Old 01-16-2006, 03:59 PM   #1
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Default 4EAT to 5MT swap problems, please help!!!
Hello everyone, I am looking for some help.
I am doing a 4EAT (auto) to 5MT (manual) swap in my 02 WRX. Literally everything for the whole swap is done, but from what I understand, the car just wont start. I had my mechanic do the swap, because the price was so low, I just couldn't refrain. Anyways, from what I understand, He is done. The car is 100% back together, but the car wont start. The new trans is in,with the new rear diff, and all the linkage, the clutch cyl, manual trans brake cyl, all the linkage ect. The problem is that the car just wont start!!!
I am assuming that the neutral safety switch, or the clutch switch, or something else in the wiring harness needs to be wired in or something, in order to allow the car to start. Can you please help me with some info on how to make it start?
Here are some questions that I have.
Is the wiring harness different from auto to manual?
If not, is there a sub harness that goes from the harness to the transmissions varios sensors ect?
Do I need to disconnect the TCU?
Is the clutch switch going to work the way I want? I am thinking that the cruise control will either not work at all, or just not have a clutch cruise off switch. Also, I am assuming the car will just start all the time, whether the clutch is in or out. Is that correct?
Can you guys please give me some help? Thanks!!!
PS I know bunot has already done this swap, and I have just sent him a PM and an email. Hoping to hear back from him soon. Thanks again!!!
jared nelson is offline   Reply With Quote
Old 01-16-2006, 05:04 PM   #2
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Okay, so it tunrs out that Ron with Axis power racing is the ****. I just called him and got the answer. I have a 2.4 liter motor built by him, and I call him every time I have any sort of a problem with my car. Infact, I really think I should have a yearly paid subscription to his advice and help. He seriously has answers for me within 10 seconds of my calling him. Hell stop me in the middle of asking my question, and answer me right away.
There is a harness connector that connects to the under side of the automatic transmission shifter. There are a bunch of pins on that connector. 2 of the pins are for sending and recieving volts when the car is in either neutral or park. All I have to do is run a wire from one of the pins to the other one. That will make it to where I always can start the car, no matter if its in gear, or the clutch is out or whatever. Then If I would like to, I can wire the clutch switch into those pins, and have an actual clutch swith. I dont think I will even do that though, because I really like to be able to start the car any time I want. Then If there are any problems, I can still drive the car and get it started.
Now, all I have to do is wire in the other things that are on the trans, like the speed sensor, and the other 1 or 2 sensors on the trans.
Old 01-16-2006, 10:06 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
There are other electrical issues you will need to take care of. Do NOT just wire the clutch switch to the two pins on the trans connector. You must use a relay because those two pins that used to be connected to the inhibitor switch carry ignition amperage which goes to the starter.
Read my write up on the electrical stuff I had to deal with.
http://www.surrealmirage.com/subaru/...lectrical.html
Legacy777 is offline   Reply With Quote
Old 01-16-2006, 10:20 PM   #4
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
your write up is for a completely different car. I know some of it applies, and I have already read about 20% of it. (the things I think I should know)...but for the most part, alot of those thigns are not the same as my car.
WTS I dont know what my guy is doing. I called him today with the little bit of info I got, and he basically put me in my place. Turns out he is a rocket propulsion engineer for his day job. And he has done some insane ECU harness marrying, and much much wiring and other fabrication.
So basically he got it all running, except for the lack of speed sensor on the trans. So I need to grab the one I have at my house, and take it to him tmorrow. then the car will run. Ill let you know. Maybe hell let me post what he did for the swap. Should know tomorrow.
02 wrx 4eat to 5mt swap wiring scOOtNsOOby Transmission (AT/MT) & Driveline 2 10-11-2009 07:45 PM
4eat to 5mt - cruise problem morrocco88 Subaru Conversions 23 08-23-2007 01:11 AM
4eat to 5mt - cruise problem morrocco88 Transmission (AT/MT) & Driveline 1 04-30-2007 10:55 AM
Suspension swap problem.. please help! merauder69 Brakes, Steering & Suspension 8 10-08-2004 08:08 PM
4EAT to 5MT swap? erice1984 Subaru Conversions 6 05-06-2004 09:42 PM
