Old 01-18-2006, 09:18 AM   #1
STi-Spec C
Member#: 75923
2004 18g WRX
Default 99rs to usdm wrx swap
does anyone know if it's possible to do the swap without having to pull out the dash? also i need the wiring charts for both ecu
STi-Spec C is offline   Reply With Quote
Old 01-18-2006, 09:46 AM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Yes, its possible, but it will be easier and look cleaner to pull the beam and heater core. Trust me.
jamesfacts is offline   Reply With Quote
Old 01-18-2006, 03:39 PM   #3
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
Both ECU's???
Elaborate please.
WRXedUSA is offline   Reply With Quote
Old 01-18-2006, 04:11 PM   #4
STi-Spec C
Member#: 75923
2004 18g WRX
the reason why i wanted to do the swap without pulling the dash because i want to keep the amount of labor time down so I can finish the swap on a weekend or something like that. Sorry i need to find wiring diaghrams for both cars so i know which wire to splice and which wire to replace. I was early morning when I posted that and my haven't really waken up yet. so it is possible without puling the dash. so what method should i use if i choose to go this route?
Old 01-18-2006, 04:25 PM   #5
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
www.northursalia.com has quite a few diagrams.
Old 01-18-2006, 06:18 PM   #6
jamesfacts
Member#: 51282
98 RS
You will never get your first complete swap done in a weekend - it takes us 2-4 days at the shop, and this with 3 guys who have done it more than a few times.
Old 01-19-2006, 01:45 AM   #7
STi-Spec C
Member#: 75923
2004 18g WRX
thanks for the link it has all the info i need for the wiring
Old 01-29-2006, 05:02 PM   #8
maddbmxjumper
Member#: 43044
01 sedona red ej20
stage 3 vf23 rs
actually pulling the dash and dash bar out isnt all that bad. you can do the whole thing with a phillips head screw driver and a 10mm socket and extension. and it makes things 10 times easier and it comes out alot cleaner. if you do pull the dash, just make sure you dont let your steering wheel and shaft assembly drop down to far. the rubber o-ring around the steering shaft in the firewall may pop out, its a project to get it back in. anymore questions feel free to ask me. kyle
maddbmxjumper is offline   Reply With Quote
Old 02-01-2006, 05:24 AM   #9
billyr2.5
Member#: 53663
2011 WRX WR Blue
2000 Coupe, Sedona Red
to pull the heater core and the beam...is that just to help with the wires behind the dash or is that just to help out with the swap and its overall performance, or just to help and then be put back?
and also would it be a direct replacement if i where to buy a ver. 5 cluster, ecu, engine, and maybe the tranny (b/c i have a kaaz close ratio right now.)? BUT...would i need the "ver. 5" complete wiring harnese if i went this way?
billyr2.5 is offline   Reply With Quote
Old 02-01-2006, 10:59 AM   #10
jamesfacts
Member#: 51282
98 RS
You will end up with a sloppy harness if you don't pull the dash - you won't be able to chop you everything you'll need to.
Electrically, you can use a v5 tranny and cluster without performing any wiring work at all.
Old 02-01-2006, 11:17 AM   #11
Petty
Member#: 45331
.... I miss my
swapped RS :(
My RS-t That i purchased from a guy in NC was done without the dash being pulled. I must say that he did an awesome job! I disagree with the comments about it being messy. Mine is super clean.
Petty is offline   Reply With Quote
02 2.5rs swapped to usdm wrx 307whp 277 torque:)td05 big 16g simprezl25 Proven Power Bragging 15 05-03-2008 02:11 AM
JDM v7 Passenger Seat swap on to USDM wrx driver base dan avoN7 Interior & Exterior Modification 7 09-02-2006 08:08 PM
usdm wrx swap maintenance questions spiralsmurf Subaru Conversions 3 01-27-2004 01:51 PM
Gauging Interest: JDM 2.0 or USDM WRX swap fukamoto Private 'Wanted' Classifieds 0 09-07-2003 07:33 PM
USDM wrx swap+ AEM EMS into GC8 best option? FLUBYUx2 Normally Aspirated with bolt-on Forced Induction Powertrain 38 06-28-2002 09:54 AM
