Old 01-17-2006, 06:28 PM   #1
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Question KYB AGX's on 99 Legacy
This topic applies to Legacy owners who have put Impreza AGX's on there legacies.
I was curious if anyone who has done this mod remembers if there were washers on the front suspension pieces. I'm particulary refering to the spacer washers that is supposed to go in between the top part of the spring and the strut mount (factory part by diagram via the dealer).
I recently had a friend put these AGX's on my legacy for me and I have been having spring noises for a few weeks. I folded and took it to the guys at smart service and they suspect I missed putting the spacer washer on my front struts and that is causing my trouble. ANyone else remember these spacer washers on theirs... Neither I or my friend remember seeing them...I got some for dealer and they are rather large...woudl think we couldn't miss something like this but I suppose things can happen. Especially with my luck not being so good lately.
Anyone else forget to do this before on theirs? If so if you could describe how your car reacted that would be great. Not sure if I will hear anythign back on this or not but I figured I would try since I am bothering my friend again to take these boys off and check and I wanted to be 100% this third time through that I check everything when we are there.
My car is a 1999 Legacy L Sedan just FYI
Kcwiro is offline   Reply With Quote
Old 01-17-2006, 07:02 PM   #2
cadillacklos
Member#: 103049
2003 Wrx Impreza
You may need rubber isolators. I have kyb's on my wrx and have the same problem I was asking everyone but after calling the previous owner found this out. If you check out the universal section at energy suspensions youll find all the info you need. I'm not saying this is your exact problem but its a good place to start.
cadillacklos is offline   Reply With Quote
Old 01-18-2006, 08:59 PM   #3
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
thanks I will check that section out...
Anyone else...any thoughts?
Old 01-18-2006, 10:16 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Legacy Forum?
Old 01-24-2006, 10:52 PM   #5
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
I figured this spot might get more notice... sorry pat... perhaps should have put it there... I read your headlight guide (interesting) you put AGX's on your Legacy and remember this spacer I speak of?
Old 01-25-2006, 10:34 AM   #6
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I forgot to put those washers in once when doing the AGXs on my 97 Impreza. It was immediately noticeable as memory steer. The wheel would not return to centre after going around a corner. The same happens to a lesser extent if the washer is upside down.
linsavy is offline   Reply With Quote
Old 01-25-2006, 01:01 PM   #7
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Talking
Wow! ... linsavy you get good marks with that comment. You nailed the issue I'm having with my steering dead on without me even saying what is happening on mine. I used the kit for the 93-01 impreza on my legacy.
I was hoping to get a comment on my exact issue and you delivered. Thank you
What side is 'upside down' on this spacer? Given I likelty don't have a referance on my car ATM
Old 01-25-2006, 03:27 PM   #8
linsavy
Member#: 11620
Pointy side should be up.
Old 04-25-2006, 09:06 PM   #9
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
Cool
Case Closed BTW....
The washer was on but not in the proper spot... lesson learned... ALWAYS have a diagram because pictures always help
Old 12-10-2009, 01:39 AM   #10
Kcwiro
Member#: 57366
1999 Legacy-Sleeper
Burgandy
years later and 45k on these and the stiffer springs no problems and suspension is still very nice.
Fitment Issue: KYB AGX's on a 2004 WRX BiglTFP Brakes, Steering & Suspension 16 04-29-2004 10:59 AM
WRX 02+ KYB AGX's on Forester XT? mgenti Brakes, Steering & Suspension 2 04-06-2004 12:36 PM
GC8 KYB AGX's on WRX Mr. Mercado Brakes, Steering & Suspension 4 11-29-2003 12:29 AM
What spring will be my best match for KYB/AGX's on a GC8? Robmat Brakes, Steering & Suspension 10 07-10-2002 12:08 PM
Do the KYB/AGX's fit the Legacy turbo's(along with other parts). MPREZYA Legacy Forum 8 08-09-2000 10:16 PM
