Old 01-17-2006, 05:22 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Fuel pump relay related swap problem
First off, this car has run before, but no while I was the owner of it.
When I turn the key to ON, I'm not hearing the fuel pump relay or pump. When I give ground to the fuel pump relay wire from the ECU, the relay clicks and the pump stays on. I'm gonna check the car for the fuel pump controller, but I don't think the EJ20G had one. The relay is good. That ground wire for the relay doesn't have any ground though. So where is the problem?
Brent
scoobyimprza is offline   Reply With Quote
Old 01-17-2006, 08:02 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
sounds like the ground wire lost its ground somewhere, or maybe a soldering connection broke from when the swap was done.. could be a number of things. You could just run a whole new wire from the relay to the ecu, instead of trying to trace it through a harness..
And i do not believe the G's had a FPC, just the usdm wrx's. I could be wrong
subbyspeed is offline   Reply With Quote
Old 01-17-2006, 08:30 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Is it the wire from the ECU to the fuel pump relay? I think the wire is fine because I touch a ground wire to it and the relay clicks and the fuel pump comes on, but it stays on.
Old 01-17-2006, 09:09 PM   #4
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
That seems weird that the ECU would not be grounding the signal wire. Make sure that your "ignition switch" (B95 12) has 12V when the key is in the "on" position, I usually just hook it up to the "main power" wires. Also double check to make sure that the Grounds (B43 21, B44 24, B44 25, B44 15, B44 14, B43 11, B43 22) are grounded. You may just want to check the back up power(B43 15) while you are in there.
Let me know if you have any other questions
Hope this helps
Rick
scoobydorift is offline   Reply With Quote
Old 01-19-2006, 01:50 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Okay, so I'm not getting ground on B43 21. It's a sensor ground, but I can't find it on the ground distribution of my EJ20G diagrams, so I'm searching the whole thing. Any idea where that ground is?
Old 01-19-2006, 02:02 PM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I found it, here's a picture.
It runs to the pressure sensor by the intake and also to the engine wiring harness (B3) and then to the coolant temperature sensor. Now to troubleshoot.
Old 01-19-2006, 02:47 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I grounded that wire and it didn't help at all.
Old 01-19-2006, 03:14 PM   #8
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
but you checked all the ECU power, back up power, and ignition switch wires?
does your CEL come on with the ignition to ON? (should..)
Natoe is offline   Reply With Quote
Old 01-19-2006, 05:16 PM   #9
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
No, the CEL doesn't come on.
Old 01-19-2006, 06:45 PM   #10
Natoe
Member#: 90353
ah HA, that means that your ECU isnt getting power , so it CANT turn the fuel pump relay on. are you SURe that the ignition switch is connected? also check the 'self shutoff control'. if you KNOW ignition is hooked up and it all has power its most likely the self shutoff.... i had this problem, i had to put a diode between the ignition wire and self shutoff for it to work right. but you can try just tapping the self shutoff directly into a 12v ignition source (ignition switch).
when the accesories are on, the CEL should come on with the fuel pump. lemme know if this works, did on mine.
if its not that and your ECU DOES have power, then check the CEL maybe?
Old 01-20-2006, 09:33 AM   #11
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Hmmm, I'm pretty sure I'm getting power, but when I was fooling around with stuff a couple days ago the fuel pump was coming on when I had it on ACC. I'll check to see if the CEL is coming on.
Old 01-20-2006, 02:34 PM   #12
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Dude, I love you forever.
That's what it was. That wire had no power.
The wire right next to it is cut though. It's the purge control solenoid. My wiring diagrams say it's a WL wire, but on my ECU, its YG. I can't find where it was cut from. Where is the PCS? Diagrams say it has a blue connector and it's near the TPS.
Old 01-20-2006, 03:36 PM   #13
Natoe
Member#: 90353
so it was the self shutoff huh? sweet.
the purge solenoid valve is normally somewhere under the intake manifold on the passenger side. should have a vacuum line from the throttle body going to it, as well as a harness connector. im not sure about what color itd be, my swap was a different engine and ECU and all. (im using my 1.8L purge solenoid though, im 98% sure they are all the same)
so what did you have to do to the self shutoff for it to work?
Old 01-20-2006, 04:16 PM   #14
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I looked a little harder and I don't have a purge solenoid valve, so I don't have to worry about it.
I just hooked a 12v wire to it and it worked. I'm looking for a diode to put in there now. Where did you get yours? I can't find any on my harness that I'm not using.
Old 01-20-2006, 04:35 PM   #15
Natoe
Member#: 90353
i got a diode from radioshack, one that can handle a couple amps, i forget the part number, if you really need it i can look it up for you though.
puttin the diode in will make it so the self shutoff can still work properly.
Old 01-20-2006, 04:52 PM   #16
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Yeah, I noticed that everything stayed on.
I looked on Radio Shacks website and there diodes seemed more like home audio diodes. If it's not too much trouble, the part number would be great!
Old 01-20-2006, 07:01 PM   #17
Natoe
Member#: 90353
direct quote from the genius vrg3 at legacycentral.org:
"Get a power diode that can handle a few amps (like maybe the 1N5402 or 1N5404 that Radio Shack sells). Splice the cathode (the end with the stripe) into the self-shutoff control wire. Splice the anode (the other end) into an ignition-switched +12v source. "
this was for the legacy turbo, but im sure the function for the self shutoff is the same! hope this helps.
im not sure if i got one of those parts exactly, just one that could handle like 3 amps and it works. but yeah
good luck
Old 01-20-2006, 07:05 PM   #18
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Cool, I got one good for 3 amps.
need fuel pump and fuel pump relay 4/18/10 raceckr MWSOC Private Classifieds 1 04-18-2010 03:05 AM
Fuel pump controller related problems kromHASaWRX Subaru Conversions 4 01-06-2010 10:25 PM
EJ22 Swap - No Spark... no ground for fuel pump relay?? Subarutex Subaru Conversions 5 01-22-2007 12:14 PM
fuel pump relay problem ?? subaru'd_by_marriage 'Old School' Subaru Forum 4 06-11-2004 12:54 AM
Location of fuel pump relay? Car starting problems Max Umbarger Service & Maintenance 2 02-23-2003 08:55 PM
