Old 01-18-2006, 12:48 AM   #1
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
Default blocking off egr; good idea or not?
i dont think that jdm subarus have an egr system so for most of you guys this wouldnt be an issue. but what if youre swapping in an usdm engine, or building a
hybrid? i know that blocking off the egr rasises combustion temps but can that be corrected with just a colder plug? i'm sure that you would show a CEl but
who cares if it doesnt hurt anything. the only things that you would have to worry about is the egr valve itself and the egr postion sensor right? you could just plug the vaccum lines up. i'm just thinking that getting rid of the egr and maybe even the evap systems you could really clean up and simplify an engine
josh...just josh is offline   Reply With Quote
Old 01-18-2006, 07:00 PM   #2
josh...just josh
Member#: 82273
97 impreza L
so no one has any idea huh?
Old 01-19-2006, 09:39 AM   #3
suby53
Member#: 59648
97' Legacy Outback
I tore all that crap out when I swapped from my ej18 to my ej22. I used the EJ18 manifold and just built a block off plate and tore of all the hoses and plugged the vacuum ports. No cels yet and its been months and it runs great!
suby53 is offline   Reply With Quote
Old 01-19-2006, 06:55 PM   #4
josh...just josh
Member#: 82273
97 impreza L
i would think that as long as you kept it in check the higher temps would even be better for turbo spool
Old 01-20-2006, 03:14 PM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
i blocked it off on ej28->25 swap. he was happy for 2 years.
swapstar is offline   Reply With Quote
Old 01-20-2006, 05:12 PM   #6
Lachlan
Member#: 19470
1981 Brat GL
what's an egr?
Lachlan is offline   Reply With Quote
Old 01-20-2006, 05:27 PM   #7
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Dark Slvr / Crystal Slvr
your retarded if you remove EGR...
only thing egr does is improve gas mileage during light throttle/cruising conditions...
it is NEVER open during idle or full throttle....
Bottem line DO NOT REMOVE EGR...
JessesTalon is offline   Reply With Quote
Old 01-20-2006, 07:45 PM   #8
josh...just josh
Member#: 82273
97 impreza L
hows does dumping exhausr gas into the intake improve gas milleage? the point of the egr is to a) reduce emissions by re-burning some of the exhuasr gases and b) reduce combustion temps. i dont know what youre talking about but i dont think that its right (i could be wrong)
Old 01-20-2006, 08:11 PM   #9
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
how would letting exhaust gas into the combustion chamber LOWER temps?
i thought it was a way for cold starts for the engine to warm up faster as well.
the EGR probably does help mileage, since your reburning unused fuel in the exhaust. dont worry about it, do whatever makes the swap easier for you.
Natoe is offline   Reply With Quote
Old 01-20-2006, 08:29 PM   #10
josh...just josh
Member#: 82273
97 impreza L
i guess that i just want to understand it. i know that the symptoms of a bad egr is pinging and rough idle, i dont know
Old 01-20-2006, 08:34 PM   #11
josh...just josh
Member#: 82273
97 impreza L
This was taken from another website:
The automotive engineers figured that they needed to do something to lower the peak combustion temperatures which only occurred under certain high load driving conditions. They figured they could do so at the expense of power and fuel economy but what the heck, ya can't have everything! If they could only add something to the combustion chamber that would act like sort of a fire extinguisher to cool the combustion temperatures that would do it.
So they invented a way to allow some very inert gas to get back into the combustion chamber only when needed. They needed a source of this gas - it wasn't air, cuz that contains oxygen and nitrogen which caused the problem in the first place. So they chose carbon dioxide. Where to get a supply of carbon dioxide . . . ??? Hmmmm, how about the exhaust system?
Old 01-20-2006, 08:43 PM   #12
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
egr is nasty. and so is a RWD "drift-o-futo" impreza.
you'd think that if EGR improved gas milage all the JDM motors would have them.....
Old 01-20-2006, 09:33 PM   #13
XENONSVX
Member#: 41719
XT, SVX, JUSTY &
GF8 STI V4 RA
you can block off EGR and not have any driveability problems. You may get a CEL and you'll have problems passing emisions (if it's in your state)
I know for a fact (because there's one in my garage) that when doing a miata swap you have to disable the EGR on the new motor. Just block it off w/ a plate and call it good.
EGR is old technology, there are better systems coming out and currently in use
XENONSVX is offline   Reply With Quote
Old 01-20-2006, 10:35 PM   #14
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
i have mine blocked due to the rumor that N/A to turbo swaps, you'll be getting a LOT of hot gas going into your intake manifold, thus heating up a specific piston chamber due to area of disposal. I have yet to absorb why I SHOULDN'T do this, so its still disconnected. My concern is to make all four intake manifold runners an equal temperature, if this mod won't do it, then I'll switch that 4mm tube back in...
STi-Nismo Dood is offline   Reply With Quote
Old 01-20-2006, 10:38 PM   #15
JessesTalon
Member#: 63925
95 R33 / 06 WRX
seriously if u don't know what a egr is in the first place, DON'T MESS WITH IT...
lol
it drops temperature by adding inert gas into the combustion chamber...
you get better gas mileage cause you arn't using as much air/fuel because some of the chamber is inert gas which doesn't combust. smaller combustion = better mpg and lower emissions and lower temperature in teh combustion chamber
seriously if you guys DONT know what your talking, then don't talk at all... please
Old 01-20-2006, 10:43 PM   #16
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
so does anyone notice the drop in the intake manifold temp. where your EGR is located after removing the hose?
Old 01-20-2006, 10:46 PM   #17
JessesTalon
Member#: 63925
95 R33 / 06 WRX
egr ONLY opens at cruise...
it is NEVER on at full throttle.... so don't touch it, otherwise your going to get worse gas mileage normal driving around town, just drop it aight?
Old 01-20-2006, 10:53 PM   #18
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
TAKE DAT ISH OUTTA DER!!
fuel to the fire
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-21-2006, 12:01 AM   #19
Natoe
Member#: 90353
go home, nobody wants to hear that, everyone deletes it, no one has had any problems with deleteing it, if you love it so much then you can keep it and we wont make fun of your mom for it. older usdm and all jdm motors dont have it, its strictly emissions.
Old 01-21-2006, 12:27 AM   #20
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
EGR advantages- lowers combustion temps which reduces NOx emissions and reduces detonation, allowing for more aggressive ignition timing.
Disadvantages- may reduce throttle response, promotes carbon buildup in the intake. Over time and mileage the valve tends to stick and may leak, causing idle and/or driveability problems.
Most factory EM has a way of monitoring the EGR so if it is removed completely a CEL will usually result.
Old 01-21-2006, 05:38 AM   #21
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
jesse, you are being a dolt. you belong in the fan boi forum, not the conversions forum. show us some street cred and perhaps i'll ask that importer shop why you were not fit for the op.
Old 01-21-2006, 08:51 PM   #22
JessesTalon
Member#: 63925
95 R33 / 06 WRX
if u want higher combustion chamber temp's and bad gas mileage, then be the dope and block it off...
u wont pass emissions, you'll get ****ty gas mileage, and you will have a check engine on all the time...
how is it a mod?
Old 01-23-2006, 05:24 PM   #23
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Not too sure about the Full throttle.. If I'm Correct the EGR opens above 3K you can see the Suction of the engine pull it open, and the engine runs like Crap if you open it by hand.
SubaruImpreza_power is offline   Reply With Quote
Old 01-23-2006, 05:27 PM   #24
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Originally Posted by Lachlan
what's an egr?
Exhaust Gas Recirculation
In a nutshell it takes gases that were not burnt the first time around, they go for another pass.
Old 01-23-2006, 06:13 PM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
lol
I think you may be missing the point here. On a number of the hybrid engines that some of us have been building, there is no bung for the EGR on the new heads. And thus the relevance of his question.
I have blocked this off on several engines that used non-EGR heads, but continued to use the Ej18 intake manifold and wiring harness. Or for other folks using EGR based EJ20's with different heads, but the original manifold, it would be the same. Just unplug it and block off that section of the manifold...
Creating man made black holes - good idea or not? docwhorocks Off-Topic 84 09-09-2008 01:53 PM
Good Idea or Bad Idea stock BPV's question SatanasoSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 03-29-2006 09:04 PM
good idea or bad idea? fastwrx006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 07-15-2005 05:23 PM
3" cat back for WRX...good idea or bad idea? JDMSubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 12-24-2003 04:40 AM
Dealer rust, fabric, paint protrection. extended warantee-Good idea or not? belvista Canada Region Forum 11 12-04-2003 09:16 PM
