Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 01-16-2006, 06:25 PM   #1
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
Default Complete ECU pinouts for all GC8 JDM EJ20; ej20g, ej20k, ej207
wonkers. i've got it! solves all of anyones ecu pinout issues except for 1 thing......
its in japenese!!
haha. bring out your japenese friends yo!
swapstar is offline   Reply With Quote
Old 01-16-2006, 06:56 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I'm sure someone will step forward...
Old 01-16-2006, 07:15 PM   #3
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Very nice, what book is that?
THAWA is offline   Reply With Quote
Old 01-16-2006, 08:47 PM   #4
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Bwuahahahaha
1. Looks like the Owners Bible or Maintenance File
2. I have the pin outs from Subaru and they do not match up to published books. Suby is right News Mook is wrong and trust me I found that out the HARD way!! Your O2 and your Throttle sensor will most likely be reversed!!
DuoMaxwell is offline   Reply With Quote
Old 01-16-2006, 09:34 PM   #5
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I got excited till I saw it wasn't in english
I really need a v7 207 pinout.
DoctorNick is offline   Reply With Quote
Old 01-16-2006, 10:36 PM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
you got the page for ej20h?
snowman4us is offline   Reply With Quote
Old 01-17-2006, 01:23 AM   #7
suberdave
Member#: 101865
88 GL-10 STi
here is an EJ20G i translated while doing my swap
http://www.suberdave.com/subaru/glwr...WiringDiag.pdf
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 01-17-2006, 04:01 AM   #8
bmxpunk
Member#: 89599
1995 almost 22B:)
red
holy crap!!! what ecu is the one on the bottom wit hthe three plugs? That is the same plugs/pins as my 1.8L harness..... anybody see what I am trying to get at? WOuld it work if I rearranged the wires and added the few I needed (probably boost control I am guessing.)
bmxpunk is offline   Reply With Quote
Old 01-17-2006, 06:53 AM   #9
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
ej18 plugs are physically identical to EJ20k. the branch design and setup of the harness are quite a bit differnt, id say its possible but not very probable or easy to convert. youll have to do boost and map sensor, ignitor style is really close (both are waste spark). EJ20K bits are the most rare to come by imo, actually im on the hunt for some. the motor has 2 arms in the back and 2 that connect to the side by the battery that run the engine harness, it would be considerably hard to adapt a ej18 harness to the K elecs and ecu.
Old 01-17-2006, 02:09 PM   #10
bmxpunk
Member#: 89599
1995 almost 22B:)
red
you saying that just to make a sale....... just kidding. well if that is the case...... bummer. What heads will work if I rewire my car wit ha 20G harness? just the 20 g heads? which manifolds?
of topic, which series is the 22B? Ej22G correct?
Old 01-17-2006, 05:22 PM   #11
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
haha. yes. ej20 g and k have compatible heads (intake manifold wise) so you can go 90 deg side inlet turbine or straight k style. wrx version 1-4 manifold are compatible.
so all ej20g version 1-4 and ej20K v3/4 would be compatible.
no idea on 22b. i think i can find a legacy TT diagram, i have a hunch of where to find....
Old 02-04-2006, 11:43 PM   #12
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
Ej207 verison 5/6
Input side??
117 *ECU Power?
121 *Ignition SW?
60 Sensor Power?
55 Airflow sensor ?
124 Airflow sensor ground?
65 02 Sensor?
50 Crank angle sensor?
63 Crank angle sensor ground?
51 Cam angle sensor?
70 *Water temp sensor?
72 Knock sensor?
66 Throttle sensor?
49 MAP sensor?
67 Intake temperature sensor?
48 Car speed sensor?
37 Air conditioner SW?
30 Starter SW?45 Neutral SW?
31 Power Steering Switch?
29 Torque Down 1?
36 Torque Down 2?41 Small light SW?38 Blower fan SW?43 Rear Defogger SW?40 Test mode connector?35 Reed (Lead?) memory connector?
7:23
Output side??
108 Injector #1?
107 Injector #2?
105 Injector #3?103 Injector #4?
1 Ignition signal 1,2?
8 Ignition signal 3,4?
10 ISC Valve 1?
3 ISC Valve 2?
9 ISC Valve 3?
2 ISC Valve 4?
25 Canister Purge Solenoid?
19 ?? pressure solenoid?
24 Atmosphere switch solenoid?
4 Radiator Relay 1
11 *Radiator relay 2?
17 Fuel Pump relay?
16 Air conditioning relay?
22 Check Engine Light?
34 Engine RPM?
45 Intake air amount?
33 Torque down ???
18 Alternator ???
10 Injector ground?
102 Power-type ground?
104 Ignition ground?119 ???
122 Sensor-type groundThis is F/G (so version 5/6)
Input side
117 ECU Power
121 Ignition SW
60 Sensor Power
55 Airflow sensor
65 02 Sensor
51 Cam angle sensor
70 Water temp sensor
72 Knock sensor
66 Throttle sensor
49 MAP sensor
48 Car speed sensor
30 Starter SW
45 Neutral SW
29 Torque Down 1
36 Torque Down 2
41 Small light SW
38 Blower fan SW
43 Rear Defogger SW
7:23
Output side
108 Injector #1
107 Injector #2
105 Injector #3
103 Injector #4
10 ISC Valve 1
3 ISC Valve 2
9 ISC Valve 3
2 ISC Valve 4
4 Radiator Relay 1
7:23
11 Radiator relay 2
17 Fuel Pump relay
34 Engine RPM
33 Torque down ??
18 Alternator ??
10 Injector ground
104 Ignition ground
119 ??
_______________________________________
EJ20G
Input
16 Power Steering Switch
19 Idle switch
20 Knock sensor signal
21 Knock sensor body ground
22 Cam Sensor body ground
23 Cam sensor signal
30 Accelerator switch
31 Starter switch
32 Air conditioner switch
34 Crank angle sensor switch
33 Crank Angle sensor body ground
37 Throttle sensor signal
36 Throttle sensor ?? Voltage ground
38 Throttle sensor body ground
39 Ignition SW+
40 Car speed sensor
41 Neutral SW
45 Airflow sensor body ground
46 Airflow sensor signal
47 Airflow sensor power
55 Airflow sensor body ground
48 Water temp sensor
49 O2 sensor signal
57 O2 sensor body ground
50 Exhaust temp sensor
51 pressure sensor signal
52 pressure sensor power
53 pressure-type ground
7:34
output
1 ignition #1
2 ignition #2
3 ignition #3
4 ignition #4
113 ignition-type ground
7 Radiator fan relay 2
8 ? solenoid
9 Fuel pump relay
10 Air conditioner relay
12 Atmosphere Absolute pressure switch solenoid
13 Check engine lamp
15 radiator fan relay 1
25 engine rotation signal
111 ISC valve open
112 ISC valve close
101 injector #1
102 injector #2
103 injector #3
104 injector #4
134 exhaust noise warning lamp
105 injector-type body ground
106 injector-type body ground
121 ? body ground
122 ? body ground
________________________________________________
EJ20K
Input
113 ECU power
111 Ignition SW
37 Airflow sensor signal
36 Airflow sensor ground
38 O2 Sensor
33 crank angle sensor +
34 crank angle sensor ground
35 cam angle sensor
40 water temp sensor
39 knock sensor
48 throttle sensor power
46 throttle sensor signal
45 absolute pressure sensor
22 car speed sensor
43 exhaust noise sensor 1
31 Air conditioner SW
23 Starter SW
32 Neutral SW
115 sensor-type ground
105 injector ground
110 power type ground
116 ??
106 ignition ground
24 intake temperature sensor
28 intercooler spray auto SW
7:44
output
104 injector #1
101 injector #2
102 injector #3
103 injector #4
1 ignition signal 1,2
2 ignition signal 3,4
107 IDC valve open
108 IDC valve close
26 canister purge solenoid
8 ? pressure solenoid
5 atmosphere switch solenoid
17 radiator fan relay 1
25 radiator fan relay 2
4 fuel pump relay
11 aircon relay
3 check engine lamp
12 exhaust sound warning lamp
27 engine rotation signal
20 select monitor send
21 select monitor receive
41 test mode connector
42 reed (lead?) memory connector
30 AT ?
18 AT air amount
d
Old 02-05-2006, 04:15 AM   #13
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
pretty sure the 22b is a V4 basically. same intake manifold IIRC when i saw one up close.
the block is different however, and Monson knows more about this, but it is a PHASE II 2.2 liter block. heads i would assume would be very close to V4 R or RA (probably RA, has better cams)
and i also agree. K series are very hard to find parts for.....
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-05-2006, 05:27 AM   #14
THAWA
Member#: 44581
3 Boxers 2 AWD
Isn't a v4 a Phase I engine? If it's a Phase II it would have to be a v5 right?
Old 02-05-2006, 09:55 AM   #15
psaeko
Member#: 7057
this should be a sticky
psaeko is offline   Reply With Quote
Old 02-05-2006, 12:18 PM   #16
kheff46
Member#: 66739
2002 WRX wagon
Word!
kheff46 is offline   Reply With Quote
Old 09-10-2006, 04:27 PM   #17
sense of nature
Member#: 112759
2018 bugSti
SexyRP
Man these threads have helped soooo much
bump
sense of nature is offline   Reply With Quote
Old 12-02-2006, 09:49 PM   #18
mdcmotorsports
Member#: 75495
1995 Miller
Syncrowave 351
Im still in search of version one wiring for the ECM....
mdcmotorsports is offline   Reply With Quote
Old 12-02-2006, 10:24 PM   #19
JoshP
Member#: 94350
that guy is such a douche
JoshP is offline   Reply With Quote
Old 12-03-2006, 09:47 PM   #20
chris sanborn
Member#: 42995
Wow ,
This is what I've been looking ,I think! I am doing the STI conversion from a GF8 into my 97 L coupe. I've never worked on a scooby before so please excuse my ignorance but how would I know that this pinout + diagram will work with the set up I have. I'm so use to doing cossy's and audi's where the engine harnasses are seperate not integrated, especially the cossy's. Not so much the audi's but easier then the suby none the less. I don't want to make a mistake just in case they chaged something in different years or models. I am a little lost by only having the wrx and RS pdf's, I don't want to blow the mines computer that came with this clip. So if anybody could send me in the right direction ie( how to use the vins or part numbers to verify it) I would really appreciate it.
Cheers,
Chris
chris sanborn is offline   Reply With Quote
Old 12-12-2007, 04:52 PM   #21
JJMINIMAN
Member#: 158347
Default Mass Air Flow Wiring
Hey Guy Got My Motor Started Its A 1995 Ej20h But I Snipped On Of The Wires While Clenaing Up It Sth E Black And Red One Coming Off The Mass Air Flow I Found Where I Thought It Went To A Larger Black And Red That Went To The Ecu And Was A Ground
But If I Probe The Mass Airflow While Engine Is Warm I Get No Output At All Specs Say About 1 Volt I Get 0volt
Has 12v Into It And Has Ground
I Ordered A New Mass Airflow But Maybe Ut Has Something To D O With Black And Red Wire I Reconnected
JJMINIMAN is offline   Reply With Quote
Old 12-12-2007, 05:25 PM   #22
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
already got that Bible! but thanks anyways!
old_duwel is offline   Reply With Quote
Old 12-13-2007, 09:25 AM   #23
JJMINIMAN
Member#: 158347
Default Reply
not sure what the bible reply meant
Old 12-17-2007, 05:42 PM   #24
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
The pinouts are from the Tuning Bible for Subys, however they are not that correct as stated before. I have the actual books from Subaru for the EJ20G and K and they dont match up, total pita to realize this in the middle of a build!!!
Old 12-18-2007, 09:49 AM   #25
JJMINIMAN
Member#: 158347
Default Buble
there is no diagram any where for a 1995 ej20h
oh well now i waiting for my mass air flow meter it is the same as a sva subaru i couldnt find the twin turbo one but matched the numbers up and svx came upo same numbers
ECU Pinout for Ej18 Ecu... Jdmleggy97 Engine Management & Tuning 0 02-21-2010 10:23 PM
Big question for all GC8 with JDM engine swap specialists V6 Subaru Conversions 6 12-03-2006 09:33 PM
HELP!!! Need a ecu pinout for a 96 L for e-manage install! Sideout Legacy Forum 0 12-02-2005 12:04 AM
Looking for ecu pinout for 97 jdm sti StrongBow Subaru Conversions 1 07-19-2003 11:21 PM
ECU Pinout for 93 Impreza subachad Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-18-2001 11:33 AM
