Old 01-15-2006, 11:54 PM   #1
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Default Dummy check before I buy something.
v4 STI rear end. 4.44 Final drive. I am getting the R180 and axles. Do I need the hubs to comeplete the conversion? I won't be able to use my WRX rear brakes...correct? I noticed someone said the driveshaftshop makes r180 dif to r160 hub axles. If this is correct, could I take my old axles, and have the r180 spline put on them so they would work with the new r180?
Am I making sense?
Thanks.
DoctorNick is offline   Reply With Quote
Old 01-16-2006, 12:36 AM   #2
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
well i installed a 6spd in my car.. w/ whole conversion including rear axles hub and diff, etc..i'm not too sure about 4.44 final drive. but.. if you wanna use 6spd r180 (3.900) final drive you have to change rear axle and hub or you could send it out to godspeed and have them install r180 ring and pinion for you.. check it out.. i'm not too sure.. about 4.44 final drive though.
taeyax82 is offline   Reply With Quote
Old 01-16-2006, 12:45 AM   #3
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I have a special 4.44FD 6mt. Hence why I have been searching high and low for a lagit 4.44 r180. The v4 came with one.
The seller doesn't understand I want the hubs.. so I was wondering if there was a way to get custom axles made to fit my old wrx hubs.
Old 01-16-2006, 12:59 AM   #4
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
hm. get the proper hubs. r180 hubs from a GDB will increase your track about 15m in the back. gdb axels work on a gc8 as well- thts my setup.
the driveshaft has a issue with flange. check my faq
http://forums.nasioc.com/forums/showthread.php?t=907818
swapstar is offline   Reply With Quote
Old 01-16-2006, 01:08 AM   #5
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Nope, the hubs don't increase the track, the GD lateral links do.
Ver.III is offline   Reply With Quote
Old 01-16-2006, 01:25 AM   #6
cronic
Member#: 9749
Exactly..
Call up the DSS man.. THey have what you are looking for.
cronic is offline   Reply With Quote
Old 01-16-2006, 09:43 AM   #7
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
the lateral links also increase the track.
the GDB hubs on my gc8 increased the distance from rear shock to inner tire enough to not require a wheel spacer which was previously required to clear the distance.
what is it called then, if not track? TEACH me somthing!
Old 01-16-2006, 10:39 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm i was under the impression that the 04sti hub was the same where as the 05-06sti are wider
Old 01-16-2006, 05:11 PM   #9
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
i have version 8 jdm rear hubs. perhaps you can take some measurements cronic and teach us somthing
Price Check before buying new car: 01 RS Kardon MAIC Private Classifieds 0 10-26-2009 02:35 PM
What to check before buying a used turbo goixiz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-07-2007 02:19 AM
Anyone else still look at where something is made before they buy? nos Off-Topic 23 07-21-2006 07:28 PM
One final check before buying RA-1's MattSTi Tire & Wheel 5 11-26-2004 10:38 AM
I want to buy something on ebay but don't know what. Help me find something. Eric SS Off-Topic 28 05-15-2004 05:16 AM
