Old 01-17-2006, 04:55 PM   #1
LoganG1K
Member#: 78618
Default my bad luck
I ordered a set of the Enkei RP02's from edge racing bundled with Falken 451 tires. They are going to be my summer set of wheels and I am going to use the stockers for winter. I have been applying Mequires #20 polymer sealant to help protect them from brake dust and the dust from my gravel road. Today I was polishing the wax residue off and I lightly pushed one wheel away to start on the next. The wheel I lightly pushed rolls slowly across the garage floor hits a large socket and tips over face first onto the floor. I freak out thinking I just scratched my wheel. I hear air rushing out of the tire. I pick the wheel and tire up and there is one of the old style metal oil cans/dispensers stuck into the sidewall of the brand new, never touched the pavement, tire. The oil can was one of those that you click on the bottom end to dispense the oil out of a long pointy end on the top. I assume that there is no way to save this tire right? It is a rather small hole in the middle of the side wall. When I pulled the oil can out of the tire the now pressurized oil can spewed oil all over the freshly waxed wheel and every thing else in that area of the garage. I am worried that even if I were to get the tire patched the oil that might have gotten into the tire will cause the tire to fail prematurely because of dry rot. Is this a possibility?
LoganG1K is offline   Reply With Quote
Old 01-17-2006, 05:35 PM   #2
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I don't think you can repair holes in the sidewall properly.
waktasz is offline   Reply With Quote
Old 01-17-2006, 05:38 PM   #3
Tire Rack Moderator
Member#: 1215
ext. 4362
no repair for that type of damage
Old 01-17-2006, 06:08 PM   #4
LoganG1K
Member#: 78618
I was hoping, since it was such a small hole, it would be able to be repaired. Why is a hole in the tread repairable but a hole in the side wall is not?
Old 01-18-2006, 05:01 PM   #5
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
Sidewalls do not have as much reinforcement as the tread and are also subject to folding in corners which would probably shoot a plug across the road. This is the same reason you often cannot plug a hole close to the edge of the tread. The edges get subjected to high cornering loads and could spit the plug out in a tight corner.
Pete Holt is offline   Reply With Quote
Old 01-18-2006, 07:32 PM   #6
LoganG1K
Member#: 78618
Is there anything that I can do with this tire? Is it just a big black paper weight? I'd hate to think that one mishap cost me a brand new tire. I have already ordered the new tire.
Old 01-18-2006, 08:50 PM   #7
drift_king
Member#: 83669
1992 Impreza
Green
Throw them in the dumpster and get some new onez!
Then sheet all over your hands
drift_king is offline   Reply With Quote
Old 01-19-2006, 12:29 AM   #8
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Go to a local discount tire and buy certificates for the tires, they'll cover you in situations like that.
BlkTS02 is offline   Reply With Quote
Old 01-19-2006, 10:45 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...are you the same troll that runs 22psi???
My Bad Luck SlidewaySTI Newbies & FAQs 4 07-24-2008 11:21 PM
my bad luck returns! 20Sti05 Mid Atlantic Impreza Club -- MAIC 22 03-06-2006 09:31 AM
First time out+Last night of racing=My bad luck theJohnson Proven Power Bragging 24 12-16-2003 11:58 PM
My bad luck continues... KKoepp31 Mid West Subaru Owners Club Forum -- MWSOC 12 01-11-2003 06:04 PM
