Old 01-18-2006, 12:12 AM   #1
subeforlife2002
Member#: 100667
2002 WRX stage 4
Default Short ram intake question
I have a 02 wrx and I'm running a AEM short ram intake. Since we installed the fmic a while ago we had to cut my intake to make it fit in before the pipes. It looks like crap and I wanted to know what other intakes are people running with a fmic.
subeforlife2002 is offline   Reply With Quote
Old 01-18-2006, 12:25 AM   #2
Hunt3r
Member#: 95484
I have a Perrin short-ram that did not have to be modified to fit the piping for my hyperflow fmic. Maybe your ic piping runs differently?..
Hunt3r is offline   Reply With Quote
Old 01-18-2006, 12:51 AM   #3
subeforlife2002
Member#: 100667
2002 WRX stage 4
I'm running turbo xs fmic. My pipe runs the same, but it looks like yours my bend down sooner by your filter. Not sure though. Would me changing intakes mess up my tune that I had done on my turbo xs?
Old 01-18-2006, 02:49 AM   #4
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
So you guys are happy to suck hot ait from the header and up-pipe??:?
Have lost whatever gains you WERE going to get? What did your EGT's do after these were installed?
'Box off' the pod, modify the bonnet 'grille', and get some cold air in there!!
Not flaming....Just my 0.2c worth
Sixpack
sixpack subaru is offline   Reply With Quote
Old 01-18-2006, 06:07 PM   #5
subeforlife2002
Member#: 100667
2002 WRX stage 4
Any ideas on what material to use to create a box around the intake, then a tube or splitter to direct the air?
Old 01-19-2006, 01:35 AM   #6
Hunt3r
Member#: 95484
My whole setup is a TurboXS stage 4 kit but the guy who installed it went with a Hyperflow IC instead of the TurboXS one. But yeah it looks like mine bends down sooner before the intake and that my air filter assembly may be just a little smaller than yours too.
Sixpack, boxing it off definitely would be a good idea if I had the time, but I really don't think it gets hot air there being that the filter is shoved right up against the hole into the fender well. I have a egt meter and I usually cruise around 500-600, sometimes less.
My only complaint about the intake is I seem to be getting too much cold, dense air now that it's winter time. I had it re-tuned the past summer outside in the heat and now it seems to run a little lean on cold days so I've got to go get a "winter" tune now
And yes you probably should re-tune if you change intakes, I guess it really depends on how different the intakes are and most likely they're different enough to warrant a retune.
Old 01-19-2006, 01:59 AM   #7
sixpack subaru
Member#: 64974
Subaru Stars
Use fiberglass, then use a tar-backed adhesive foil heat coating on it.
As far as the bonnet grille goes, there are a few manufacturers out there making a 'bolt-on' 'scoop' for the rh bonnet grille. You WILL notice the difference, cold climate or not.
Cheers
Sixpack
Old 01-19-2006, 02:17 AM   #8
sixpack subaru
Member#: 64974
Subaru Stars
I doubt whether you will ever need a retune for an intake, most of the governing factors for intake are turbo, valves, heads, t/body etc, (and lets not forget that you guys are still running the under manifold intake ).
You would not need to retune because of the intake pipe before the turbo in my opinion. As far as sucking cold air, I recently had an 'in depth conversation' on a thread with The Mad Scientist based on turbo-prop engines and the issues with fuel condensation when the charge air temp falls below 40Deg F, we both agreed and it is thermodynamic basics that the lower the charge air temp in a forced induction internal combustion engine the better, there is no 'lowest usable' temp where the fuel will condense and therefore lose torque due to an unburnt mix. In short, for the Subaru engine in particular, with it's long intake runners and turbo charger, that the colder the air the better .
I'm not saying that you won't have to re-tune from summer to winter if we are talking about massive charge air temp differences, (although believe it or cold dense air actually creates a lean mix!), to achieve max toque/HP this would be essential.
BTW;it DEFINITELY gets hot air there, trust me!!
If you don't have time, wait till your mate makes one then get one from him
HTH
Cheers
Sixpack
Short Ram Intake Question? 2002SUBIE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-13-2007 02:35 PM
short ram intake question ttatsumi Legacy Forum 11 05-09-2006 10:33 PM
Short ram intake question subeforlife2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-01-2006 08:26 PM
short ram intake question dj00crusty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-02-2005 07:53 PM
Short ram intake question gumby1976 Normally Aspirated Powertrain 5 04-01-2003 06:47 AM
