Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-17-2006, 11:57 PM   #1
scooterforever
Member#: 55011
Default Cold weather fuel leak from stock '02 fuel rails -- kudos to KTR
Thanks goes out to KTR for fitting me in for replacement fuel rails on about 2 hours notice yesterday.
After nearly 4 years of only limited maintenance issues (bad wheel bearing which was probably accident related -- snow donuts are expensive if you don't see the curb -- and a dirty IACV) I started my car yesterday morning when it was around 11 degrees F outside, let it idle for a bit to warm up, and...
came back to the smell of gasoline... like someone had dumped a gallon on the passenger seat. I figured that the cold weather fuel leak to which the '02's are susceptilbe finally bit me. This is a documented "from the factory" issue. I don't believe there has been a recall, but there is a technical service bulletin on it.
First response: drive to the subie dealer. No go. Wanted to remove my intercooler and intake manifold. Nobody touches those save KTR -- I'm running meth injection, and my TMIC is, well, huge. It is not the easiest thing to remove.
Anyway, a new set of fuel rails and a few hours later, I'm good to go. No more fuel leak. Whew. I can put the fire extinquisher back in the trunk.
scooterforever is offline   Reply With Quote
Old 01-18-2006, 01:36 AM   #2
Mumbles
Member#: 248
Haha, nice. KTR and water injection seem to hold hands these days. I'm going to be putting it in my evo come summer. Which kit do you have?
-B
Mumbles is offline   Reply With Quote
Old 01-18-2006, 10:03 AM   #3
scooterforever
Member#: 55011
I went with the Aquamist 2d. It's on the expensive side but I liked the failsafe options. Right now I only have a water level sensor and a pump/injector failure warning light, but when I get the electronics wired up I'll have an automatic switchover to wastegate boost upon failure of the pump. Based on other posts, people seem to be having success with the SMC equipment as well.
Old 01-18-2006, 10:26 AM   #4
Mumbles
Member#: 248
Yeah i figured the 2d. That's what i'll be going with also. Have you seen the custom work Franz has done with the LED's? I'm currently scoping out an optimal place to put mine. He also made a nice tank for the trunk which i'd like to replicate.
Old 01-18-2006, 11:10 AM   #5
scooterforever
Member#: 55011
Drop me a pm with your email and I will send you some digital pics of the setup. I did the LEDs myself (so it looks OK, but not great) and KTR did the trunk tank + piping + pump install and tune. The pump itself goes under the rain tray, and is invisible (essentially) in the engine bay. You have to look really hard to see that I have water injection.
Old 01-18-2006, 11:27 AM   #6
NeoteriX
Member#: 20999
2002 PSM WRX Stg 2
knee - Aw - teh - rix
How much it set you back?
NeoteriX is offline   Reply With Quote
Old 01-18-2006, 11:56 AM   #7
Mumbles
Member#: 248
boosting4 at hotmail dt com
I think i saw your install when i was out there... That's a cool setup though. Did he make you a trunk tank or did you use the STI Spec C tank?
-B
Old 01-18-2006, 12:05 PM   #8
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
B... get the Aquamist 2d already, talk about being a sally .
+1 for the custom installs at KTR .
Rick
ami2fst4u is offline   Reply With Quote
Old 01-18-2006, 12:06 PM   #9
Mumbles
Member#: 248
And you get a evo already you sally + 1.
Old 01-18-2006, 03:28 PM   #10
alacrity024
Review Crew
Member#: 49476
this happened to my completely stock '02 turbo wagon last winter.. bumper to bumper warranty had just expired.. i made a stink, called SOA, dropped my name (hey sometimes it's nice to be somewhat famous) and they got it covered under the powertrain warranty. i just hope it doesn't happen again this year
alacrity024 is offline   Reply With Quote
Old 01-18-2006, 05:21 PM   #11
scooterforever
Member#: 55011
Yeah, really feels like they should have done a recall. The gas smell was unbelievably strong.
Oil leak from stock 05 wrx turbo andyboi677 Newbies & FAQs 2 07-03-2009 10:54 AM
Cold weather=Gas leak! Bizmark Texas Impreza Club Forum -- TXIC 33 12-09-2005 05:21 PM
fuel leak from gas tank area 808sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-06-2005 03:58 PM
My STi rock in cold weather, pulled away from a E46 M3! JDM addict Off-Topic 234 08-12-2005 09:42 PM
My STi rock in cold weather, pulled away from a E46 M3! JDM addict General Community 1 11-10-2003 02:26 PM
