Old 01-18-2006, 09:53 PM   #1
Scott Farmer
Member#: 87799
2005 STU STi
White/Gold For Sale!
Default EM: HP/TQ Gains WITHOUT touching boost
I autocross in a class (STU) that doesn't allow the direct modification of boost levels (boost changes from TBE and other allowed mods are permitted).
So, I'm debating whether I should get a Cobb AP or EcuTek (both would be Protuned maps). What kind of gains would I see with engine management if I couldn't touch the boost levels?
Just so you guys know, my only modification is a TurboXS catted TBE and I drive an 05 STi.
Scott Farmer is offline   Reply With Quote
Old 01-18-2006, 10:43 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Your options are basically adjusting timing only. I run in STX, and what i'd do is the following:
1) You are required to use pump gas, but that doesn't mean you are limited to 93 oct. Go find a pump that has 100+ octane. Fill up a 10 gallon tank with that. Get a siphon, and when you get to the event, suck out the gas in your take, and replace it with the 100+ oct.
2) Get a tune (using the AP probably, so you can swithc maps) that adds a bunch of timing. That will get you some extra power from the extra octane you added above. I'd expect you could see +10-15 HP, but more importantly, you will probably see a leftward shift of the torque curve.
mcowger is offline   Reply With Quote
Old 01-19-2006, 12:48 AM   #3
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Depending on how the car is running, leaning out and adding timing are both options which could net you a few ponies. I'm not too sure how they can limit what boost modifications you can do if changes from supporting mods are permitted. If peak boost is the limiting factor then I'm sure you can pick up quite a bit tuning your car for your conditions and fuel without raising peak boost.
phantomsr is offline   Reply With Quote
Old 01-19-2006, 12:55 AM   #4
Scott Farmer
Member#: 87799
2005 STU STi
Well, the idea is that boost creep is allowed from a turbo back exhaust system. That's deviation from stock boost levels without having directly modified the boost levels.
However, actually changing boost through a boost controller or EM is illegal. It's all about staying honest, though.
Is it possible for 09 WRX to acheive STI HP/TQ numbers without any exhaust mods? REX265 Factory 2.5L Turbo Powertrain 81 12-27-2009 11:23 AM
2.5L hybrid swap hp & Tq gains? REDrum Built Motor Discussion 0 08-07-2006 11:54 AM
<--Newbie to EM: How does the ECU control boost, and is it possible to: TD04 --> VF34 caterpill Engine Management & Tuning 7 02-23-2006 01:43 AM
what hp/tq does the stock clutch slip at? Eric SS Transmission (AT/MT) & Driveline 3 02-04-2002 06:26 PM
Message Board Statistics All times are GMT -4. The time now is 07:18 AM.
