Old 09-15-2001, 09:37 PM   #1
RSser
Member#: 9528
1999 Impreza RS
Default Another grounding problem and Alpine
The deal is: Alpine amp mounted in trunk on wood, power lead run down middle of car, RCA's run down passenger side, other speaker wires run down their corresponding sides, ground from amp to rear shock tower, additional ground run fron HU case to amp and then to rear shock tower. I have noise in rears. I switched the RCA's at the amp and the noise switched also. Do I have an amp problem? Noise is both ignition popping and alt. whine. The amp is a little over a year old and has been making this noise since new, but it was a hasty install and I just let it go until I could play with it.
RSser is offline   Reply With Quote
Old 09-15-2001, 10:19 PM   #2
mitch808
Member#: 10228
2002 Subaru WRX
Well make sure that your RCA cables are SHEILDED. On top of that, you HAVE to grind or sand down the area your bolting down the ground to, it should be bare metal. If not you'll get noise in your system.
mitch808 is offline   Reply With Quote
Old 09-15-2001, 10:34 PM   #3
RSser
Member#: 9528
1999 Impreza RS
I grounded to the threaded bolt that sticks out of the top of the shock tower. There are three of them available.
Old 09-15-2001, 10:48 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Thats okay to a point, I'll get into that later. Usually, alternator whine is caused by poor quality/NON-shileded RCA cables.
Back to your bolt grounding technique... That is still not enough. Did oyu use a eyelet crimp? Or a spade type crimp for attaching to the bolt? The mojority of the surface contact will come from the nut and car chassis and not the bolt. Most nuts are painted or coated with some type of anti-rust coating. So that leaves removing the paint on the car as a better option.
I am not giving a definitive fix, just my thoughts on how to fix it. As I am a bit of a audio nut.
Old 09-16-2001, 01:09 AM   #5
RSser
Member#: 9528
1999 Impreza RS
I used an eyelet crimp type. I filed the eyelet as well as both surfaces of the two nuts. I ran one nut down on the post, put the eyelet on then tightened the other nut down on the eyelet. Are you saying that it is better to go to a place where paint is scrubbed off? I have tried grounding to three different places; one at bottom of rear deck where I used an existing 6mm threaded hole ( I think it was for a trunk light attachment), one through the drain plug under the spare tire and to the tow hook ( I think this was to long), and the last was the shock tower. All with just about the same results. In your opinion, do I have amp problems?
Old 09-16-2001, 10:49 AM   #6
travman733
Member#: 5649
2002 WRX wgn bl stg2
(sold)'93 Impreza L Sedan
Same problem here...although now I can hear the problem through the fronts as well. I moved my ground to yet another location and the problem got worse. I bought a stiffening cap right when I purchased the amp, so I'm going to try installing that and see if it helps filter out the noise.
travman733 is offline   Reply With Quote
Old 09-16-2001, 12:42 PM   #7
RSser
Member#: 9528
1999 Impreza RS
Stiffening cap? explain please.
Old 09-16-2001, 03:22 PM   #8
Alpine Sube
Member#: 1805
2000 2.5RS
If I were you I wouldn't run my power cable up the middel of the car. With the drivetrain and all the different electronics that are in the middle of the dash. I've always done power on the drivers side and RCA's on the passenger. I'm not sure where our CCM is on the car but make sure to keep the RCA's away from that to.
MATT
Alpine Sube is offline   Reply With Quote
Old 09-16-2001, 04:53 PM   #9
travman733
Member#: 5649
Hm...I never really thought about that, but now I have an even bigger problem, so this'll have to wait. The install of the turbo timer did not go nearly as planned whatsoever!
Old 09-16-2001, 08:14 PM   #10
RSser
Member#: 9528
1999 Impreza RS
MATT, I understand what you are saying, but, it seems to me that there are a lot more wires in the kick panels on both sides. Where I ran the power cable through the firewall, there seems to be very little wiring. There is almost no wiring in the center consul.
Old 09-17-2001, 12:30 AM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
what i used to ground my amp was my spare tire...the center thing that tightens to hold the spare in place is bare metal and cunducts perfectly...also i have a real amp...autotek...with built in noise filters....i dont have any engine noise...also you may want to look into a pioneer organic deck..or any kind of pioneer deck..they have great noise filters on all of their high end decks..
-akcel™
akcel is offline   Reply With Quote
head gasket issue. and yes, another misfire problem. rathead Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-29-2007 12:41 PM
Another grounding mod Kraziken Legacy Forum 16 04-22-2006 12:13 AM
another grounding mod success story! shipjumper New England Impreza Club Forum -- NESIC 4 08-21-2005 02:14 AM
Alpine IVA-D300, Alpine Navigation, and Alpine 12 Disc changer WRXin04 Private 'For Sale' Classifieds 12 08-04-2005 09:59 PM
Grounding Mod and Possible Heat Problem Meat Electrical & Lighting 3 08-11-2003 03:54 PM
