Old 01-16-2006, 12:38 PM   #1
MatthewMarchand
Member#: 94663
Default Stiffer suspension, stock ride height?
Ok, I drive a 2005 Impreza WRX, and am looking for a better suspension set up, that still maintains a close to stock ride height, but improves handling.
The car is daily driven, and probably a bit of Auto-X and track days.
Thanks.
MatthewMarchand is offline   Reply With Quote
Old 01-16-2006, 12:45 PM   #2
wgb113
Member#: 32478
2004 Forester XT
STI Pinks?
Bill
wgb113 is offline   Reply With Quote
Old 01-16-2006, 12:47 PM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
What type of ride are you looking for? The TEIN H-tech (and others I don't remember) increase the rates to that of the stock STi, but offer a much larger drop than you are looking for. The STi pink springs offer a moderate drop, but are a bit stiffer than the stock STi springs.
iON Performance "Sport Spec" springs offer the same rates as the stock STi, but only a 1" drop. If you are hard-set on keeping the stock ride height, find some springs off an '04 STi from someone who upgraded. Those should keep your ride height stock and give you the increased spring rate you are looking for.
Scooby921 is offline   Reply With Quote
Old 01-17-2006, 12:39 PM   #4
MatthewMarchand
Member#: 94663
Thanks guys.
Old 01-17-2006, 12:42 PM   #5
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Sti Pinks will drop you about an inch all around. I have the v7's and love them.
Acostafan is offline   Reply With Quote
Old 01-17-2006, 05:17 PM   #6
Mark Avery
Member#: 10313
2002 WRX wagon
Stock STi springs will drop your car the least (about 10mm), and you should be able to pick up a used set cheap.
You'll want to pair those with a strut designed to handle that much spring. STi takeoff struts would be a good used option (only 04 struts will fit your car, not 05-06). But, I would recommend adjustable Koni inserts for a great setup.
Mark Avery is offline   Reply With Quote
Old 01-17-2006, 06:25 PM   #7
boxerT
Member#: 16311
2004 STi
WR Blue
I bought a lightly used '04 STi strut assemblies from a NASIOC member for $325 shipped. It would be hard for you to beat this bolt on setup for so little cash. I would search the forum and private for sale classifieds for something just like it.
boxerT is offline   Reply With Quote
Anyone make stiffer springs that maintains the stock ride height? mikeythejew Brakes, Steering & Suspension 24 05-29-2011 06:16 PM
FS IL: STi V7 RA springs - stiffer with stock ride height peterex MWSOC Private Classifieds 7 10-29-2009 10:42 PM
FS IL: STi V7 RA springs - stiffer with stock ride height peterex Suspension/Brakes/Handling 8 10-29-2009 10:42 PM
stiffer stock ride height springs??? Scott F. Williams Brakes, Steering & Suspension 10 04-18-2005 07:32 PM
Forester suspension keep stock ride height? ferretboy Brakes, Steering & Suspension 1 05-08-2001 08:33 PM
