Old 01-17-2006, 08:23 PM   #1
weaC sauCe
Member#: 43625
2011 Ford Raptor
world rally blue
Default Capturing Data w/UTEC Help!
I have a UTEC and after data logging I am trying to save the the data in the Hyper terminal menu. I am selecting:
1.Transfer Capture Text
2.I name file and press start
3.CTRL S and nothing happens I thought "Finished" should appear
What am I doing wrong?
Thanks
H
weaC sauCe is offline   Reply With Quote
Old 01-17-2006, 08:53 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
You have to do that BEFORE it displays the text.....
mcowger is offline   Reply With Quote
Old 01-17-2006, 09:38 PM   #3
Lost_Pete
Member#: 100570
1. Start with the UTEC in the home menu.
2. Go to the Hyperterminal tool bar and select "Transfer" then "Capture Text"
3. Enter your file name (I suggest you add the extension .csv)
4. Press "Start"
5. Back in the home menu press "<shift> 1" or whichever logger you want. The <shift> will give you a comma delimiter output. Also you can use the space bar to stop and start the log.
6. Once you have captured enough data then got to the Hyperterminal tool bar and select "Transfer" and then "Capture Text". Press "Stop"
7. Your data will be in the file location you had previously selected. If you added the .csv extension you can open it using Excel.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 01-18-2006, 03:07 AM   #4
weaC sauCe
Member#: 43625
2011 Ford Raptor
world rally blue
Thanks guys, I got it. I wasn't putting in the .csv so I could'nt open it.
Hank
Utec check sum error map corrupt!! UTEC help bluesube2000 Engine Management & Tuning 18 07-28-2005 05:45 PM
utec help? wont switch over into utec drifterx Engine Management & Tuning 3 11-27-2003 02:28 AM
Quick UTEC help needed 1quikrex Engine Management & Tuning 7 01-23-2003 08:47 PM
Anyone running a UTEC!!!!Help buchananracing Southern California Impreza Club Forum -- SCIC 2 01-05-2003 09:20 AM
UTEC help silver 02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-15-2002 11:17 PM
