Old 01-17-2006, 10:59 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ257
Brilliant Red
Default Can an MY05 Legacy GT crossmember be used?
Just like the question says can it be used for a swap in to a MY97 impreza?
Thanks,
Joshua
yebokmj is offline   Reply With Quote
Old 01-19-2006, 09:43 PM   #2
yebokmj
Member#: 2213
Brilliant Red
Anyone know?
Joshua
Old 01-19-2006, 09:51 PM   #3
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Sure. Control arms are going to be the big thing though. The rear bushing is totally different.
THAWA is offline   Reply With Quote
Old 01-20-2006, 11:01 AM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i know its differnt enough that- you don't need to jack the engine up on the lgt to get the uppipe out the bottom..
Old 01-20-2006, 01:07 PM   #5
yebokmj
Member#: 2213
Brilliant Red
THAWA,
So you know it will fit I will just have to shim the control arms because of the bushings like you would when using a WRX crossmember? Or were you just guessing?
Thanks,
Joshua
Old 01-20-2006, 02:22 PM   #6
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
well, the issue of shimming is bc they went biggornator. i doubt they would have reduced the size for some weird reason.
im sure it can be made to work, unless its free or very very cheap, why not just do the time tested thing of using the proper part?
what do you have on your L wagon with ej25 now?
swapstar is offline   Reply With Quote
Old 01-20-2006, 02:44 PM   #7
yebokmj
Member#: 2213
Brilliant Red
I currently have an MY97 2.5 from a legacy Lsi that has an old JC Sports turbo kit on it, it's over five years old and showing it's age. Yes the crossmember is free, since is comes from my wife's crashed legacy which I just bought back for a swap. So besides the shimming I don't have to worry about the bolt holes matching up to the frame or anything like that then?
Joshua
Old 01-20-2006, 09:24 PM   #8
THAWA
Member#: 44581
3 Boxers 2 AWD
The bolt holes matching up is what you need to worry about. The rear bushing setup is completely different.
Old 01-20-2006, 09:53 PM   #9
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
the steering rack is also differnt style. for the X member you need to use the new style 05 ish rack (im guessing) that has differnt ujoint than gc8.
Old 01-20-2006, 09:56 PM   #10
yebokmj
Member#: 2213
Brilliant Red
Okay well seeing that I have the whole car, is it possible fore me to use this crossmember? Can I switch the rack over, maybe even the control arms? I don't have a problem getting a new cross member but would prefer not to if I don't need to. Thanks for the input guys.
Joshua
Old 01-21-2006, 05:35 AM   #11
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
youlll have to custom fab a steering u-joint (chop/weld), and deal with sever camber issues from teh widetrack legacy. why not just buy a $100 part and take care of it properly. no ghetto rigging.
Old 01-21-2006, 08:28 AM   #12
yebokmj
Member#: 2213
Brilliant Red
Now knowing this I now plan to purchase the proper part just didn't want to if I didn't have to. Any suggestion on where to pick one up cheap?
Thanks for the help.
Joshua
MY05 Legacy GT Turbo tranny swap solution! yebokmj Subaru Conversions 14 05-23-2006 12:55 PM
Can a MY05 Legacy GT tranny be fitted for mechanical Vehicle Speed Sensor? yebokmj Transmission (AT/MT) & Driveline 2 02-10-2006 10:41 PM
MY05 Legacy GT (56K???) buplew Member's Car Gallery 15 10-28-2005 10:33 AM
MY05 Legacy GT and Ltd. Pricing in Pittsburgh subawang Mid Atlantic Impreza Club -- MAIC 7 04-25-2005 11:24 AM
iON Sport Spec Springs (for MY05 Legacy GT Sedan available shortly... iON Performance Inc Legacy Forum 3 10-28-2004 02:39 AM
Message Board Statistics All times are GMT -4. The time now is 01:55 PM.
