Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 01-17-2006, 01:23 PM   #1
fzturbo
Member#: 43482
2004 JDM 2 litre STI
Default Wich turbo for 400 WHP on 91 octane Gas
A friend wants like 400 WHP on 91 octane gas, setup will be with a Blitz FMIC, inyectors, stock ECU, Apexi S-AFC2 and AVC-R, gruppe s manifold and a 3" TBE. Wich turbo can do this. Someone mentioned me the SZ55 or the Forced Performance turbos.
Any idea???
Thanks.
fzturbo is offline   Reply With Quote
Old 01-17-2006, 01:37 PM   #2
pezman04wrx
Member#: 66558
How about you tell us at least what kind of car it is? ... Regardless of whether or not it's an STi (and it had better be ) 400whp and 91 octane doesn't compute in the suby world ...
Edit: I have seen a number of STi's with to 400whp on 93 octane, but they usually also have meth/water/alky injection of some sort ... 20g (style) turbo's would be the way to go ...
pezman04wrx is offline   Reply With Quote
Old 01-17-2006, 01:38 PM   #3
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Why is your friend running an afc2 and avcr combo? A tuned ecu will net more hp safer. Tell your friend that he will get no where close to 400 whp short of a rotated 35r set-up...ESPECIALLY with insufficient tuning capabilities of the afc/avcr combo.
Tell your friend to start off with selling the afc. If he is in a wrx with a stock drive line. Tell him he need to save up for 2.5 sti short block. If he wants to hold 400 whp daily for at least 10k miles he should seriously consider swapping in some forged pistons into the sti short block. Then tell him to save up for a rotated gt-35r set-up. (While he is at it, he is going to at least need some r/a gears for the tranny, he would be better off buying an sti transmission...the stock box is a ticking time bomb with that kind of power.). If your friend doesn't mind running some meth injection...an sz55 should get you fairly close to 400whp. I dont know how well the stock wrx head flows, so he might need some porting, valve work, and quite possibly some cams. Basically if your friend has a wrx, he needs to sell it and get an sti.
Once your friend has assembled all the necessities... he needs to buy ecutek, utec, cobb ap, or a hydra...these are all top notch engine management solutions. He then needs to take his car to a tuner who can tune one of the above to custom tune it for him.
If its an sti, an sz55 with some meth should be all that you need to. The stock pistons should last a decent while if your tuner is worth a damn.
Swine is offline   Reply With Quote
Old 01-17-2006, 02:08 PM   #4
STiLL WILL
Member#: 37581
2004 SZ55'd STi
375whp on 91/404whp on 95
I run an SZ55 on an STi...and I can almost assure you there is NO WAY not even on the higher reading DynoJet dyno's you will be able to hit 400whp on pump 91 with an SZ55. On 91, I was tuned to 375whp on Harman's DynoJet in Torrance with an SZ55, but I honestly wouldn't push it past that level just to hit 400whp with an SZ55 on 91. You will need some kind of water/alcohol/meth injection system to hit that with pump gas---but even then you are raising the octane when you inject something.
...but I have seen 400whp+ on pump 91 on STi's running SZ65's and FPRed's. Remember, it's all in the tuning. A SURE SHOT way to hit over the 400whp on 91 is with a GT35R. My buddy BlingusKahn also is running an FP Red with a pretty built motor in his STi---you should PM him as well. Here's a link to a stock block STi running a GT35R tuned at Harman that hit 425whp on 91:
http://www.harmanmotive.com/Images/g...haseGT35R.html
If your friend has a WRX, he needs to swap out the shortblock for a 2.5L USDM STi shortblock.
I guess what it all comes down to is---
THere are PLENTY ways your friend can hit 400whp on 91 octane, it all depends on how much your friend is willing to spend. The combinations are endless....he just needs to figure out HOW he wants to go about getting to that 400whp mark. Again, tuning is key. Make sure your friend goes to a tuner who doesn't just hit numbers to make you happy---make sure the car is "happy" as well. I've seen too many cars fail from unexperienced tuners who just "hit the numbers" and forget about everything else(driveability, safety, etc...). I can assure you, most of the reputable tuners you will find here on NASIOC will do their best to make sure your friend will get a thorough tune.
-Matt
STiLL WILL is online now   Reply With Quote
Old 01-17-2006, 02:17 PM   #5
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
^ If he drives a wrx, he can scratch out the shortblock, he needs the long block unless he is willing to pay to get the heads built.
the_colombian is offline   Reply With Quote
Old 01-17-2006, 02:59 PM   #6
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.7 @ 102, '09 spec.B
WRX + EJ207 (~$3000) + PPG gearbox (~$5000-6000) + SZ65 or FPRed (~$1600) + miscelaneous (~$2000-3000) = relatively reliable 400whp (~$11,600-$13,600).
Just a ballpark figure.
def
dug-e-fresh is offline   Reply With Quote
Old 01-17-2006, 03:02 PM   #7
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Is it me or is this the wrong section for this question?
fastwrx006 is offline   Reply With Quote
Old 01-17-2006, 04:36 PM   #8
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
yes on the wrong section..the only way you'd see 400whp on 91 pump or I should say easiest way is with water/alky injection.
IMPORTIMAGE is online now   Reply With Quote
Old 01-17-2006, 04:54 PM   #9
powerleak
Member#: 72571
04 STI
^^^^^ ditto to the above.
sz60 here with 400whp and alky injection
powerleak is offline   Reply With Quote
Old 01-17-2006, 05:01 PM   #10
MARKGSTI
Member#: 70197
I would do a SZ or a FP RED or 3 inch green along with meth/alky.
MARKGSTI is offline   Reply With Quote
Old 01-17-2006, 05:05 PM   #11
MARKGSTI
Member#: 70197
[quote=pezman04wrx
Edit: I have seen a number of STi's with to 400whp on 93 octane, but they usually also have meth/water/alky injection of some sort ... 20g (style) turbo's would be the way to go ...[/QUOTE]
20G TO SMALL IMHO...
Old 01-17-2006, 05:05 PM   #12
Newbie Subie
Member#: 20214
07 Acura RDX
390WHP no more
Newbie Subie is offline   Reply With Quote
Old 01-17-2006, 05:12 PM   #13
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
Impreza WRX STi
def
you forgot a bunch of stuff that would bump you up a little bit....
BREWPUBEAVER is offline   Reply With Quote
Old 01-17-2006, 05:14 PM   #14
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
It basically comes back to a harsh reality that he should buy an sti(if he doesnt have one).
Old 01-17-2006, 05:28 PM   #15
Gregar
Member#: 50472
2004 STi
Did 415 WHP on an AVO 500 (non rotated), but that was with 93 octane
Gregar is offline   Reply With Quote
Old 01-17-2006, 07:06 PM   #16
fzturbo
Member#: 43482
i'm really sorry , its a JDM MY04 2 litre STI. BTW, is safe the water inyection???? and how effective is for this cars.
Wouldn't be too big a GT35R for a 2 litre engine??? i mean, a 4500 to 5000 RPM fullboost would be fine, the car revs up to 7500
thanks
Old 01-17-2006, 07:19 PM   #17
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Well that most certainly changes things...quite a bit.
Well, all things considering. An sz55 is the minimum he needs to go for 400whp...and meth or alky injection is a must to get anywhere near that number. His best bet by FAR is get a rotated turbo kit and a gt35r...although it is going to take a while for it to spool(I would say between 4500-5000rpm.).
I though the jdm motors revved to 8k?
Meth injection is very safe. A decent tune with meth makeing 400whp is more safe then the same car tuned to 360whp with no meth.
Old 01-17-2006, 07:41 PM   #18
fzturbo
Member#: 43482
JDM's here (Chile,south america) rev up to 7500 on STI's and 7000 on WRX's. Where can i get a meth inyection, or are there some DIY systems???
BTW, whats the difference in the water/meth/alky inyections?? do all of them do the same???
thanks.
Old 01-17-2006, 08:02 PM   #19
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
It seems meth gives you a few more ponies, but is more expensive and harder to source(around $2 a gallon).
I would personally go with a 50/50 mix of water and alcohal(rubbing alcohal, can pretty much find it anywhere). It seems to give 90% of the performance for a fraction of the cost.
http://gruppe-s.com/Subaru/subeng.htm ...click the link. Find the smc alcohal injection kit under Fuel System. That seems to be a decent kit.
Old 01-17-2006, 10:49 PM   #20
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
Port and Polished Td04
mrubino83 is offline   Reply With Quote
Old 01-18-2006, 02:44 AM   #21
fzturbo
Member#: 43482
are you kidding me???
no further comments.
Old 01-18-2006, 03:48 AM   #22
norris639
Member#: 93489
2004 WRB STi
DR65'd 415whp
Made 415whp on my DR65
This isn't the 415 run but it will give you a good idea
norris639 is offline   Reply With Quote
Old 01-18-2006, 09:14 AM   #23
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
That dr65 would probably be way to laggy for the 2.0lt. Especially with it only reving to 7500.
Old 01-18-2006, 12:13 PM   #24
fzturbo
Member#: 43482
well, please consider when you're posting that this is a 2 litre STI and a big WHP 2.5 setup would be way to big for this one.
One more thing, i was wrong on something, pump gas for me would be 93 octane. (here equivalent to the 97 octane gas)
Thanks, keep replys comin'
Old 01-18-2006, 12:35 PM   #25
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
like?
def
Ideal IWG turbo for 350-375whp on 91 pump no meth? zanderspeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-07-2007 11:36 PM
Crawford Performance CP35R and Stock Block: 433 whp on 91 Octane Crawford/I-Speed Proven Power Bragging 72 06-22-2006 09:15 PM
Max WHP for 2.5 STI on 91 Octane w/ mods and tune NewSuby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 05-23-2006 03:16 PM
349 WHP On 91 Octane: Is this the highest on Pump Gas? Phatron Proven Power Bragging 27 02-12-2004 07:03 PM
Does the Sti run ok on 91 octane gas? edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-27-2003 11:23 AM
