#1 |
Member#: 25047
Vehicle:2001 Impreza RS Coup Silverthorn Metallic |
yeah im doing a swap and was wondering if anyone could tell me what kinds of problems i might have doing this, heres what i got....
04' STI complete engine with turbo and intercooler, 6-speed tranny, complete wiring harness with ECU, front axels, drive shaft, rear diff, engine mounts, and tranny mounts. one of the things im concerned about is if the 01 RS clutch and lightweight flywheel will fit in the new 6-speed set up. im assuming i'll need new ones, can someone confirm this? thanks chris
#2 |
Member#: 16274
Vehicle:2001 GM6 2.0L vf30 e30 black/rust |
you need the 6 speed clutch setup.
#3 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
did you get the rear hubs+brakes
the rear axels are differnt other wise there is a place that will custom make r160/r180 axels |
#4 |
Member#: 25047
i just got the rear diff, i don't have the hubs or axels. am i gonna need hubs for the front? do you know where i could get those and for the rear?
#5 |
Member#: 25047
alright ive been reading similar threads and came up with a few more questions....
1. since im putting in an 04' do i need a new radiator? 2. i have the stock brake system so my DCCD won't work right? im not even sure if i got the g sensors or the actual controller switch ( is the controller switch just a switch the wiring hooks up to? can i subsitute with some other switch?) 3. i don't have the 04' rear hubs and rear axels, so is it possible to custom fit the stock 01' axels to the 04' diff? or with that not hold to well? 4. i now know i need a new clutch and flywheel, is there anything else i might need to make all this work? thanks chris |
#6 |
Member#: 177
NWIC
0 front rs axels will be fine
1 no you can use the rs radiator making the sti radiator fit is some work 2 correct look at the other dccd thread in conversions to lazy to link 3 you will need custom drive shafts i wanna say (drive shop sevice is the name of the companyi think) -ask this question the the tranny forum 4 as far as big things go .. no little things yup |
#7 |
Member#: 35176
Vehicle:1998 2.5 RS Impreza 2000 gray OBX |
imbaru25rs, i just got the exact same set up but i have the rear subframe w/ axles. Im missing the hubs as well. Are you installing this your self or a shop? good luck on ur swap. Im pretty sure the dccd will not work with out the complete harness into the tranny, and the matching abs unit. from what i have read you will be stuck in 35/65 with out the complete system.
#8 |
Member#: 25047
yeah its going into a shop thats gonna make custom rear axels for me, i have the complete harness just not the ABS system, or the g-sensors. which im not gonna mind having 35/65 since i drive it in the summer only. and i will do suspension and brakes at a later date. the swap is gonna start tomarrow so thank you guys for all your help and ill let ya all know how it goes and post some pics if i can!
chris |
#9 |
Member#: 96664
RMIC
Vehicle:V5 STI RA |
did you get a turbo crossmember, in not yor need one!!!
#10 |
Member#: 35176
i will be using the sti X-member
#11 |
Member#: 1391
E. Canada
Vehicle:1997 GF - silent ed. 12.677@107.87 untuned |
Here's some eye candy for you
http://www.rs25.com/forums/showthread.php?t=40811 |
#12 |
Member#: 35176
yeah, I saw this yesterday... cant wait... the way it should have came from the factory..
#13 | |
Member#: 30695
Vehicle:BOOM , Get her to sew THAT! |
I'm doing this currently. Last edited by UTCiv; 01-19-2006 at 11:34 PM. |
| Thread Tools | |
| Display Modes | |
| 05 STi into an 02 RS... Should i or should i Not... | ScubyMedic | Subaru Conversions | 13 | 04-28-2007 12:03 AM |
| JDM sti into USDM 2001 2.5rs HELP! | K6DimE | Factory 2.0L Turbo Powertrain | 1 | 05-23-2006 08:42 AM |
| problems with 04' sti into an 01' RS help! | Imbaru25rs | Subaru Conversions | 7 | 02-18-2006 02:40 AM |
| WRX radio into a 2001 RS? | prelude/2.5rs | Car Audio, Video & Security | 3 | 03-26-2002 03:14 PM |
