Old 04-26-2008, 04:31 PM   #1476
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Originally Posted by DS1 Motorsports View Post
Bluescoobywagon & Bort- The 1st gear down shift issue is common in 02'-03' no matter what fluid you run the 4th gear issue is actually caused by a broken 3rd gear synchronizer. By running the cocktail you are just furthering the damge it causes
As for the 5th gear issue, they are known to crack the hub and cause issues.
-Dylan @ DS1
That may be the case. Maybe all that **** inside is broken or worn, but at 97K miles it shifts just fine on Valvoline non synthetic The only time I had any really bad symptoms was when I switched to the Valvoline synthetic for a short time over 50K miles ago. Yes I ran the cocktail for a while after that and maybe it did accelerate wear, but that's not why I chimed in. I just wanted to point out that in my case (and others) synthetic gear oil greatly exacerbated shifting flaws.
Bort is offline   Reply With Quote
Old 04-26-2008, 07:29 PM   #1477
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Have you tried any other brand of synthetic gear oil? Just because Valvoline synthetic did not have favorable results in your case, don't lump all synthetic gear oil into a group as being bad for the 5mt. I have used Valvoline, Royal Purple, Neo oil, Ams oil synthetics all with out issue along with the factory OEM lube off the assembly line. Yes I do have a personal preference as to which one I thought gave the best over all feel and one I dislike the most, but that also changes with summer and winter(same weight oil).
flstffxe is offline   Reply With Quote
Old 04-26-2008, 07:50 PM   #1478
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
^^^Good point about trying other oils but I'm happy with what I'm using. I was just pointing out to DS1 that the Valvoline Syn doesn't work for everyone.
Old 04-27-2008, 12:45 AM   #1479
boney7
Member#: 114696
02 WRX
02 White Wrx/itch fixed
70k miles on USC and no problems,, this is after replacing the syncros twice before the warranty was up..
boney7 is offline   Reply With Quote
Old 04-28-2008, 08:41 AM   #1480
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
I used LubroMoly 75W-90 Synthetic between 30k and 60k miles. It was fantastic in all but the warmest weather. Now I'm on Valv Synth.
Asinine is offline   Reply With Quote
Old 04-28-2008, 09:20 AM   #1481
CrashTestRacer
Member#: 66394
2004 WRX Wagon
I only ready a few pages back, so this may be a repeat...
What are the current thoughts on running redline lightweight shockproof on a 5MT? I've been using it for a ~30k miles now and am happy with it...
CrashTestRacer is offline   Reply With Quote
Old 04-28-2008, 02:21 PM   #1482
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
-Dylan @ DS1
Except that the issues went away with non-syn oil. Also, before switching to the synthetic, I was able to downshift into first with the car moving. After switching, the car had to be at a dead stop and still didn't always want to go in gear. I never tried other brands, but there are more than 2 people that have problems with synthetic oil in the 5MT.
bluescoobywagon is offline   Reply With Quote
Old 04-28-2008, 02:37 PM   #1483
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
I'm one of 'em! Redline 75w90 gave me a wicked 4th gear grind when downshifting from 5th at speeds above 40mph that wasn't there when using mineral-based fluids.
Spenk is offline   Reply With Quote
Old 04-28-2008, 03:56 PM   #1484
DS1
Vendor
Member#: 111780
^^ MT90 is an ATF based fluid for Honda transmissions.
We've been running the Valvoline syn. for over 5 years in all of out customer's street cars and never had an issue. We run the Motul Gear 300 in all of our "hard use" cars and no issues there either and it's synthetic.
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 04-28-2008, 04:11 PM   #1485
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Would trying a synthetic with different viscosity (higher possibly) solve some of these guys' synchro issues?
2slofouru is offline   Reply With Quote
Old 04-28-2008, 06:25 PM   #1486
DS1
Vendor
Member#: 111780
Sometimes a higher viscosity can cause syncro issues because the gear has to be spun up to speed while submerged in the fluid
-Dylan @ DS1
Old 04-28-2008, 10:02 PM   #1487
boney7
Member#: 114696
02 WRX
I've replaced my syncros twice using the valvoline syn...
Old 04-29-2008, 01:56 PM   #1488
DS1
Vendor
Member#: 111780
^^ which gear syncro?
Old 04-29-2008, 02:05 PM   #1489
Jay04WRX
Member#: 34075
2009 CTS-V
Originally Posted by Soul Shinobi View Post
It's said the cocktail should be changed every 10-15K miles. We've been discussing the excessive wear caused by the cocktail and the following fluids have been recomended:
Subaru Extra-S (ask for it at a dealer, or buy a 5 gallon drum, not sold by the quart)
75w90w Valvoline
Amsoil
Motul Gear 300
does anyone know a good site that has either of these two oils at a good price? I am going to replace the US cocktail with reg 75w 90 non-synthetic gear oil.
I dont want to harm the tranny at all with a synthetic that will be too slippery.
thanks
Jay
Jay04WRX is offline   Reply With Quote
Old 04-29-2008, 02:07 PM   #1490
boney7
Member#: 114696
02 WRX
It's been so long but I know the infamous 3-4th, and there were others but the whole thing had gone to crap on dealer lube.. twice.. Maybe I'll try the others later depending on what I do with the car since I have a broken engine..
Old 04-29-2008, 03:31 PM   #1491
DS1
Vendor
Member#: 111780
^^ that's not a fluid issue, there is a design flaw in the 3-4 set. Do you have a short throw in the car?
Jay04WRX- We have the Valvoline and Motul in stock.
-Dylan
Old 04-29-2008, 03:39 PM   #1492
Jay04WRX
Member#: 34075
2009 CTS-V
-Dylan
Yes I do have a short throw in my car (kartboy). How much would it be each shipped to 06029 for what I need? I think it was 5 quarts, i forgot sorry.
Jay
Old 04-29-2008, 06:11 PM   #1493
DS1
Vendor
Member#: 111780
^^^ I would swap out for the SPT short throw. 5 quarts of Motul Gear 300 is $90 shipped
-Dylan @ DS1
Old 04-29-2008, 07:04 PM   #1494
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
-Dylan @ DS1
What makes the SPT better than the KB shifter?
Superorb is offline   Reply With Quote
Old 04-29-2008, 07:20 PM   #1495
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
+1 Would like to know the answer too.
rexman2002 is offline   Reply With Quote
Old 04-29-2008, 07:39 PM   #1496
DS1
Vendor
Member#: 111780
The angle of the linkage. If you run a KB shifter look how the linkage changes angle when installed. We see a lot of shift selector seals leaking with KB shifters.
-Dylan
Old 04-29-2008, 08:02 PM   #1497
Rickyh
Member#: 40453
Rickyh is offline   Reply With Quote
Old 04-29-2008, 09:43 PM   #1498
boney7
Member#: 114696
02 WRX
so whats your solution to a design flaw? because USC is the only solution that I have found,
maybe when I get my donor I will tear apart the tranny as well just to see if theres any mayhem going on..
-Dylan
Old 04-29-2008, 09:50 PM   #1499
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
-Dylan
Old 04-30-2008, 08:00 AM   #1500
Jay04WRX
Member#: 34075
2009 CTS-V
-Dylan @ DS1
How much for the valvoline?
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 08:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
