![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 58352
Vehicle:04 20G STI(SOLD) 08 z51C6 (growing mullet) |
looking at 18x8.5 ssr gt2 +48 offset wheels with 225 40 18 tires...
is this offset too high? how much will my speedo be different from stock? I'm using sti pink springs.....any chance of rubbing.... I have an 04 sti..... Matt
#2 |
Member#: 86356
Those are skinny tires. If you are only going to run 225s why not save money and hassle and get 7.5 or 8 inch wheels.
As for the speedo difference... http://www.miata.net/garage/tirecalc.html |
#3 |
Member#: 66033
SCIC
Vehicle:05 STi |
Yea the offset is perfect. But i would go with some 235/40/18 tires or bigger. You will not rub with the 235's not sure about any bigger.
#4 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
actually 225/40-18 can and does fit a 9" wide wheel so, 8.5" is fine and the overall diameter is the same as a 225/45-17 so, there will no speedo difference
#5 |
Member#: 86356
Sure they will fit, but if you only plan to run 225s, wouldnt 7.5 or 8 inch wheels be cheaper?
#6 |
Member#: 58352
Yeah I'm just looking at a set of slightly used gt2's....and the tires that came with them are 225's.....its such I good deal I can't pass up.....I'll just use up the 225's quick and throw on some 235's...
Matt |
#7 |
Member#: 47769
I would replace them with 245 35 18 when you get around to it.
#8 | |
Member#: 29019
Vehicle:2012 Impreza WRX STi DGM |
I have the following set up with no rubbing:
18x8.5 ssr gt2 +48 (in gold btw) Tire size of 235/40/18 04 STi lowered with pinks Alignment is -1.5 in the fronts and -1 in the rears (recommended by andrewtech for daily (spirited)driving) You should have no problem rubbing with the relatively thinner 225's. Quote:
#9 | |
Member#: 58352
what tires are you running? Are you sure you won't have any rubbing with full suspension compression?
#10 | |
Member#: 29019
Pirelli Corsa 235/40/18. I got them from Myles at racecompengineering. I had the same set up as him before he got his coilovers. If I recall correctly, he had no rubbing issues with the pinks. It might be worth your while to PM him. BTW, this is the actual pic of my tires that Myles is using to sell his silver gt2's that have the same tires. Bad ass summer tires and effective in the wet. Can't wait till winter is over.
![]() Quote:
| Thread Tools | |
| Display Modes | |
| wtdd tires and wheels 5.114 | BreaWRX-STI | SCIC Private Classifieds | 1 | 12-11-2008 10:40 PM |
| 5 dollars tire and wheel | congowrx | NESIC Private Classifieds | 2 | 10-13-2008 12:07 AM |
| WTB 08 STI BBS wheels or any 18x8.5 wheels with proper offset for an 08 STI. | HRCboy | VIC Private Classifieds | 3 | 01-28-2008 05:06 PM |
| personal car GT2 SSR 18x8.5 local pickup | RaceComp Engineering | Mid Atlantic Impreza Club -- MAIC | 29 | 11-07-2005 04:38 PM |
| work wheels vs-xx 18x8.5 with new tires will fit 04 wrx and sti | scoobydave | Private 'For Sale' Classifieds | 6 | 11-06-2005 11:51 AM |
