#1 |
Member#: 97987
South East
Vehicle:The Wagon shaped paper weight |
I just got the car back together, and now it seems to run rich. I noticed that the car is turning around 11.5:1 AFR at 20% throttle. The car has a stutter when you go over that point. I need to see if anyone has a good MAP for the 2.5L swap with WRX heads.
#2 |
Member#: 4980
As I told you on the phone, the map is not really that different. We tuned a car with a 2.0L and an 18G. A few weeks later the customer decided that he wanted a 2.5L. The car came back to us with a 2.5L, same heads and the same turbo. The AFR of the map didn’t change a bunch between the two different short blocks. We had to make some adjustments to get the most out of the 2.5L block, but the car actually ran fine on the old map.
Your problem sounds like something mechanical. -Nathan www.turboxs.com |
#3 | |
Member#: 60324
did you try leaning it out? |
#4 | |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
I'm tuned a UTEC map for my 2L setup with PE800 injectors and a GT30R. I have now swapped in a 2.5L block with heads and am able to run almost the exact same map. I had to add a little fuel in places but mostly it ran just fine. Sounds like you have a mechnical issue. Maybe you are not running on all 4? Post turbo leak? |
#5 | |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
The fuel map was fine though. The main problems (besides the timing) was that the 2.5 was reaching higher load, low rpm sites that the 2L can never hit. But that's my experience, YMMV. And to the original poster, PM me your email and I'll gladly send you my street map (EJ257, WRX heads, VF39, 770 injectors). It should at least be a starting point. |
#6 | |
Member#: 4980
Sounds like you have other problems. You shouldn't have to take more then 2 degrees out anywhere other then the mid-range where you might need another degree. 10 degrees of additional retard over the stg4 base map would put you at 15-11 degrees at 7000rpms. -Nathan |
#7 |
Member#: 19346
Vehicle:2003 MBP WRX Wiseco / Oliver EJ257 |
Isn't all this really dependent on CR? One person's results being different could originate from different headgaskets or someone decking the heads, etc....
#8 |
Member#: 4980
I seriously doubt anyone is running any significant boost on a higher compression motor then the one we have built for our shop car, and even that one at insane power levels for pump gas doesn't require that much timing retard.
Although there is a common mistake when people make the swap that could cause all sorts of issues with knock retard. The WRX UTEC’s knock thresholds are not calibrated to the STI short block. If you run the WRX thresholds, you’ll have some false knock issues. |
#9 | |
Member#: 7555
South East
Sooooo......what do you recommend? I've got mine at 3 (vs 2 IIRC which was the WRX UTEC param). I also decreased the values for rpm sensitivity. What's the solution? |
#10 |
Member#: 19346
+1 Natahn please fill us in. I just swapped in a crawford S3L and I'd love to know how I shoudl set the calibration...
#11 | |
Member#: 4980
For an STI short-block, you should use STI sensitivity settings. Beyond that, you’ll have to attempt to calibrate the sensitivity on your own. |
#12 |
Member#: 97987
South East
Ok so here is what I found. No Vac or boost leaks, which I new already because I went over those about ten times before I finished the install. I did pull one of the TGV Sensors off during the teardown, and when I reinstalled it, putting everything back together I did not preload the spring in it. Thus throwing the TGV code and sending the ECU into Limp mode. Just like that the problem is solved. The car runs great, although I have not seen any high RPM load points yet since I am still breaking in the new motor. I just got the car back together on Sunday, so I still have a while. I still want to see someones 2.5L Map(s), so I can see what they look like verses my modified stage four map. I have no doubt they are close, but I would like to see what others have done with their tunes.
#13 | |
Member#: 7555
South East
Nathan, Thanks but more specifically, are you speaking of the rpm sensitivity areas or the threshold or both? Can you clarify? Todd |
#14 | |
Member#: 4980
-Nathan |
#15 |
Member#: 97987
South East
So what should the Sesitivity be at when running the STI block?
#16 | ||
Member#: 9794
TXIC
![]() Quote:
#17 | |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2009 BMW X5 |
#18 | |
Member#: 4980
Ignition timing should almost never flatten out like that unless for some reason your motor's VE is increasing as you approach redline. Given what I know about Subaru motors, I seriously doubt that's happening in your case. As for your knock thresholds, it looks like your sensitivity may be too high, but I frankly haven’t looked at your thread too closely. |
#19 |
Member#: 38469
NESIC
Vehicle:07 LGT spec-b Crystal Grey Metallic |
is the only real way to determine knock thresholds with the use of det cans and headphones?
#20 | |
Member#: 9794
TXIC
The STi thresholds are MUCH lower than that of the WRX (STi is 60 vs 80 at the last data point). I wonder if it's just a noisier engine. |
#21 | |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
| Thread Tools | |
| Display Modes | |
| Dyno Tune: Motion Lab Tuning Makes 264whp On A '02 WRX TD04 + 2.5L w/STi Cams | Motion Lab Tuning | Proven Power Bragging | 7 | 02-09-2010 06:17 PM |
| UTEC tuning with AC on... | lowblow | Engine Management & Tuning | 4 | 05-12-2005 12:27 PM |
| UTEC Tuning with Tuner Pro | manman99 | Engine Management & Tuning | 7 | 05-09-2005 11:15 AM |
| Utec tuning with Tuner or Tuner Pro | manman99 | Engine Management & Tuning | 4 | 05-09-2005 10:44 AM |
| UTEC tuning with PDA what do I need? | Davenow | Engine Management & Tuning | 5 | 02-19-2003 12:52 AM |
