Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-16-2006, 08:29 PM   #1
gmanwrx
Member#: 53871
95 s14 240sx
ruby red
Default will 8.5 fit on an wrx
i have my car lowered, the question is will i rub with 17x 8.5 inch rims? what offset is need if rims are posible????
gmanwrx is offline   Reply With Quote
Old 01-17-2006, 11:05 AM   #2
subieworx
Member#: 47769
Depends on the size tire you want to run. Anywhere in the 44-50 range should work alright if you don't want to run a tire over 245. The wider tire you go the lower the offset needs to be so that you don't rub the strut.
subieworx is offline   Reply With Quote
Old 04-03-2006, 08:33 PM   #3
billy boi
Member#: 19714
.... front cover of
MODIFIED MAG Sept. 2006
hey gary . I have 18x8.5 on my car with 235/40-18 dunlops and theyre fine . your suspension will need to be a little stiff cause if your rear dips real low , then it will rub on the fender . But the wide look is well worth it !
billy
billy boi is offline   Reply With Quote
will 16" rims fit on an 09 wrx CletusTheDwarf Tire & Wheel 1 01-04-2009 02:32 PM
Will 15" steelies fit on an 05 WRX? nicholam Tire & Wheel 4 09-10-2008 07:28 PM
Will 18" subzero's fit on an sti? Depeche Tire & Wheel 5 03-30-2004 12:17 PM
Will Tanabe GF210's fit on an 02 wagon? poison Brakes, Steering & Suspension 4 12-30-2003 12:35 AM
will 8.5 fit the sti?? STI-300 Tire & Wheel 1 09-05-2003 01:52 AM
