Old 01-18-2006, 06:16 AM   #1
jimmieson
Member#: 69601
2004 WRX Sedan
Default New Crawford 2.5 S2
Ok here is the deal,
I installed the 2.5 S2 block, STI injectors, and gutted the stock up pipe and down pipe. Im getting a check engine light from the O2 sensor. I also had it all check by a mechanic everything was mechanicaly sound except for this O2 reading. The Problem im having is that its shuttering at high RPMS. Im planning on getting the UTEC and working on tuning it and i just wanted to get input to see if that was most likely my problem.
Thanks for any ideas
jim
jimmieson is offline   Reply With Quote
Old 01-18-2006, 09:08 AM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
You can't just swap the block and injectors and expect the car to run right. You definatley need engine management. You are probably running real rich. What was the exact CEL code?
LiquidForce is offline   Reply With Quote
Old 01-18-2006, 09:51 AM   #3
jimmieson
Member#: 69601
2004 WRX Sedan
I understand that it wasnt going to run right i was just curious if anyone was having a similar problem. Thats why i said im planning on remapping the ECU. Ok the actual code is P0420 Catalyst Efficiency Below Threshold. Can that be fixed with the tuboXS UTEC? just curious
Old 01-18-2006, 10:36 AM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
The cel is from removing the cats. It has no impact on performance. Back when I had a UTEC it could not turn off specific cel's it simply turned off the light on the dash leaving the codes in the ecu. Things may have changed since. Do a search for "mechanical cel fix". There is a real easy way to get rid of it by using two spark plug antifoulers.
Old 01-18-2006, 11:56 AM   #5
jimmieson
Member#: 69601
2004 WRX Sedan
Hey thanks for the help i looked into it and its about 20 bux a pop for a wire to trip out the ECU to thinking that the cats are working fine. thanks again
Old 01-18-2006, 07:37 PM   #6
LiquidForce
Member#: 12811
2002 2.5l Wrx
the antifoulers are 2.50 at autozone and require no wiring.
crawford 2.5l s2 pippen Subaru Conversions 3 06-02-2010 07:17 PM
NC: 2004 wrx f/s crawford 2.5 liter w/ sti 6 speed ilivas Private Vehicle 'For Sale' Classifieds 17 01-24-2007 12:07 PM
BRAND NEW Crawford 2.8 R4 Shortblock Peeblesmx445 Private 'For Sale' Classifieds 20 05-31-2006 04:30 PM
Crawford 2.5 Stage 2 Block Install mrbluesky Subaru Conversions 4 01-13-2006 12:35 PM
Crawford 2.5 Stage 2 Block Install HELP! mrbluesky Subaru Conversions 0 01-12-2006 10:18 PM
