Old 06-11-2001, 12:53 AM   #1
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Question Most modified Outback?
I was wondering who on i-Club has the most modified Outback? I will nominate myself . So far mechanically I have a drop in K&N and RS shifter with Cusco bushings. Suspension-wise, I have Whiteline heavy duty front and rear swaybar links and adjustable rear swaybar. Plans in the next month include RS wheels and tires and KYB GR2s (probably with Whiteline stock height springs).
Doug
dvancleve is offline   Reply With Quote
Old 06-11-2001, 06:41 AM   #2
gtcrispy
Member#: 3285
2005 Legacy GT
RBP
Talking
I have a friend that though he doesn't visit the board he was one very nice outback. I wish I could remember the specifics better but basically, it's turbo charged, striped interior, roll cage, full suspension work, new transmission, exhaust etc. It's one hell of a car. When I see him online I will get more info but thats all I know for now.
Kevin
gtcrispy is offline   Reply With Quote
Old 06-11-2001, 09:13 AM   #3
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
I've done a decent bit but it is still a work in progress. That basically means I'm broke.
Lemme see...
205-70/15 Michelin Rainforce MX4 tires
Axxis Metal Master semi-metallic brake pads (front)
Corbeau Forza Driver's Seat (en route)
Hella FF100 Driving Lights
Hella Twin Supertone Horns
Homemade Lower Grill Protection
Painted Hood Scoop Plate (Hi-Gloss red)
Primitive Racing 1/8" Front Skid Plate
Stromung Cat-Back Single Tip Exhaust
Subaru rear differential protector
Trunk Mounted Fire Extinguisher
Removed Factory Intake Silencer
Amsoil air filter
Next is probably going to be a new mid-pipe since my 2.25 turned out not to fit (stupid midas) and then a tranny cooler, 21mm rear sway bar, ALK, harness, cb radio with weatherband, better tires, suspension upgrade
http://www.remarcable.net/misc/legacy_outback/
remarcable is offline   Reply With Quote
Old 06-11-2001, 02:35 PM   #4
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Post
There is an MI guy that has a custom CAI, exhaust, low profile tires, and a 100 shot. I'm not sure if he's got anything else though.
JC is offline   Reply With Quote
Old 06-11-2001, 08:07 PM   #5
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
If 'most modified' includes just adding SOA stuff that didn't come on the car, then I've done a lot - in addition to the couple of aftermarket things I've put on. This is on a 96 OB; some of these items are for other model years. Everything was self-installed
SOA stuff:
- front/rear skid plates
- trailer hitch & wiring
- woodgrain kit
- 6-disk in-dash CD changer, new OEM stereo, amp/sub (from 2001 MY)
- tweeter kit
- heated mirrors (ran new wiring harness)
- engine block heater
- security upgrade (waiting for install)
Non-SOA stuff:
- whiteline adj rear swaybar
- whiteline antidive kit (going on RSN)
- Infinity 625 speakers (all four doors)
- 80w AW/gold fogs
- 70/80 krypton-quartz headlamps
- Competition Unlimited headlight harness
- Hella Twin Supertone horns
- JC Sports underdrive pulley
- K&N drop-in (had full large cone, too loud)
- Bradi front rotors
- Michelin Rainforce tires
I think there's more; can't remember :-)
rrubel is offline   Reply With Quote
Old 06-11-2001, 08:44 PM   #6
bagio
Member#: 7442
98 Legacy Outback
dark violet
Post
So, nobody has super/turbocharger?
I'm disappointed...
And why are you guys paying attention to
things like stereo/security?
bagio
bagio is offline   Reply With Quote
Old 06-11-2001, 09:02 PM   #7
gtcrispy
Member#: 3285
2005 Legacy GT
RBP
Post
Read a little closer in my post.
Kevin
Old 06-12-2001, 12:27 AM   #8
dvancleve
Member#: 5211
Unhappy
bagio,
I think most Outbacks have the Phase I 2.5l (DOHC heads and weaker block) that is not well suited to turbo or supercharging.
Doug
Old 06-12-2001, 12:30 AM   #9
dvancleve
Member#: 5211
Question
Hey guys,
I also bought a WRX 6 disk in dash CD changer thinkin/hoping that it would plug right in. Well, I have tried two different times and it doesn't work just plugged in like the original tape deck. I understand that newer cars (mine is a '97) or Imprezas have a ground wire that attaches to the head unit. I am going to try running a ground wire to a screw on the unit and see if that does it. If it doesn't, I am at a loss. Anybody have any experience with this sort of thing?
Thanks, Doug
Old 06-12-2001, 01:28 PM   #10
lucien2
Member#: 1519
1998 Volvo V70R
Post
don't forget that Outback with the GT suspension and 17" rims....
lucien2 is offline   Reply With Quote
Old 06-12-2001, 10:29 PM   #11
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Post
i think he was running 16's
there's a guy runing around san jose on tein ha-s on his bg5 outback ,but I have yet to see it; probably a good thing, or i'd be $1200 poorer
sybir is offline   Reply With Quote
Old 06-13-2001, 05:58 AM   #12
lucien2
Member#: 1519
1998 Volvo V70R
Post
Old 06-13-2001, 11:45 AM   #13
dvancleve
Member#: 5211
Lightbulb
I am doing the same conversion, but with MY01 RS wheels and tires (I got them locally on Monday). I am pretty sure I am going to go with the Whiteline stock height wagon springs at the same time. When the 205/55VR16s wear out, I will probably try test fitting a bit bigger tire to get closer to the original tire diameter.
Doug
Edit: Well I put the RS wheels and tires on this afternoon (need to get the old wheels boxed up to ship). They look less rediculous than I thought they would. Boy, those tires aren't really wide enough to protect those 7" wide rims. I will definitely do a "Plus Zero" if I can't fit a slightly wider and taller tire when these wear out...
[ June 15, 2001: Message edited by: dvancleve ]
Old 06-15-2001, 10:29 AM   #14
remarcable
Member#: 2362
1999 Legacy Outback
Post
MY SEAT CAME!
I'll post pics if I can figure out how to install it.
FS : subi garage sale all most go!!!"blitz,perrin,OEM,STI n RS" subiidude Engine/Power/Exhaust 35 03-24-2011 01:15 AM
Most ticketed - Subaru Outback? ATX25RS Texas Impreza Club Forum -- TXIC 17 01-28-2009 08:36 AM
Outback Owners Most Likely to Get Tickets Cocoa Beach Bum General Community 16 01-14-2009 06:59 PM
pic request: modified old school outback sports RChampion Member's Car Gallery 40 02-24-2006 05:40 PM
Most reliable Outback? what year? txl146 Outback Forum 3 10-05-2004 11:33 AM
