Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 01-17-2006, 11:09 PM   #1
amye66
Member#: 86420
2004 STi
Default HELP; trouble getting into Reverse and 5th gear
Have any of you had trouble getting into reverse or 5th gear in an '04 STi? I don't understand what could be wrong; we are having our tranny fluid checked, but I'm starting to get really freaked out. Any input would be appreciated, thanks. We have an Exedy STi Hyper Single clutch with lightweight flywheel. BTW, my husband says he notices that the driveshaft has alot of movement and we have bushings on the way to help correct, could that have worn out something? Do you think this is synchro issue, mounting issue, or did I just wear out my tranny? I have 38,000 miles.
amye66 is offline   Reply With Quote
Old 01-20-2006, 01:56 AM   #2
amye66
Member#: 86420
2004 STi
seriously, noone will answer me now we dont need to lift the reverse lockout to get into reverse. can't anyone help me?
Old 01-20-2006, 06:57 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Does the lockout pull still pull up or is it stuck in the up postion?
Old 01-20-2006, 11:03 AM   #4
amye66
Member#: 86420
2004 STi
It still pulls up ... definitely not locked in engage
Old 01-20-2006, 01:13 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Hmmmmm.... That's really odd. slide under the car and check the cam for the lockout on the tranny. The cam lobe pointed at the ground is the at rest, locked out positon. The cam lobe pointed toward the back of the car is the into reverse, unlocked position.
While under there check for play in the front stay bushing, and in the linkage bushings.
Do you have any modifications to the shifter setup?
trouble getting into reverse SkatmanWRX Transmission (AT/MT) & Driveline 1 05-31-2010 03:44 PM
trouble getting into reverse XmikeX Transmission (AT/MT) & Driveline 7 08-31-2008 09:11 AM
Can't get into 4th, and 5th feels funny. st1llet0 Transmission (AT/MT) & Driveline 5 09-06-2007 01:51 AM
To all of you out there that are having trouble getting into reverse. Sublime5260 Transmission (AT/MT) & Driveline 5 12-15-2002 01:38 AM
Trouble getting into reverse tomrichardson Normally Aspirated Powertrain 15 11-02-2000 09:49 AM
