Old 01-17-2006, 08:50 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Changing head gasket
Quick question. I know I've heard this before. Is it possible to change the head gasket on a phase I DOHC 2.5 without removing the engine? Just taking off the heads?
Brent
scoobyimprza is offline   Reply With Quote
Old 01-18-2006, 01:56 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
yes its possible, but not very fun. not very much room in there even with heads off. but you really should pull the motor to change the rear main seal and oil seperator plate( get the aluminum one) but yes it is possible and people do it.
~Josh~
Old 01-18-2006, 02:46 AM   #3
JTJ 2.5
Member#: 81572
1968 Subaru 360
2000 RS-H6 Race Car
i did my 2000 rs headgaskets without pulling the motor. it was a pain in the butt especally on the drivers side. if i did it again i would definately pull the motor no questions asked. it was more of a prob because the head bolts seemed to be a bit too long to to fit between the frame rail and the actual block so there was alot of caressing them into place. the one thing i do know it the head bolts for the DOHC heads are shorter than the SOHC ones. This may elivate alot of the major problems i was running into but im not sure.
JTJ 2.5 is offline   Reply With Quote
Old 01-18-2006, 10:27 AM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Alright, I'm just gonna pull the motor then. Thanks a lot guys for your help.
Brent
Old 01-18-2006, 10:39 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's the right choice. You will save no time by not pulling the motor. The extra effort required doing it in the car is not worth it. Even the dealership pulled my motor when they did my first one under warranty...
Old 01-18-2006, 09:20 PM   #6
00rs2.5
Member#: 105306
2000 RSTI
stm
Is the difficulty in reinstalling the heads? I have a 2000 rs pulled the heads of friday and once the bolts were loose from the block the heads w/bolts still in lifted right out. Maybe Im not to the hard part yet?
jp
00rs2.5 is offline   Reply With Quote
Old 01-18-2006, 10:23 PM   #7
JTJ 2.5
Member#: 81572
1968 Subaru 360
2000 RS-H6 Race Car
The heads in my car came out pretty easy too. it was re installing them. i had to problems with the back lower bolts (labeled d in the shop drawings) on both sides. they seemed just a little too long. it probally took me about an hour and a half on the drivers side to position it right so it would fit. the passanger side went alot quicker.
help 05 sti misfiring after head gasket change takumi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-13-2007 09:29 PM
changed head gasket, had slight problem, now car chokes to death 1995LegWag Normally Aspirated Powertrain 5 03-23-2006 11:06 PM
head gasket change help how to rubyred Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-05-2006 07:31 AM
Head Gasket Change...thinner Lavery Normally Aspirated Powertrain 12 05-05-2005 10:39 AM
So now I get to change my head gaskets Tim Sanderson Mid West Subaru Owners Club Forum -- MWSOC 15 12-24-2003 11:19 AM
