Old 08-08-2008, 06:10 PM   #51
koom
Member#: 144426
Originally Posted by CuevaCustoms View Post
I need one for the EJ20TT motor does anyone have it?
It depends on which EJ20TT motor you have. The BD5a/BG5a Legacy's have a four plug ECU. I've got the pinout for that shown below and compared to an early WRX and BC5 Legacy. The BG5b/BD5b TT Legacy has a 3 plug ECU that is nearly a direct swap with a V3/V4 ECU.
koom is offline   Reply With Quote
Old 10-24-2008, 10:55 PM   #52
DvSkD4
Member#: 181829
2001 Impreza RS
^ do you have that pinout in a larger file you can pm to me?
DvSkD4 is offline   Reply With Quote
Old 10-28-2008, 03:28 PM   #53
Odyknuck
Member#: 192866
2006 Impreza
Are the 2.0 2.2 and the 2.5 the same ECM and/or can they be interchanged
Odyknuck is offline   Reply With Quote
Old 10-30-2008, 03:18 PM   #54
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
Does someone have the ECU pinout for a 1994 WRX STi Ver. 1 (ECU code-SA) JDM, I would really appreciate it? I cant find it any where
chrisc1991 is offline   Reply With Quote
Old 11-10-2008, 11:10 PM   #55
TattooRyan
Member#: 193954
1998 impreza WRX STI
white
does anyone have an ecu pinout for the 1998 wrx sti vers. 4 jdm???????
TattooRyan is offline   Reply With Quote
Old 11-24-2008, 05:02 PM   #56
surfpac
Member#: 112214
Originally Posted by bicanek View Post
These might be a bit more comprehensive if you're trying to wire up an EJ20K. I translated the Japanese v3 wiring diagrams, and this is the ECU part. Enjoy.
http://www.bakemono-imports.com/suby005.jpg
http://www.bakemono-imports.com/suby006.jpg
http://www.bakemono-imports.com/suby007.jpg
http://www.bakemono-imports.com/suby008.jpg
Is this similar to a EJ20T? Pardon my ignorance, I'm a newbie.
surfpac is offline   Reply With Quote
Old 01-06-2009, 01:48 PM   #57
renysti
Member#: 179331
1993 subaru wrx
204 rally pearl blue
Hay guys what's up i have a 93 jdm wrx in Jamaica and i would like to used the aem standalone on my car but i only see it for 02 model and up wards,does any one know if that 93 wrx pin up is the same as the US ej20 02wrx?
renysti is offline   Reply With Quote
Old 04-12-2009, 11:29 AM   #58
dalhedian
Member#: 186513
Default hybrid engine
hey men i have a question you seem to know about these two engines that I have ... I bought the ej20k clip but had bad bearings so i bought an ej20g used those engines and pretty much did a hybrid engine ej20g engine ej20k transmission, intake manifold, turbo uppipe downpipe and of course wiring ... I am looking forward to tunning the car ... but idk where to start I was thinking at the power fc and might go for that what do you think .... or anyone else ...
Originally Posted by swapstar View Post
haha. yes. ej20 g and k have compatible heads (intake manifold wise) so you can go 90 deg side inlet turbine or straight k style. wrx version 1-4 manifold are compatible.
so all ej20g version 1-4 and ej20K v3/4 would be compatible.
no idea on 22b. i think i can find a legacy TT diagram, i have a hunch of where to find....
dalhedian is offline   Reply With Quote
Old 04-12-2009, 03:35 PM   #59
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Power fc is pretty much the best bet for these year models. You need to find someone who really knows how to use it or start learning. There is also a tool called datalogit you can buy to make the power fc's even better. I have a power fc for my swap and as soon as I've driven it for a few hundred miles I'll be plugging it in to see what's going on.
2slofouru is offline   Reply With Quote
Old 05-27-2009, 09:00 AM   #60
csugden
Member#: 154959
04 JDM STI
Default 04-07 Swap, fuel pump issues.
I swapped an 07 JDM STI Engine / G/Box in to a 04 JDM STI, installed ECU, complete steering column, have original key, used engine and dashboard harness from 07, 04 cables to fuel pump, etc. Fuel pump not coming on, any ideas?
csugden is offline   Reply With Quote
Old 05-27-2009, 06:27 PM   #61
koom
Member#: 144426
Have you checked that the fuel pump relay is getting the 12v signal from the ECU?
Also check that all the 12v inputs into the ECU are getting power when the key is turned on. I've had the same issue once when swapping ECU's around and found that one wiring harness had a diode between two of the 12v ECU inputs and the other harness did not. Found this when one of the ECU inputs wouldn't go up to 12v when turning the key on.
Old 11-17-2010, 07:51 PM   #62
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
thank you nasioc massive.
maxpowr is offline   Reply With Quote
Old 03-04-2011, 10:53 AM   #63
solutioninject
Member#: 275784
hi all ,iam having a hard time to find the ecm pinout for the v4 wrx jdm .anyone could help me finding it
there is 3 yellow connector and the numbers on the ecm is 1S A18-000D68
solutioninject is offline   Reply With Quote
Old 03-06-2011, 08:06 AM   #64
Spec C
Member#: 77737
2003 spec C
I have this for a version 3 which should be the same its on a pdf pm me your email and i will send it to you
Spec C is offline   Reply With Quote
Old 04-09-2011, 07:05 PM   #65
jay_parot
Member#: 202352
1996 STI V3 JDM
WHITE
does any one have the 200 RX 2.0 ecu C5 pinout ???
jay_parot is offline   Reply With Quote
Old 04-18-2011, 05:57 AM   #66
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
This should help some people.
http://www.cannell.co.uk/Manuals.htm
TAGS:
93 wrx service manual
94 wrx service manual
95 wrx service manual
96 wrx service manual
93-96 wrx service manual
97 wrx service manual
98 wrx service manual
97-98 wrx service manual
2000 wrx service manual
This will also help the porsche swap guys with manuals:
Porsche service manual
KOJAK-02-WRX is offline   Reply With Quote
Old 04-25-2011, 08:58 PM   #67
mccueauto
Member#: 280952
So I have a ej20g I am putting in an outback and the ecm I have I believe is a z4 the numbers on it are 22611 ae360 as stated before I believe this is a z4 if it is not please let me know I also need a pin out for the ecm and a wiring diagram for the ecm so if you have a bible please share the info I would love to get my hands on the wiring diagrams and ecm pin out for this swap. It looks like the three pin schematic is the one I need but I would like to verifie that. thanks a bunch
mccueauto is offline   Reply With Quote
Old 04-26-2011, 06:48 AM   #68
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
You lost me, said you have a Z4 but then you said you need a 3 pin (im guessing you mean plug schematic? If it is a z4 you will have a 4 plug ecu not a 3.
If you really have a z4 ecu that matches your engine you should have a 95/96 engine which is posted in my post right above yours. Just for reference here is where I got the years for your ecu:
http://bbs.scoobynet.com/general-tec...-96-turbo.html
Old 04-29-2011, 01:52 AM   #69
mccueauto
Member#: 280952
Yes I meant three plug ecu when I purchased the engine it said it came with a z4 ecu I think I am finding out it is not a z4 the Aussie site that has all the diagrams did not mach up to what I have either I did a pin out starting at the injectors iac tps....ect to find out what wire went where on the ecu and checked against the pin out diagram the inj where the only things that mach up. Here is the ecu number
22611 AE360
A18-000 D66
I hope I can get some help this is turning out to be a mess it would be better if I could get a freaking pin out.
Old 04-29-2011, 06:46 PM   #70
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
22611 AE360
A18-000 D66
That is a jdm version 4 sti but also could be the ra version as they used the same ecu. Just search the 22611 ae360 number and that's what you'll find. Should be able to use any version 4 wrx pinout.
Old 05-07-2011, 12:22 PM   #71
mccueauto
Member#: 280952
I have used the every pinout I have found and they all have errors I pulled my harness apart to trace back each thing so I can find what it all goes to. But I still need some of the pin outs so if anyone has any I am up for all that I can get. thanks all
Old 05-20-2011, 08:33 AM   #72
JPN4
Member#: 248084
2003 WRX Wagon
I am writing in here so that I can find this thread again. Thanks
JPN4 is offline   Reply With Quote
Old 08-04-2011, 08:08 AM   #73
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Originally Posted by suberdave
here is an EJ20G i translated while doing my swap
http://www.suberdave.com/subaru/glwr...WiringDiag.pdf
-=Suberdave=-
The page isnt showing up
peanutswagon is offline   Reply With Quote
Old 08-25-2011, 11:52 PM   #74
Mr.Minney
Member#: 214892
1999 Legacy
red
I'm interested in an ej20g wiring diagram and pin outs as well.
Mr.Minney is offline   Reply With Quote
Old 08-30-2011, 11:33 AM   #75
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Pm me
ECU Pinout for Ej18 Ecu... Jdmleggy97 Engine Management & Tuning 0 02-21-2010 09:23 PM
Big question for all GC8 with JDM engine swap specialists V6 Subaru Conversions 6 12-03-2006 08:33 PM
HELP!!! Need a ecu pinout for a 96 L for e-manage install! Sideout Legacy Forum 0 12-01-2005 11:04 PM
Looking for ecu pinout for 97 jdm sti StrongBow Subaru Conversions 1 07-19-2003 10:21 PM
ECU Pinout for 93 Impreza subachad Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-18-2001 10:33 AM
