Old 01-18-2006, 02:24 PM   #1
rewt
Member#: 60794
2007 Solstice GXP
Default Pre-turbo WI
Hey everyone... I figured this section would be the best place for the question, so I hope I'm right. I basically was interested in opinions on the best way to accomplish pre-turbo WI...
Is there a kit that already exists for this?
If not, what sort of nozzle should be run? Based on reading about aiming the water at the compressor nut, I would assume a typical misting nozzle used for post-turbo WI would not work... or would it?
Would I need to run more pressure in pre-turbo WI?
Any information about this would be much appreciated. TIA
rewt is offline   Reply With Quote
Old 01-18-2006, 02:34 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
No kit.
Have to be careful of backflow so use check valves (boost will push water into intake).
Use a mist, not a stream.
You'll need very good boost control.
I'd say this is an advanced form of water injection. I'd set up post-turbo water injection first before you turn to pre-turbo injection. Pre-turbo has it's place, but it definately complicates the whole set up. I'd be sure you are really comfortable with water injection in general before you turn to trying to compress more air with it.
Old 01-18-2006, 02:44 PM   #3
TheMadScientist
Member#: 23717
2005 Big red
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=267
You might have to sign up to view that. But it is ~20 pages about pre turbo WI.
It is a good place to start.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-18-2006, 02:44 PM   #4
rewt
Member#: 60794
2007 Solstice GXP
I've been running post-turbo WI for a while. I'm interested in pre-turbo WI, but I was looking for more information (like nozzles, pump pressure, etc) before trying it.
Old 01-18-2006, 02:45 PM   #5
rewt
Member#: 60794
2007 Solstice GXP
TMS
Thanks! Sign-up is not a problem if the info is good
Old 01-18-2006, 07:41 PM   #6
rewt
Member#: 60794
2007 Solstice GXP
My thanks to TMS; the thread on WI.info is great. Just the type of information and discussion I was looking for.
Old 01-18-2006, 10:35 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....IIRC, hotrod has done this....mebbe he will chime in and give us the benefit of his considerable experience
Old 01-18-2006, 10:48 PM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
hotrod participated in the aquamist forum. I used three 0.5 mm nozzles, two in the intercooler and one in the intake (a check valve prevents siphoning). The pump was at 7 bar. Adding the pre-turbo injection did increase the amount of air compressed as measured by AFR at the same boost pressure.
Old 01-19-2006, 07:43 AM   #9
hotrod
Member#: 14141
2002 Impreza WRX
Yes I have some posts on that forum discussion.
Cliffs notes version.
Per-turbo compressor WI can increase the effeciency of the compressor by several percent.
Its benefit is most noticable on undersized over stressed turbo's (ie stock WRX TD04-13T),or if inlet air temps are high and humidities are low (ie desert condtions)
It can lead to some compressor blade errosion if over used, and or excess water is sprayed.
Some small amounts of compressor errosion appears to have very little effect on compressor performance.
Do not attempt this --- unless your willing to read and understand the above posted discussion on pre-compressor injection on the aquamist site, and are willing to consider the compressor a wear part and replace it if you overdo the WI amount.
Larry
hotrod is offline   Reply With Quote
Old 01-19-2006, 12:25 PM   #10
rewt
Member#: 60794
2007 Solstice GXP
Yeah, I've been reading through the thread on the Aquamist site, and unfortunately, I don't think pre-turbo injection is something I'd benefit from in my specific circumstances...
On spool-up, my compressor is already pretty close to the surge line on the compressor map, so I'm thinking unless I want to only inject at high RPM, high flow, I think pre-turbo WI would lead to guaranteed compressor surge. It would have been a nice idea on my 20G though.
Thanks for all the input.
Old 01-19-2006, 01:09 PM   #11
Freon
Member#: 88322
2009 BMW 135i
There is a thread on NASIOC where Richard from Aquamist has been posting. I think his username is RichardL, but the thread title has "aquamist" in it.
Freon is offline   Reply With Quote
FS: IL 2005 Legacy GT, 20G turbo, WI, with or w/o ALL stock parts NEW PRICE Rclark0032 Private Vehicle 'For Sale' Classifieds 57 05-01-2008 06:37 PM
2005 Legacy GT, 20G turbo, WI, Plus ALL stock parts for sale in Chicago Rclark0032 MWSOC Private Classifieds 12 04-23-2008 05:39 PM
Telling the difference between PRE turbo and POST turbo leaks bren wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-30-2006 02:07 AM
Pre-turbo cat failure = blown turbo nicd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-24-2001 04:18 PM
