Old 01-17-2006, 12:05 AM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default How badly do lowering spring screw up the ackerman angles?
I can't seem to find much info on this. How much do aftermarket springs (lowering about 1.0-1.5 inch) affect ackerman?
Will it cause bad scrubbing or unstable turns, etc?
chimchimm5 is offline   Reply With Quote
Old 01-17-2006, 01:45 AM   #2
Mark Avery
Member#: 10313
2002 WRX wagon
I'm not sure what kind of Ackerman angles the Impreza uses, but the kind of lowering you're talking about with proper alignment will not result in an unstable car.
Mark Avery is offline   Reply With Quote
Old 01-17-2006, 02:57 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....springs of that drop don't mess up toe too much, usually....an ALK, which I really like, will alter toe a good bit and require adjustement of toe for a good alignment.
ackerman angle isn't even mentioned in the FSM, AFAIK.
Old 01-17-2006, 08:23 AM   #4
Jim Lewis
Member#: 92551
2005 Saab 9-2X
Doesn't affect Ackerman, affects toe - adjust toe back to zero and you're set.
Jim Lewis is offline   Reply With Quote
how bad does mismatched tires tear up the transmission? bradze Newbies & FAQs 17 10-27-2008 09:09 AM
Curious; how bad is lowering just the front of the car? DANACoOp Brakes, Steering & Suspension 1 09-01-2004 12:10 AM
Lowering an STI, does it screw up the alignment/camber/toe/etc.? Moshpit552 Newbies & FAQs 5 03-04-2004 01:06 PM
NYPD screwed up the ticket. Do I still have to pay? klipschaudio Tri-State Area Forum 8 01-22-2004 05:38 AM
How bad do you want to see the US WRX in person before it arrives at the dealerships will667 General Forum Archive 5 12-09-2000 12:54 AM
