Old 09-16-2001, 12:24 AM   #1
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
Default Boost Gauge Question
How loud should the boost gauge be? We (mostly Hondaslayer) just installed an Autometer boost gauge in my WRX today...under boost it sounds like I have a second turbo on the driver's side. Is this normal? At first I liked it, but now its getting somewhat annoying. Any comments? Thanks?
lbk16 is offline   Reply With Quote
Old 09-16-2001, 12:45 AM   #2
solomrus
Member#: 1767
shouldn't make any sound.
if it does, you have a leak. that isn't a good thing. check all of your connections.
solomrus is offline   Reply With Quote
Old 09-16-2001, 01:17 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
boost gauges are supposed to be silent! Maybe you got the boost gauge that has an integrated blow off valve or something?
nhluhr is offline   Reply With Quote
Old 09-16-2001, 01:59 AM   #4
hman
Member#: 3747
2002 Impreza WRX
Platinum Silver Metallic
Sounds like a leak. I had the same problem.
hman is offline   Reply With Quote
Old 09-16-2001, 04:11 AM   #5
Austin
Member#: 7089
2016 STi
Can you say... Leak!
Austin is offline   Reply With Quote
Old 09-16-2001, 07:29 AM   #6
Hyperdash
Member#: 8577
2002 wRx wHiTe OnE
AsPiRiNg I-cLuB RyCeBoI
if he tapped the vacuum hose thru the little opening above the pedals then thats where the sound is coming from, it doesnt have to be a leak.
I had this same problem, but then I just drilled a hole in the rubber cap thing that's originally over the hole, pushed the hose thru it and plugged it up and now no more "second turbo sound"
Hyperdash is offline   Reply With Quote
Old 09-16-2001, 08:48 PM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I have the same problem! I installed my VDO gauge and it reads boost perfectly (~9 psi in 1st, and 14psi in all other gear after 2nd). At high boost, it make a sound kinda like a sping rattling. It's not the gauge, because I removed the gauge and plugged the vacuum hose and it still made the noise. It sounds like the pulses from the turbo are just being amplified through the hose. My vacuum at idle is just under 20 in in Hg. Any more fixes? BTW, I routed the hose through the rubber gromet that is on the firewall.
TIA, -C
TypeC is offline   Reply With Quote
Old 09-16-2001, 09:23 PM   #8
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
I just tightened all of the fittings. No hiss now...all fixed.
Old 09-16-2001, 10:54 PM   #9
DocWyte
Member#: 1840
2002 M3
Oxford Green
It's normal for the VDO boost gauges to rattle under boost. It's the spring inside of it. You need to place a filter inline to get rid of the noise.
DocWyte is offline   Reply With Quote
Old 09-17-2001, 10:03 AM   #10
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
wierd, because when I removed the gauge and capped the vacuum hose, it still made the noise at full boost. It's not a hissing sound at all. Maybe I'll buy another 6' of vacuum hose, run it in the car, and see if my original hose is bad. I don't think it's a leak though. Maybe the hose going into the firewall is pinched a bit and is vibrating against itself sort of like when you let air out of a balloon and pinch the opening.
any other suggestions?
-C
Boost Gauge Question & my first post, get my WRX on Wednesday! paultg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-20-2001 12:19 PM
Boost Gauge question neurotic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-09-2001 04:09 PM
GFB bov and factory boost gauge questions shogunate83 Newbies & FAQs 2 10-31-2001 11:04 AM
Boost Gauge Question MaxPSI Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-12-2001 01:38 AM
Installing boost gauge questions jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-09-2001 06:43 AM
