Notices
Old 01-16-2006, 09:47 PM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Default EJ20H wiring diagrams. please help
So im in a bind at this point.
Im about to do an EJ20G swap into my GF8. when i bought the engine the harness was so torn up that i had to get a new one. After 2 months of searching for an EJ20G harness with no sucess i ended up buying a EJ20H harness, sense the engines are extreamly similar i figgured i could use the H harness to run the G engine.
Looking closer at the harness i noticed some major diff. between the G and the H harness. So what im going to have to do is take out the old EJ20G engine harness and replace it with the EJ20H. also the wiring harness is a bit diff. also. the colores are diff. and the guages of wires are diff as well.
so this is what im looking for...
EJ20H wiring diagrams from a subaru manual
i know i have posted this up before, but now im just stuck between a rock and a hard place, i found some EJ20H diagrams, but they where hand written/typed and i dont trust the accuracy of them. my engine is ready to go in, and i got everything i need to do the swap. so now im just trying to get the wiring done and ill be boosting.
if someone has these i would greatly apretiate it.
thanks
kirill
snowman4us is offline   Reply With Quote
Old 01-17-2006, 12:19 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
i have a diagram for a 96 97 EJ20G i dont know if that will help any but if it will send me a PM.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 01-17-2006, 12:45 AM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
i got some EJ20G 4 plug ECU diagrams and they are a bit diff then the H harness.
I am a little familiar(sp?) with the G harness, and the H is a bit diff. instead of having all of the engine controls go in one part of the harness like the G, the H splits of and 1/2 the harness goes from ECU to engine and the other 1/2 of the engine plugs run thrue the interior harness before it goes to the engine . i can make it work, i just need to know what wires im plicing and what not. its not hard to figure it out, its just hard to figure it out if you dont know what wires your looking at.
does anyone have an EJ20h wiring diagram yet looptit Subaru Conversions 1 07-28-2006 12:27 PM
does anyone have an EJ20h wiring diagram yet looptit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-28-2006 01:39 AM
Electrical/Blower problem, its not the resistor, wiring diagram please? vica153 Service & Maintenance 14 05-10-2006 02:52 PM
Wiring diagram please subbyspeed Normally Aspirated Powertrain 1 08-07-2005 09:02 AM
I need a JDM 1996 BG5 ej20H wire diagram lotus2843 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-04-2005 10:15 AM
