#1 |
Member#: 35176
Vehicle:1998 2.5 RS Impreza 2000 gray OBX |
So I just bought my STi set up w/ Complete wiring harness, intercooler, airbox, intake, fuel pump, shifter hardware, fuel level sender, fuel controller, ECU, DCCD control unit, radiator, gas petal with TPS, all associated switches relays, fuse box's everything. Complete rear end. YAY!
I’m a little confused about using the DCCD with my 98RS. Since I have the complete harness and switches from the sti, I would assume I have everything required to fit in my car. I have heard there is a complication with using the DCCD with older ABS unit?? Re-wiring of brakes? Will they work with my stock braking system? I’m a n00b with this type of electrical stuff so all suggestions or directions to find info is greatly appreciated.
#2 |
Vendor
Member#: 87569
Vehicle:Once Was Gr8wheels |
You will need dccd g-sensors and mor! Go to the www.Rocketrally.com he has some very cool DCCD ECUs that are easy to install for a great price! It will save you loads of hassle!
Kevin |
#3 |
Member#: 35176
I am getting the complete gauge cluster, switch harness, knob, ecu, and sensors. I just want to make sure there’s no little things to worry about. Anything required besides hooking up the harness to the tranny, and g-sensors? Since it is monitoring my acceleration/braking is there any issues using my ABS system?
#4 |
Member#: 30695
Vehicle:BOOM , Get her to sew THAT! |
I believe you will need the STI ABS system and control unit which sends signals to the DCCD to to provide input for the auto option. I am hooking mine up without the auto option for the time being, but I am keeping all the wiring and sensors in case I want to swap to all STI hubs, ABS system and auto option in the future.
I talked with wrx_driver_2002 about some of the swaps he has performed, and he has kept auto in a Forester, but said it was a bunch of work. I have my hands full with the engine, tranny, cluster for the time being. If you go for it good luck, it is achievable! |
#5 |
Member#: 35176
The guy already sold the hubs w/brakes but still has the ABS control unit for sure. comeplete Sti abs system??
#6 |
Member#: 30695
EDIT:
The STI ABS controller is integrated into the pump. I believe it's all or nothing. Last edited by UTCiv; 01-17-2006 at 03:31 PM. |
#7 |
Member#: 90581
Vehicle:1999 2 door Prodrive rally shell, 450hp. |
I dont have AbS on my GL, so i think i can forget about the auto version and it will have to stay on manual all the time?
Hopefully i can get it working. PS mjd85la, i almost have the same project, but i think you have more components then me, are you going to put up a thread on your project too? greets |
#8 |
Member#: 35176
Dinges, once everything gets started I hope to post a full right up, should be picking up the parts this weekend, or the next....so excited, my car has been in the garage for almost a year now waiting to be reborn!
#9 |
Member#: 43842
Vehicle:200? WRX STI Aspen White |
so no way to have auto mode on a wrx either?
#10 | |
Member#: 3461
South East
Vehicle:1998 BMW M3 Coupe Estoril Bleau |
#11 |
Member#: 25952
NWIC
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
It was alot of work to make the system work. The FXT that we did the 6mt swap in will be featured in Subiesport in the next issue, I believe. It required using the STI Abs Pump, removing the stock porportioning valve (Because the STI porportions electronically through the abs pump instead of mechanically through the porportioning valve) and adding the STI Coupler (on the right front strut tower) Rewiring the ABS System, Rewiring the dash for the STI Cluster, and lengthening all of the wires for the switches / sensors. We had to mount them a little bit different locations. I have pictures of the build process if anyone is interested. We ended up putting the Auto / Manual Switch and the Adjustment Knob in the location where the seat heater switches were in the center colsole. we moved the seat heaters to each side of the center console about where your calf sits when you're in the seat.
#12 | |
Member#: 25952
NWIC
Here's the thread for the Forester: http://forums.nasioc.com/forums/show...t=roundthebend |
| Thread Tools | |
| Display Modes | |
| How to install 04 STi steering wheel on 04 WRX (w/ cruise control) | WRXakaBooSTi | Interior & Exterior Modification | 2 | 06-30-2008 03:23 AM |
| I never learned how to use the shift key with my right hand. | coop119 | Off-Topic | 24 | 11-19-2007 02:48 PM |
| how to upgrade 04 sti to 8000K | nstysti | Electrical & Lighting | 8 | 09-22-2007 09:32 AM |
| how to swap 04 STi motor into 05 WRX? | whateverwrx | Newbies & FAQs | 4 | 05-22-2006 12:48 AM |
| how to install 04 sti foglight covers? | darkjediii | Interior & Exterior Modification | 3 | 03-01-2004 10:24 PM |
