit and it did seem to shift well.
I then went to straight Red line and it did just as nice....so I left it in. I will be putting it in my 07.
BryanH is offline   Reply With Quote
Old 04-03-2008, 09:30 AM   #1384
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Have you read the Subaru owners manual? Factory recommends Subaru Extra-S, which is what you should put in there. Some other brands work as well such as the Valvoline and Motul products. The cocktail is merely a bandaid to try and cover up mechanical problems that need to be fixed.
Superorb is offline   Reply With Quote
Old 04-03-2008, 09:37 AM   #1385
BryanH
Member#: 993
Superorb....not really.
For those of us that had 2002-2003 MY cars from new they didn't even have EXTRA-S fluid available from the dealer when I did my first trans fluid change...so how could they have recommended it? What they recommended was a GL5 fluid and even Mobil 1 fit the bill.
I am assuming this is still the same for my 07.
Old 04-03-2008, 11:21 AM   #1386
Ben
Member#: 423
2002 WRX wagon
Hi DS1, I have been read though this post and now here is my question before I go to do my tranny fluid change.
I have a 02 WRX wagon 5mt.
I living in Canada some how the winter temperture will become -25C (colder with windchill) and now, I would like to know what kind (brand) of tranny fluid is best for this kind of weather? Also what is the best for the rear diff?
Thanks for your info reply
Ben
Ben is offline   Reply With Quote
Old 04-03-2008, 12:16 PM   #1387
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
EVERYBODY:
DIFFERENT DRIVERS, AND EVEN DIFFERENT MECHANICS, ARE GOING TO HAVE DIFFERENT OPIONS ON THIS SUBJECT.
Just because Andrew and Dylan have differing opinions doesn't mean one is right, and the other is wrong. It's simply a matter or preference.
Try to stick with one oil, not a mix. Going with something that falls under factory recommendation is a plus. And you will have to try a few different oils to see what you, as an imperfect human being with your own opinion, prefer in your particular car. The 5mts are finicky, and nothing is as fickle as the human mind... so different car/driver combinations are going to like different oils.
My view on this is that Andrew prefers shockproof based on his own experience. While it might be just fine, keep in mind that the minute a dealer sees something milky and/or colorful pour out of your tranny, they will likely immediately deny any transmission warranty claim you have. Dylan is probably trying to stick with fluids that fall under the manufacturer's specs as well as sharing his own experience.
jhargis is offline   Reply With Quote
Old 04-03-2008, 02:01 PM   #1388
DS1
Vendor
Member#: 111780
Jhargis- I agree with you on the experience part, the experience I've had with the shock proof gelling up is the reason I don't run it.
The fluids you can run and that have been proven to work are:
75w90w Valvoline, Amsoil, Motul Gear 300 , Subaru Extra-S
Ben- Use the Valvoline, it stays almost 100% consistent in the cold weather
kike_ej20- For constant drag use I would run the Motul Gear 300
Hope this helps
-Dylan @ Ds1
Old 04-03-2008, 02:09 PM   #1389
Bluefoton
Member#: 141373
2008 2.5i-hatch -
-Dylan @ Ds1
For Valvoline/Amsoil, you mean synthetic or dino?
Ben: as per one of the 78446 posts, I used Redline 75w90NS. Tested at -25C morning start, worked well. Oh, and windchill doesn't affect the oil.. it's merely a measure of heat loss of a human body, not temperature itself
One grain of salt with the Redline I'm using. Shifting DID get better (3000 miles on it so far), however
a) I can't get downshift into first for speeds >5mph
b) upon every morning car start, there is a very delicate whine from the transmission for the first few minutes. Easily pinpointed as it goes away when I depress the clutch pedal.
Not sure if it's indicating anything negative. If so, I will do what Dylan said.
Old 04-03-2008, 02:44 PM   #1390
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Forgot about that, thanks for reminding me.
I think the important thing is to not mix fluids and stick with a GL-5 rated quality oil. With that said, I'm running some cheapo Coastal GL-5 75w90 and the stuff feels much better than the cocktail that was in for 10k miles. The cocktail did feel good in the beginning, but it degraded rather quickly.
Old 04-03-2008, 04:01 PM   #1391
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
thanks for the input i mean i live in south carolina where its warm year round pretty much so i dont see it being as much of a problem with the shock proof gelling up ill post up my progress with it once its in tomorrow
Old 04-03-2008, 04:59 PM   #1392
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
BTW, my last post sounded a little odd... I don't want to insinuate that either mechanic has better experience than the other. Edited.
Old 04-03-2008, 06:56 PM   #1393
DS1
Vendor
Member#: 111780
^^ no offense taken
I understood what you were saying
Old 04-03-2008, 08:20 PM   #1394
mugenXP
Member#: 155272
2006 WRX
Panda AE86
it's no surprise that uncle scotty is not in here backing up his stuff. i remember months ago when everyone was sucking his manhood for creating something that seemed to be a god-like fluid mix. i talked crap about it and everyone was flaming me, now i am teh winnar
mugenXP is offline   Reply With Quote
Old 04-03-2008, 10:37 PM   #1395
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Lol, its amazing how this thread has swayed. Check out my posts in this thread, from where I started out ignorant of how the stuff worked and trusting a senior member.. to where I decided to do some research and dump the stuff out of my transmission. My first post was on page 37. Wow
2slofouru is offline   Reply With Quote
Old 04-03-2008, 11:50 PM   #1396
Soul Shinobi
Member#: 130759
2002 Forester S
... If you have a grind, you have a bad syncro
-Dylan @ DS1
My friend's 2004 WRX was getting 3rd to 4th grinds above ~4000 RPM with only 11,000 miles on it. He doesn't abuse the car (I know 4000 RPM in 3rd is fast, but he shifts by the book to get there). He had Subaru replace synchro rings (I believe), under warranty, although Subaru of Milford sure wasn't happy about it!
If I recall correctly I think he had a grind after that (I'm fairly sure this happened, but part of me is skeptical of my memory), at which point I recommended Uncle Scotty's Cocktail, so both he and I put it in our cars (I drive a 1992 Subaru Legacy L AWD 5MT).
Of course he said it felt smoother, as most people do, and the cocktail only made my aging transmission feel just a tiny bit better (no more grinds with 260,000+ miles!). I have about 4,000 miles on the Cocktail, it shifts like **** but it doesn't grind anymore (it used to really easily).
After what you've said DS1, I intend to put Valvoline in both our 'boxes for 1,000 miles to clean it out, then I'm buying a 5 gallon tub of Extra-S and putting that in every Subaru I can get my hands on. So, my questions to you, DS1, are is this plan a good idea, and why would my friend's WRX have issues like that with so few miles and with mostly delicate driving?
Soul Shinobi is offline   Reply With Quote
Old 04-04-2008, 12:48 AM   #1397
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
im still here cockbreath
ive just deceided that there are so many idiots and asswholes on this board that just couldn't find their asses with both hands that i have given up and let the idiots follow the morons and the lemmings off the cliff and drown.
this thread is just another example of one asswhole coming in here and posting bull**** about this claiming all sorts of neboulous garbage with no real proof of anything
AND just because some monkey rebuilds transmissions all day does not mean that they actually know anything about what they are made of and why they really fail....which is 99% bad driving and drivers
FOR ONCE AND ALL
PISS OFF
Old 04-04-2008, 02:17 AM   #1398
mugenXP
Member#: 155272
2006 WRX
Panda AE86
FOR ONCE AND ALL
PISS OFF
lmao
i don't like you, but that one was funny.
Old 04-04-2008, 05:55 AM   #1399
kike_ej20
Member#: 145440
EJ20G 2123cc!!
FOR ONCE AND ALL
PISS OFF
Old 04-04-2008, 06:17 AM   #1400
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Uncle Scotty for President!
Spenk is offline   Reply With Quote
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
