Old 09-16-2001, 12:51 AM   #1
solomrus
Member#: 1767
Default only 8 psi boost stock?
has anyone else noticed this after they installed their boost gauges?
i finally managed a way to satisfactorily mount my gauges in the factory pod, and once i did, i thought my gauge was bust, as i only was seeing 8psi max. so, i went and coughed up for another one so that i could compare.
well, that one showed me 8psi too!
so, now i have two boost gauges, and 15psi. i made a quickie MBC with a brass valve so that i could attempt to get some real boost going on. i have it set so that it now peaks right at 15psi.
the car feels totally different now.
anyways, if anyone else has seen this 8psi issue, chime in. i am dying to know if it is just me, or everyone.
solomrus is offline   Reply With Quote
Old 09-16-2001, 01:16 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i only see about 8psi when in first gear but all other gears i'm able to hit just shy of 15psi without problem.
nhluhr is offline   Reply With Quote
Old 09-16-2001, 01:32 AM   #3
solomrus
Member#: 1767
mine wouldn't crack 8psi no matter what gear until i installed the boost controller.
Old 09-16-2001, 04:29 AM   #4
Austin
Member#: 7089
2016 STi
The stock wastegate spring pressure is around 7-9psi, so if you somehow are running a straight hose from the turbo outlet to the wastegate, you'll only see that much pressure.
Austin is offline   Reply With Quote
Old 09-16-2001, 10:45 AM   #5
Unahoctura
Guest
Member#:
I had this same problem after installing my guage and found that the whit plastic line that runs to the guage was kinked and so wasnt showing full boost. I would check that before trying to crank up the boost as you could be running dangerously high without a properly reading gauge.
Old 09-16-2001, 12:52 PM   #6
Austin
Member#: 7089
2016 STi
Just noticed... you posted in the Factory Forced Induction forum, but it says you've got a MY98 RS... Are we talking about a WRX or an RS-T?
Old 09-16-2001, 12:59 PM   #7
monkeytronZ
Member#: 7255
hey, i kind of have a similar problem. im boosting a max. of 11 lbs. im almost positive that there isnt a kink. i thought that maybe going through the ecu resetting procedure would fix this.. any ideas?
monkeytronZ is offline   Reply With Quote
Old 09-16-2001, 01:00 PM   #8
Fubaru
Member#: 6046
'08 Prius
if he's running 15psi on an RS-T he's going to have other problems...
Fubaru is offline   Reply With Quote
Old 09-16-2001, 02:15 PM   #9
solomrus
Member#: 1767
the 98 is my wifes car. when i registered, that was all that we had.
now she still has her 98, and i have a wrx. i couldn't find a way to add my car, and still keep hers as my profile.
thanks for the thought tho.
no, isn't a straight shot from the turbo outlet to the wastegate. i have a home-made boost controller.
i have also checked the nylon line for the boost gauge. first thing i do when i install something, is assume that i messed it up. so, that being one of the primary parts of a gauge install, that is what i confirmed first. it is ok.
boost is only 8 psi why Turbospool72505 Newbies & FAQs 31 11-12-2009 09:37 PM
Only 8 PSI? GlennC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-08-2008 01:56 PM
hitting only 8 psi stealth84ct AccessPort 4 08-07-2006 10:12 AM
Need help. Boosting only 8 psi atom945 Engine Management & Tuning 4 11-21-2005 07:56 PM
Only 8 PSI boost Uncle Scotty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-28-2003 09:09 PM
