Old 01-17-2006, 02:37 PM   #1
alfabc
Member#: 14735
Default Stock 16's and 225 50 16 tires
Well, I need new tires. Again. I had some Yoko ES100's and ruined them at the track. I crawled home with the cords showing on one tire. I have put the old original tires back on and want to upgrade. I am not buying new rims, and I want to go to a wider tire, but safely. I am looking at some Falken 512's or similar, in a 225/50/16. According to one web site that sells these tires, the minimum rim width is 6 inches, max is 8 inches. I should be o.k., right? Any feedback greatly appreciated.
TIA,
Bill in Los Angeles area
alfabc is offline   Reply With Quote
Old 01-17-2006, 02:49 PM   #2
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
Yeah, you should to be okay with 225/50R16 -- at least that's what I've been assured since I'll be buying new tired later this year.
One thought, though: if you intend to track your car, then you'll probably need something better than the Falken Ziex Ze 512s, which are all-seasons. From what I know of LA, you can probably get by with a good set of summer tires, unless you're taking trips to the mountains for skiing. Optimally, you would want a set of wheels and tires for the street and a set for the track. (But you said you are staying with one set of wheels.) The gurus here ought to be able to recommend to you a good tire for both street and track use.
(Edit: Corrected a blatant spelling/grammar mistake.)
thorongil is offline   Reply With Quote
Old 01-17-2006, 03:08 PM   #3
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
You'll be fine, the OEM wheels are 6.5" wide.
Though if you want to track your car on a regular basis, a second set of wheels & tires is highly recommended.
FS: RS 16x7 wheels and Falken 225/50/16 tires WRX_936 Wheels/Tires 15 11-15-2008 11:57 PM
WTB: 16" Tires for Stock Wheels or 2- 225/50/16 tires G Langa Tri-State Area Private Classifieds 2 09-16-2008 12:09 AM
Stock Rim with 225/50/16 tire ronan1975 Tire & Wheel 11 10-18-2004 06:51 PM
205/55/16 or 225/50/16 tires Pengo Private 'Wanted' Classifieds 10 12-02-2003 09:47 AM
Anyone have a photo of stock wheels and 225/ 45-16 tires? mpaone Brakes, Steering & Suspension 27 12-22-2000 06:29 AM
