Old 01-17-2006, 11:06 AM   #1
Division By Zero
Member#: 7555
Default Misfires + UTEC + new engine
Recently I built an engine and since it went back in I've got misfires on a nearly regular basis. The misfires happen primarily in lower rpms and most of the time in 1st, then a little less in 2nd, and rarely in 3rd. Never in 4th or 5th Anyway, I've gone over the car and all mounting points are tight for the engine and trans. I was getting a CEL for the cam position sensor so I replaced that. That CEL didn't come back on but I keep getting the misfires in all 4 cyls still. The only other thing is that the front O2 was bent slightly (put it in by accident before dropping the engine in) and so occasionally I get a CEL for slow response from the front O2.
Some other important data to think about. This is the second engine that I built in the last 6 months. The first engine which was nearly identical had the same UTEC, same sensors (crank and knock w/the exception of the new cam sensor), same coil packs etc. It did the same thing too (misfires in all 4 cyls in low gears and rpms). That engine cam out after it suffered a broken rod bearing. The only diff with the UTEC is that it had the 4.2 firmware and is now flashed to ver 5.0.
As for the plugs, it has NGK iridiums range 7 now. On the last engine it had 8's (colder). The maps on the two cars are completely different. I started this one from scratch where the last one I recycled from the previous set up. Either way, both misfire(d) so the maps don't seem to be the culprit. BTW, this UTEC is a toggle version (I think ver 5 IIRC), no dip switches.
Thoughts...ideas what is causing this?
Division By Zero is offline   Reply With Quote
Old 01-17-2006, 11:45 AM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I had misfires when I lost my engine. I did a compression check and #4 was at 70. I put in a new short block and continued to get misfires. Turns out my coil packs were bad. I have always wondered if the coil packs caused my block to go.
LiquidForce is offline   Reply With Quote
Old 01-17-2006, 12:45 PM   #3
AQ Motorsports
Member#: 60836
2006 Mod Class STI
TIMEATTACK!!
Is the car misfiring (you can feel/hear it) or are you just getting misfire codes?
AQ Motorsports is offline   Reply With Quote
Old 01-17-2006, 01:10 PM   #4
Division By Zero
Member#: 7555
LiquidForce,
Is there a way to test coils? Mine seem to be okay as it runs LOL! I hate to just throw money at it without knowing why.
Harman Motive, Inc.,
Well the codes is the only thing I see (flashing CEL via UTEC) and I can't feel it through the car. When the light flashes it's not knock since the UTEC isn't pulling timing. It doesn't show up as knock either when logging.
Would the crank angle sensor be suspect? There hasn't been any codes for that though.
Old 01-17-2006, 03:01 PM   #5
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I too get misfires on all 4 every day or two. It's a 2.5 hybrid with modded injectors. I checked compression and everything was fine. I am also running 7 series plugs (NGK).
TypeC is offline   Reply With Quote
Old 01-17-2006, 03:09 PM   #6
Division By Zero
Member#: 7555
Everyday or two? My thoughts would be first that it might be tuning related but....On mine, we're talking frequency of misfires is many times a day. Not every single time but most of the time in "no" boost and lower rpms at part throttle.
Old 01-17-2006, 03:58 PM   #7
happasaiyan
Member#: 37731
try this-
put key in ignition
turn key to 'on'
wait 5 seconds
start car
this cured my misfire CELs....and i would usually get misfires within the first minute of driving the car (no boost, < 3k rpms).
happasaiyan is offline   Reply With Quote
Old 01-17-2006, 03:59 PM   #8
Division By Zero
Member#: 7555
You mean every time you get in the car?
Old 01-17-2006, 04:02 PM   #9
happasaiyan
Member#: 37731
about every other time....ie- if i ever saw the CEL go away, it would come back the next time i drive the car when cold.
Old 01-17-2006, 05:00 PM   #10
AaronWRX
Member#: 7194
2011 997.2 Turbo
I get misfire codes (only after i installed my fmic) only if all these conditions are met,
-the car has been sitting for 2-3 days
-it's cold out (40 or less)
-It idles for 2-3 minutes (if i just get in and drive it doesnt do it)
sti, stock plugs, walbro, aps fmic, sz55, perrin injectors, typhoon (yeah, no bigmaf)
AaronWRX is offline   Reply With Quote
Old 01-17-2006, 11:06 PM   #11
Division By Zero
Member#: 7555
Update...I was doing a little reading earlier and came across one of those "grounding threads" I always thought those grounding mods were for the guys who put in air filters and lower their cars 'cause it looks or sounds cool. Anyway, I must say that after installing some quality 8G wire that I purchased from Tweeter (and I didn't hit all the points) that it's not as bad. Now it is only doing it in first gear and and only when I get to 3-4k rpms and/or shift. Strange because now it's gone in 2nd gear. Remember, this is no boost and slight throttle when the misfires happen. What the hell is this?...Arggg....
Old 01-18-2006, 09:01 AM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
To determine if it was the coil packs I borrowed some off another wrx. I don't know a good way to bench test them.
Old 01-18-2006, 09:11 AM   #13
VWGrk1
Member#: 57882
2004 WRX
Same problem here. Misfires below 3k rpm under light throttle conditions on all cylinders. Runs great when flooring it. I noticed that if I lightly revved the motor when not in gear, the motor would rev then hesitate for a moment and then continue reving.
The problem was that I was not pulling enough fuel in the 0% column (offset to ECU fueling). I'd suggest looking at your long-term fuel trims. They should be +/- 5%, but mine were at -15%, which means that the ECU was trying to pull alot of fuel to make me idle properly.
Not sure what your exact setup is, but I am stage 4 w/ UTEC and UR 680cc injectors. The other thing to remember is that the UTEC does not compensate for low impedance injectors and their dead time.
VWGrk1 is offline   Reply With Quote
Old 01-18-2006, 10:32 AM   #14
Division By Zero
Member#: 7555
Thanks for the input everyone. I would bet that the fuel trims might play a role in the misfire diagnosis too. I'm kind of at a loss right now until I can grab up another laptop as I'm having to borrow one here and there. Also, I've got modded stock injectors that were cleaned and tested recently when the engine was being assembled. They flow 810cc and the report showed that the spray pattern was fair due to the fact that they had been modded from the original design. Otherwise, they said that it was acceptable but not ideal as the caps being in place.
However, all of this seems weird that it only happened in 1st and 2nd gears but now from adding the extra grounds only in 1st gear!!! Of course that was only driving after I reset the ECU and taking it for a 3 mile test drive. I'll have to see what's happening after a few more miles today to know if the grounds really helped.
Old 01-18-2006, 12:00 PM   #15
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
This is likely your problem.
I too had 0 misfire dtc’s ever on OEM injectors, then immediatly after installing modded stock injectors I get a misfire code every few days now, either individual cylinders or a combination. Everything is running fine and with a professional tune. I inquired with TXS about the issue and was told it’s a pretty common problem when running modded stockers, and is really nothing more than an annoyance…
PS: Mine were flow and spray-pattern tested too, same results...
xcntrk75 is offline   Reply With Quote
Old 01-18-2006, 12:49 PM   #16
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Misfires are common on modded stockers. Its hard to get them to flow right at low RPMs and low load. Its uneven at those levels and creates (in my experience) a rich misfire. I've learned to live with it until I can afford to get properly sized injectors. Uping my idle helped a lot.
cdvma is offline   Reply With Quote
Old 01-18-2006, 12:54 PM   #17
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Same here. Zero misfires on stockers, then it started with the modded ones.
What did you set it to?
Old 01-18-2006, 12:54 PM   #18
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
same here guys, modded stockers and a ton of misfire's. Sucks, but I guess they're worth it for now.
SBW is offline   Reply With Quote
Old 01-18-2006, 02:21 PM   #19
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Boo modded stockers... then again, $650 is a lot to stomach for a "real" set of injectors
Old 01-18-2006, 03:26 PM   #20
bboy
Member#: 56468
04 Improved STI
Dirty White
Is there any evidence that people with PE injectors are having fewer misfires at the same/similar power levels?
Old 01-18-2006, 05:00 PM   #21
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
According to posts here, the PE's don't idle nearly as well.
Old 01-18-2006, 05:11 PM   #22
bboy
Member#: 56468
04 Improved STI
Dirty White
I've heard many PE trouble stories, not just around idling. I'd be rather surprised that removing the screen leads to misfires, but it's possible.
Did the people that switched to mod'd stock injectors and picked up misfires all use UTEC.
I have not had trouble with lean misfires and the Hydra. I do have some rich misfires under boost and I've not worked hard to tune those out.
Old 01-18-2006, 06:09 PM   #23
AaronWRX
Member#: 7194
2011 997.2 Turbo
id like to say that i was fine (no misfires) when i was modded stockers (perrin sti), sz55, typhoon intake, oem tmic.
It wasnt untill I installed the aps dr725 that my afrs started wandering between 14.6-15.2 at idle and the misfires. Before the fmic my idle afrs on the same injectors were a consistent 14.6-14.9.
Old 01-18-2006, 09:22 PM   #24
bboy
Member#: 56468
04 Improved STI
Dirty White
That sounds like a tuning problem.
Old 01-19-2006, 08:58 AM   #25
VWGrk1
Member#: 57882
2004 WRX
Yes, I am running a UTEC, which is a more crude tool with respect to EM and larger injectors. You guys running modded stockers should not be having an issue with injector dead time on a UTEC since the dead time is, well, stock. Other EM can compensate for dead time. We just have to live with it.
You guys might want to search for some threads by RiftsWRX. He, for those who do not know, is a well-respected tuner who has some interesting opinions about modded stockers.
I had my LT fuel trim adjustment scanned last night. It was at -4%, which is at the edge of acceptable. I could lean them out a bit more, but you are better off slightly negative than slightly positive, they say. My misfire/hesitation problem is severely reduced now to the point where it rarely happens. Not sure if this will change with the temperature, though. Just remember, tune your 0% fuel column by LT Fuel trim adjustment, not AFR. The adjustment represents what you ECU is trying to do to get things at the proper AFR.
P0303 Misfire Needs New Engine? Please Advise!! rfasman Newbies & FAQs 35 03-29-2009 07:29 PM
Misfire on hybrid engine Splinter Built Motor Discussion 0 08-11-2008 01:27 AM
Weird misfire after new shortblock?!!?! drifmtaster04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-26-2008 04:07 PM
New engine, cyl misfires, and Knock! Division By Zero Engine Management & Tuning 34 07-29-2005 10:00 PM
UTEC damage engine? any UTEC Gurus out there amorton Engine Management & Tuning 1 01-10-2005 10:20 AM
