Old 01-18-2006, 01:17 AM   #1
SamTheMan
Member#: 98650
Default rotating coolant manifold 180 deg.
If I rotated the coolant manifold 180 degrees would I have cooling problems?
Instead of the line coming out by the power steering pump it would come out
by the starter… pm me and I can email pic. sry not sure how to post a pic.
this is for a setup that needs the radiator mounted behind the engine
and trans without needing to run long hoses around the intake.
Sam
SamTheMan is offline   Reply With Quote
Old 01-18-2006, 11:48 AM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
actually you can remove the tank all togeher .. the tank allows water to recircualte AFTER the engine is off .. its not totaly nessicary but helps cool the turbo
Old 01-18-2006, 11:52 AM   #3
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
He is talking about the manifold under the intake manifold and yes you can rotate it no problem, I have done this for dune buggies.
Scoobie Steve is offline   Reply With Quote
Old 01-18-2006, 01:01 PM   #4
SamTheMan
Member#: 98650
thanks guys. yeah i am talking about the crossover tube under the intake.
even tho i dont think you need it... but would like others to see what i am
doing.... how do i post a pic?
thanks again:
Sam
Old 01-18-2006, 01:46 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I know a few guys have done it for use in 914's as well...
Old 01-18-2006, 09:01 PM   #6
SamTheMan
Member#: 98650
wonder if this will work...
stock..
rotated manifold.
had to cut a lil off so i could get the hose to fit w/o kinking.
side view.
Old 01-18-2006, 09:22 PM   #7
Scoobie Steve
Member#: 2289
1998 11.87@112mph
EJ18 with an auto.....hope you dont plan to go fast
Old 01-18-2006, 09:37 PM   #8
SamTheMan
Member#: 98650
well when the atv will be about 800-900lbs... and im not wanting to go more than 50 or 60... i think it will work. lol it came from a wrecked car just sitting at the house.. so i thought "hey im going to make something fun out of that" so with a budget of less than $600... im not going for high performance. lol but thanks for pointing out my miniscule engine hahaha
Old 01-18-2006, 10:02 PM   #9
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Here are some pics of my suby powered ATV. First engine was a EJ25 phase I block with EJ22 dual port heads, AFB carter 600cfm carb and distributor. It made crazy power and would easily do wheel stands.
After that engine blew I put in a EJ18 fuel injected engine. It didnt have half the power of the EJ25, but was still fun
Old 01-18-2006, 10:09 PM   #10
SamTheMan
Member#: 98650
now thats cool. do you have more pics of the build?
mine will be more like the STIatv... more like a 4wheeler.
so goin fast and feeling fast will be totally diff...haha
What is needed to rotate intake manifold roybfr Factory 2.5L Turbo Powertrain 2 04-12-2007 06:57 PM
Updated Project Legacy GT w/ Rotated Intake Manifold/Turbo ShaggyGT Member's Car Gallery 102 03-17-2007 10:56 PM
Turn Intake Manifold 180° ?? Mandra Factory 2.0L Turbo Powertrain 43 07-25-2004 03:27 PM
rotating intake manifold suby_speed Factory 2.0L Turbo Powertrain 5 10-15-2002 12:17 PM
180 deg. thermostat harrydog Factory 2.0L Turbo Powertrain 4 06-19-2001 07:29 AM
Message Board Statistics All times are GMT -4. The time now is 02:30 PM.
