Welcome to the North American Subaru Impreza Owners Club Wednesday April 23, 2014
Old 01-18-2006, 04:02 PM   #1
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Default G-Meters and Tuning
Would one of these be able to substitute a dyno for tuning? http://www.gtechpro.com/rr.html
Trunk_Monkey is offline   Reply With Quote
Old 01-18-2006, 04:21 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
I think it could. I also think logging delta RPM/second or half a second or quarter of a second would do the same thing. Both are based on acceleration measurement.
Old 01-18-2006, 05:01 PM   #3
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Bump - Any more input?
Old 01-18-2006, 05:42 PM   #4
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
try http://www.dynamic-dyno.com there are quite a few of us on WRXFanatics using the software and the #'s are on target with actual dyno #'s on a dynojet
i have charts in the review section
Quack is offline   Reply With Quote
Old 01-18-2006, 09:28 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
That's pretty cool software. There's a similar one called Road Dyno. The GTech seems like it should work just fine if you can get the data onto a computer. The little screen on the GTech Pro does not seem good enough (lacks resolution).
Old 01-18-2006, 09:30 PM   #6
Quack
Member#: 57264
less hardware to mess with than teh Road Dyno & the developer of the Dynamic Dyno Software has a Saabaru
Old 01-19-2006, 12:39 PM   #7
parid
Member#: 16336
2002 WRX Wagon
The main benifit from dyno tuning is not some bragging number at the end. It's being able to do work on your car off the road (safely) and to be able to put a high amount of load so that it takes longer for your car to rev (thus getting more data at diffrent points during your pull).
parid is offline   Reply With Quote
Old 01-19-2006, 01:35 PM   #8
Freon
Member#: 88322
2009 BMW 135i
I'd trust an accelerometer more than I'd trust a Time/RPM log by a longshot. The Gtech uses an accelerometer and the weight you input to calculate power. It logs RPM, but only so it can graph your power against RPM. There are two big problems with logging RPM. Wheelspin, and the quality and speed of the RPM log. To do it, you need a very high speed sampling rate, and each log sample needs to be counter-based so it is representative of the average RPM from the moment of the last sample to the current sample. Most RPM logs jump around too much and are "noisy", requiring tons of smoothing, and the more smoothing you use, the more samples you need to retain precision. I can at least tell you UTEC and SMT-6 logs are not precise enough. The UTEC isn't fast enough, either, although there is a logger now that has "fast logging" ability which may help (haven't tried yet). I don't think OBD/SSM is fast nor precise enough.
With any sort of road tuning you need to make sure you are consistent or you'll never know exactly what changes you are making are really doing. If you can do a full acceleration run in 3rd gear the same direction on the same stretch of road I don't think there is a big proble with doing this.
parid: that really only applies to a loaded dyno. I agree a dyno is a crap load faster. Resetting is faster, consistency is going to be much easier to achieve, you're not out on public roads, etc. It's a much more controlled environment.
Freon is offline   Reply With Quote
Old 01-20-2006, 12:51 PM   #9
Jeramie
Member#: 56995
2004 WRX
I've actually read alot about this stuff just recently, while a dyno may be more acurate, and easier to repeat with the same consistency, it still is not "Real World" conditions. So while on the dyno everything looks great, on the road may be a diffrent story.
While I know a dyno is the better method, logically it almost seems "Road Tunning" would end up with better results?
I wish I could rember where the artical is that I read about this. It was quite intriguing.
edit - I found the artical - enjoy
http://www.dinancars.com/whitepapersFile.asp?ID=9
Jeramie is offline   Reply With Quote
Old 01-20-2006, 12:55 PM   #10
Quack
Member#: 57264
from SloRice (a Mustang Dyno sales engineer):
Originally Posted by SloRice
What information do I need to input into Dynamic Dyno? Vehicle weight including passengers, an
estimate of the amount of fuel needed to fill up the gas tank, final drive ratio, gear ratio, tire radius, drag
coefficient, frontal area, air temperature, dew point, and pressure. Some of these values have a very
small effect on the calculated horsepower and torque. Download the user's manual if you want more
information on the effect of the different factors and suggested internet sites for finding them.
It's basically the same thing as a Dynojet. Except the Dynojet doesn't factor in the aerodynamic coefficient of the vehicle like this program does. So this program is probably a little more accurate as long as you enter the correct weight of the vehicle and the aero. coeff.
F=MA
M=weight of the vehicle + areo. coeff.
A= based on how fast your car accelerates
HP=Force*(distance traveled/time of test)
Torque=HP*5252/RPM
Old 01-20-2006, 12:57 PM   #11
Jeramie
Member#: 56995
2004 WRX
Oh and while reading up about, all these "dyno" type programs I came accross this spread sheet.
http://forums.audiworld.com/vag/msgs/457.phtml
I'm sure it could easily be modified to work with our cars (and a simple data logger). I dunno how acurate they would be, but the audi guys seem to get good results.
Old 01-20-2006, 02:13 PM   #12
Freon
Member#: 88322
2009 BMW 135i
Here's a spreadsheet I made up attempting to get HP from an SMT-6 log of time and RPM:
http://freon.shackspace.com/ecu%20an...0worksheet.xls
(go to "Sheet 1")
I used a Delta Kinetic Energy model. I knew my gear ratios, so I can translate RPM into speed pretty accurately. From there, I take the speed * mass of the car to get kinetic energy at each sample, then subtract adjacent samples to get the change in total kinetic energy per sample. Delta Kinetic Energy is a simple factor change into horsepower.
As you can see, it didnt work out too well, even after messing with various windowing functions to smooth the data. There is just a giant spike in the middle, and LOTS of general "noise."
The math is not hard, and it is really easy to come up with an Excel spreadsheet to calculate it. That's not the problem.
The RPM log just isn't precise enough. Either it needs to be counter based (average RPM over sample window), or the sampling rate needs to be drastically increased. A typical RPM log is just too noisy. The car in question was a 2.7L NA with weak cams, which should have about 150whp at 5500rpm and a wide flat torque curve.
Look at a typical log. While accelerating, sometimes recorded RPM actually drops! But either way, they are almost always very noisy. I.e. something like 5015, 5198, 5216, 5304, 5490, 5510 under WOT. It should be much more consistent and smooth. If it isn't, you'll never be able to get a good graph.
The SMT-6 was reading straight off the crank signal of a 60-3 crank wheel. (60 teeth, 3 missing) It logs at 9-12 samples per second to its internal memory. Most other loggers are loggin at an even slower rate. The UTEC is horrible at only 5hz and is still noisy. I haven't tried making it work with a log from SSM (deltadash/ecuexplorer, etc).
Old 01-20-2006, 02:29 PM   #13
Jeramie
Member#: 56995
2004 WRX
I belive, thats what is special about the link to the spreadsheet I posted. The person who made it had some sort of smoothing algo that seems to working quite well.
The only thing that sucks about his design is the "coast down".
I'm going to take a look at your spreadsheet, nice to see I'm not the only person who would have an interest in such a thing! I just haven't had the time to really get into it, with the new baby. Gotta love kids
Air fuel meter and Boost Controler Superveget Private 'Wanted' Classifieds 7 03-23-2005 09:53 PM
adding a/f meter and aftermarket 02 sensor wrx&998rduck Electrical & Lighting 1 01-22-2005 07:33 AM
Blitz SBC-ID and Power meter and more dirtygirl Private 'For Sale' Classifieds 1 12-23-2004 04:36 PM
Integrated In-Dash (Tach) Boost Gauges, Air Fuel Meters and >>> ShokWaveRider General Community 1 02-21-2003 05:38 PM
Egt, a/f meter and me? gossamer_monster Factory 2.0L Turbo Powertrain 4 05-10-2001 07:53 PM
