Old 01-17-2006, 06:32 PM   #1
JDM Importers
Vendor
Member#: 87569
Once Was Gr8wheels
Default Coil pak question need help fast!
Long story short My friend blew up his sandrail motor with a old ej20
He is swaping a long block from a 01 JDM ej20.
The coils from the old ej20 will not fit 2 bolts verses 1 offset on the new motor!
Is there anyway to get 3 wire coil paks to work on 2 wire coil pak system!
Thanks kevin
JDM Importers is offline   Reply With Quote
Old 01-18-2006, 01:14 AM   #2
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
the three wire is the wasted spark, two coil comon ground set up that is standard on most subies right? i dont think that i have ever heard of the two wire coil pack....
josh...just josh is offline   Reply With Quote
Old 01-18-2006, 11:03 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Josh,
unless I am mistaken, the current COP is a 2 wire set up. That's what Kevin is getting at. I have been wanting to explore this for use on my EJ20G, but haven't found the time. I think it may be as simple as switching to EJ205 valve covers and then the newer coils will bolt right up...
Old 01-18-2006, 11:13 AM   #4
JDM Importers
Vendor
Member#: 87569
Once Was Gr8wheels
the old ej20g is blown! so we took a 2000 RSKB4 long block and transfered everything from the ej20G. the link set up on the ej20g used the 2 wire 2 bolt coilpaks the New motor uses the 3 wire 1 bolt coilpaks, the cost to purchase 2 wire 1 bolt coilpaks is over $500, I am just trying to find a solution!
Kevin
Old 01-18-2006, 12:00 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
move the valve covers?
and use the g coils
- just throwing out ideas no idea if it will work
Old 01-18-2006, 06:59 PM   #6
josh...just josh
Member#: 82273
97 impreza L
i'm sure that you're right matt, i was just thinking that the new ones where three wire. how do the two wire ones work? anybody want to educate me
Need help fast- front hub assembly- please help soslow General Community 1 03-04-2006 08:38 PM
Need help fast! Coil packs swap! JDM Importers Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-18-2006 02:32 AM
need help fast! help me get out of work snyper784 Off-Topic 10 10-17-2003 02:45 PM
Noobie Question. Need Help Fast! wrexsta Newbies & FAQs 5 12-25-2002 03:15 PM
