Old 01-18-2006, 08:13 PM   #1
neokenxx
Member#: 92017
2004 WRX Sedan
Cobb Stage 2+
Default Cobb Accessport MPG Question
whats up guys. listen last week i put a turboxs catless uppipe, and catless turboback with rfl/ti on my car and my gas mpg has gone to **** it seems.
right now my mods are:
TXS Intake
TXS Up
TXS TBE
HKS SSQV
(all catless)
i have a cobb accessport in the mail, should be here in a few days.
my question is, i know that having up/dwn with especially a bov makes my car run very rich. will running the base stage 2 (93oct) map improve my gas mileage some? or do i really just need to get it tuned. as of now i cant afford a tune. had to spend money on college books.
it honestly seems like im getting somewhere around 16-18mpg right now.
will the mpg go up with a stage 2 base map, becasue the car needs em?
also will the bov do some damage to performance? i head a bov with the stage2 map is iffy. also what about the intake? stage 2 map is only ment for tbe.
thanks so much for any responses,
matt v.
neokenxx is offline   Reply With Quote
Old 01-18-2006, 08:49 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
The BOV only makes the car run rich on throttle lift, not all the time.
But, depending on how you drive, 16-18MPG is great. I get less than that with 100% city driving.
mcowger is offline   Reply With Quote
Old 01-18-2006, 08:56 PM   #3
kellie00
Member#: 80965
2012 STI
I don't have any hard data on the matter, just one guys story that I go to school with. He was running the same BOV and AP and was having some problems with the car (an 04), took the BOV off, replaced stock, no more problems. Now, don't let that scare you, just thought I would add my experience.
kellie00 is offline   Reply With Quote
Old 01-18-2006, 09:05 PM   #4
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
16-18mpg great? When I was running Cobb stage 2 + uppipe I was getting 25-26mpg mixed city and highway (80% city, 20% highway). The BOV will make it run rich after throttle lift, like he said. If you are driving more city, then that would probably mean more throttle lifts... which could cause crappy MPG.
Edit: Yeah, depending how you drive. 16-18mpg would be good if driving WOT a lot. For regular driving, though, 16-18mpg is pretty bad.
turbo tecnica is offline   Reply With Quote
Old 01-18-2006, 10:04 PM   #5
WRC-Go
Member#: 29917
2003 WRXWgn-WRB sold
EVO IX-MR, 98 Viper
I haven't noticed any difference in mileage going from stock to Stage 1 to Stage 2 with my accessport.
WRC-Go is offline   Reply With Quote
Old 01-18-2006, 10:18 PM   #6
05redrex
Member#: 86665
2005 WRX SRR 2.5/20g
2010 FXT SWP Cobb Stg2+
I would think the BOV would make it run rich, but only because it removes air. I wouldn't think it would be adding fuel.
05redrex is offline   Reply With Quote
Old 01-18-2006, 10:24 PM   #7
lin_tp2
Member#: 66364
02 wrx
wrb
im running stage 2 cobb with protune. catless upipe, dp and catback
still getting 22 mpg
i think you should take the bov off and put the stock one back on. also when you get the cobb ap get some tuning that might help
lin_tp2 is offline   Reply With Quote
Old 01-18-2006, 10:32 PM   #8
neokenxx
Member#: 92017
2004 WRX Sedan
Cobb Stage 2+
ok im gonan put the stock bov back on till i get a tune in a few weeks. will the stock bov hold the higher boost ok? ive ehar dof them leaking at 16+ psi and letting boost out near redline. should i be worried. is stock bov good for stage 2 basemap and stage 2 protune? at what point should i worry about a stronger bpv?
Old 01-18-2006, 10:47 PM   #9
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
The stock BOV will handle WELL over 16 psi no problem. More like 20+psi. The loss of pressure at redline is intentional ECU programming, not a leak.
The stock BOV is good for pretty much any setup you are likely to do that uses a TMIC.
Old 01-18-2006, 10:48 PM   #10
lin_tp2
Member#: 66364
02 wrx
wrb
the stock bov is good for stage 2. I know a lot people that upgrade turbo (vf 22, 34) and are still running stock bov. however if you like the sound of the bov and intake i would recommend getting the protune so your car doesnt run rich and you also get the max. performance of all your aftermarket parts.
Old 01-18-2006, 10:54 PM   #11
neokenxx
Member#: 92017
2004 WRX Sedan
Cobb Stage 2+
thanks alot sounds great. ill put the stock bpv on for a while, and might even leave it on. but the intake im gonna leave on regardless.
Old 01-19-2006, 09:17 AM   #12
samesk8r
Member#: 65070
2005 Ex-WRX owner
:single tear:
You have to ditch the intake. All the Map notes on Cobb's website clearly state that you HAVE to use the stock intake. Although PDX Tuning offers AP maps so you may want to check in with them.
samesk8r is offline   Reply With Quote
Old 01-19-2006, 02:26 PM   #13
neokenxx
Member#: 92017
2004 WRX Sedan
Cobb Stage 2+
yeah this morning before work i put the stock intake and stock bpv back on my car. wastegute flutter is alot louder. but w/e. ill keep the other parts and throw them back on right before, or when i get a tune.
thanks guys.
Cobb Tuning Accessport Version I Cobb Accessport WRX0520 Engine/Power/Exhaust 0 07-18-2007 03:02 AM
Cobb Accessport Question - Noob question hlanderr Newbies & FAQs 7 05-08-2006 12:23 PM
cobb accessport questions speedyshifter Engine Management & Tuning 23 03-29-2005 03:31 PM
cobb accessport questions skimmilk68 Engine Management & Tuning 18 04-05-2004 08:25 PM
Questions about the Cobb AccessPort 03WRX83 Engine Management & Tuning 13 12-12-2003 02:23 AM
Message Board Statistics All times are GMT -4. The time now is 07:15 PM.
