Old 01-18-2006, 09:30 PM   #1
mazdamike
Member#: 62937
2003 wrx
wr blue
Default 2.5 block w/WRX heads
hey guys/girls, i got a WRX and im doing 2.5 STI short block w/WRX heads.what is the best turbo/injectors for that set up? also what would be the best clutch+flywheel set up. for clutch i want something that could handle everyday driving. the tranny is a 6 speed STI w/dccd.
mazdamike is offline   Reply With Quote
Old 01-18-2006, 09:54 PM   #2
ipozestu
Member#: 67792
2005 WRX Wagon
Hey M-mike. There are a couple of recent threads about this very issue. do some research on the compression ratios for 2.5l and 2.0 heads. You may have some tuning issues running the 8.5:1 CR as opposed to the 8:1. Turbo: What are you looking for? Injectors: Pending on answer to Turbo question. Clutch: Answer the turbo question. Without knowing how much power you are going for, it's tough to lay out a setup. Do some re"search" come up with a game plan and lay it out for discussion.
ipozestu is offline   Reply With Quote
Old 01-19-2006, 12:11 AM   #3
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default right on
^^+1 ...will you be doing anything with the car other than streeting it? What kind of budget are you working with?
Do you have a front-mount? Tell us your mods...
Just curious, what about the rear?... diff, half-shafts, hubs, brakes...
ka mano is offline   Reply With Quote
Old 01-19-2006, 10:55 AM   #4
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
my only recommendation is that if you want over 300whp, get some cams. Even stock STi cams would help,because the WRX ones will hold you back. Good luck.
the_colombian is offline   Reply With Quote
Old 01-19-2006, 10:43 PM   #5
mazdamike
Member#: 62937
2003 wrx
wr blue
i want to get probably a greddy turbo(is it good?), for now i got TMIC from TXS but im getting a front mount from them soon. i also got perrin down pipe, M2 uppipe greddy cat back, utec, avo turbo inlet pipe. now i got about $5000 to spent. im getting aluminum driveshaft from godspeed(anybody know anything about it?) and i will be using my rear end with a ring and pinion from gruppe-s. i want my car to be a everyday car. on my list that i want to get are greddy timing belt, cusco mounts, crank pulley, apr head studs, header, clutch + flywheel, injectors, fuel rails, walbro pump.
Old 01-19-2006, 11:19 PM   #6
ka mano
Member#: 78022
PdxT built 2.5L 6sp
I'm going to take a stab at listing this out.
Old 01-19-2006, 11:36 PM   #7
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default Have I got this right?
You've already got:
- 2.5L shortblock
- STi tranny
- M2 UP
- Perrin DP
- GReddy muffler
- UTEC
- AVO turbo inlet hose
You have $5000 to get this other stuff:
- Cusco mounts
- flywheel
- clutch
- Godspeed alum. driveshaft
- gruppe-s ring & pinion
- APR head studs
- header
- lightened crank pulley (stock diameter)
- fuel rails
- injectors
- Walbro pump
- turbo
- TXS FMIC
- GReddy timing belt
Is this right so far?
Old 01-20-2006, 02:49 AM   #8
joeyd02
Member#: 16742
07 STI UGM
AP Stage2 Clark Tuned
I hope this helps you. I asked the same question a while ago and was shown this http://www.i-speed.us/dyno_results/d...s.cgi?Menu=3-0 . There a few dyno plots of different hybrid set ups.
joeyd02 is offline   Reply With Quote
Old 01-20-2006, 09:15 PM   #9
mazdamike
Member#: 62937
2003 wrx
wr blue
ka mano - that is correct. i am also going to change all the seals, gaskets, port my intake mainfold.
Old 01-20-2006, 10:44 PM   #10
JessesTalon
Member#: 63925
95 R33 / 06 WRX
Dark Slvr / Crystal Slvr
if you want good driveablity go for a gt30r... injectors will depend on what kind of tune you want... but just to say something I'd say with 15-20 psi through a gt30r you should be sitting between 550cc-850cc injectors...
It really depends on all your mods... look what other people have and what they are running...
Make a goal of what you want first....
I love ACT clutchs myself... and fidanza flywheels..
i had a act2600 and a fidanza flywheel and that was a EXELLENT combo, i daily drove that car every day as well and gave me no problems in traffic or regular driving.
JessesTalon is offline   Reply With Quote
Old 01-21-2006, 01:24 AM   #11
ka mano
Member#: 78022
PdxT built 2.5L 6sp
If you get a lot of contributors to this thread, you'll get a lot of different ideas about the turbo to go with... and there are a lot of ways to go right.
Looking at your budget I'd say either A. go with a bolt-on -- a FP Green or a SR55 -- or B. take some stuff off your list to make room for a rotated mount Garret with an external wastegate.
If it were me, I'd chose B., and get the GT30R (when it was me... I did) but it's all tradeoffs. If you like A., go to the link joeyd02 gave you, here it is again...
I-Speed hybrid dyno comparo
...and click the white boxes to the right of the SR55 and the Green, hit 'Enter' and tell us what you think.
I'd go modded stock injectors or you'll bust your budget.
I did alotta research on clutches and landed on the ACT myself, but of course that's nothin compared to experience with the product. I'm glad to hear you like the one you got. I'm getting a HeavyDuty with a StreetLite FW put in in February.
mazdamike, PdxTuning will give you a good, competitive price on clutches and FWs. I say, go organic.
Dude, if you're going from stock to this setup, you're going to be rocked!
Old 01-21-2006, 02:07 AM   #12
mazdamike
Member#: 62937
2003 wrx
wr blue
i've been hearing bad thinkgs about pf green turbos. friend of mine had it on his wrx and it blew on him twice within two week period.
act2600 is the street clutch right? i dont want anything to crazy. its not on/off clutch is it? i want to be able to slip it to launch it.
i deffenatlly want to run 20+ psi on the turbo but i want it to be able to drive it everyday.
anybody heard anything about the streetlite act flywheel? thats the one i had in mind.
my goal probably would be 350-400 whp.
well im not really going from stock to this. all those parts i already had on my 2.0 motor but my tranny blew and like most of you whit that problem the dealer did not warranty the car so i got mad and i got the sti set up. by the way im am sueing subaru. well see what happens.
Old 01-22-2006, 02:00 AM   #13
keaniegenie
Member#: 94494
2005 Element 92x
I'd get a TD06-20g. So many of them running around. Good price. With good mods, you'll get close to 350awhp w/ pump, and close to 400 with race fuel.
A GT30r would be great, but better suited for a FMIC. ATP is coming out with a GT28 kit this spring.
keaniegenie is offline   Reply With Quote
Old 01-22-2006, 02:54 AM   #14
joeyd02
Member#: 16742
07 STI UGM
I got that ACT Stretlite fly and Street cluctch. It works great for me. I was going for the fp green but heard alot of horror stories so I went with the SZ49 w/ 3in inlet and fatboy wheel. Unabomber changed my mind . I havent put the new set up together yet and wont be able to until I get back in May. I am also on my second tdanny. I plan on puttin some RA gears in the old one and set it aside just in case.
Old 01-22-2006, 04:54 AM   #15
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default not sure I follow you...
Originally Posted by keaniegenie
...A GT30r would be great, but better suited for a FMIC. ...
Hey, keaniegenie. Did you not notice he's planning to get a FM?
Old 01-24-2006, 11:48 AM   #16
mazdamike
Member#: 62937
2003 wrx
wr blue
do you guys know which head gasket do i need? is it the 2.0 to match the heads or is it the 2.5 to match the block?
Old 01-24-2006, 11:51 AM   #17
joeyd02
Member#: 16742
07 STI UGM
I put an STi head gasket on mine
Old 01-24-2006, 03:13 PM   #18
ka mano
Member#: 78022
PdxT built 2.5L 6sp
With a decision like this that's so crucial to the compression ratio, I'd call a couple of reputable shops experienced with this type of build to get their advice.
Old 01-24-2006, 03:29 PM   #19
mazdamike
Member#: 62937
2003 wrx
wr blue
now i narrow it down to to similar turbos. PE1818F or a greddy TZ518Z. i dont know which one to pick. they are both 18g turbos. now with the head gasket it would make sense to put STI because STI pistons are bigger so the wrx gasket would be in the way.
Old 06-08-2006, 01:32 PM   #20
BrettS
Member#: 73854
Midnight black pearl
same here-
2.5l block, 2.0l stock heads, sti head gaskets, sti timing belt, FP 18g, sti pink injectors, really crappy, small fmic, stock fuel pump, cheap 3" exhaust, ACT clutch, ecutek tuned at Harmanmotive to 280hp at the wheels.
since then Ive installed an aps DR725 fmic, apexi exh, walbro fuel pump- now saving for a retune-
BrettS is offline   Reply With Quote
Old 06-25-2006, 11:04 AM   #21
joeyd02
Member#: 16742
07 STI UGM
My car has been put together, but I stilll need to get mine tuned. Kingpin is taking their time with my ECU. Thinking of going back to Dyno Comp.
2.5 block with wrx heads mmmRex21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-13-2008 08:04 PM
EJ207 or 2.5 block w/wrx heads... Can't decide, need input! vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-12-2006 12:20 AM
18g on a 2.5 block w/wrx heads... 13secwrx Proven Power Bragging 18 08-28-2004 09:39 AM
Turbo options for STi 2.5 block w/WRX heads? Arnie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 01-07-2004 12:42 PM
2.5 block with STI heads & internals KYScuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2003 11:34 PM
