Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-18-2006, 10:18 PM   #1
xtian
Member#: 93248
95 20g powered gc8
PPG'd yO! & is250 AWD
Default swap done.. but i have a problem..help!
hi.. i just got my car back ..i have a 95 L with a jdm version 2 motor..
RUNNING A STOCK L fuel pump!!!!!!!!!!!!!!!
the problem:
i really cant explain this fully since i just got my car back today..but when i was getting on the gas.. i cant seem to pass 4-5k rpms.. it jerks and feels like the car is gona die..feels like it fuel cuts?!?! what do u guys think is the problem? has anyone experience this yet? on jdm motors? i mean..motor feels good and tranny seems to be fine..can someone help me? im thinking about buying a walbro pump asap.. info would be apriciated..thanks in advance!
---got a new pump..walbro. still has the problem.. but does it less times it did before.. could it be my boost seloniod going bad? or my wastegate(actuator)?
becuase..i floord my car once and the boost gauge flapped to 20 PSI!!! its not suppose to go over 15ish psi.. and today i hit 18psi!
could it be overboost?
thinking about getting a manual boost controller..and try to test if my soleniod or the actuator is bad.. wut yah guys think? any suggestions? more ideas would be helpful.. i just want my baby to run fine and run safe..=(
---put in a mbc..im now set at 12 psi.. and it still does it on 4th gear.. im getting worried.. anyone have any more ideas? =(
the post could be a lil confusing.. but these are they post i made on a thread i made on RS25.com . i copied it hear to get more opinions and help on how to deal with this problem..
heres the link on the original thread by the way:
http://www.rs25.com/forums/showthrea...690#post727690
thanks in advanced
---christian
xtian is offline   Reply With Quote
Old 01-18-2006, 10:22 PM   #2
xtian
Member#: 93248
95 20g powered gc8
someone told me.. putting in the mbc dint solve my problem.. it just masked the problem.. and somethings wrong with the car still.. im running out of ideas.. anyone has the same problem too?
Old 01-18-2006, 10:45 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Speedo work?
Scoobie Steve is offline   Reply With Quote
Old 01-18-2006, 10:47 PM   #4
xtian
Member#: 93248
95 20g powered gc8
yeah it does.. i thought about that too..maybe the cable is barely connected or something..but it seems alright.. funny thing is.. WHY ONLY ON 4TH!?!?!? well..im sure if i floor 3rd id will do it too.. i dont get it..
Old 01-18-2006, 11:09 PM   #5
Scoobie Steve
Member#: 2289
From what you told me on AIM sounds like you have a wiring issue. Make sure the CEL is wired correctly, it should be on when this is happening. Also make sure the ecu is getting a speedo signal from the cluster, if its not you will be in limp mod which cuts fuel at 4k.
Old 01-19-2006, 02:03 AM   #6
silvialost
Member#: 91021
1997 impreza
red
if the car is just boosting to 20 then cutting you should check the action on you wastegate actuator rod. mine was in a bind with the body of the actuator. just tweak the braket a touch with some pliers. you should be able to move the rod with your hand to open the wastegate.
if your wastegate actuator is not the issue just throw in a gallon of zyline/zylol. with a full tank of gas. make sure that you mix it with a gallon or so of gas before you pour it in. i run this stuff it works pretty good. on 93 octane gas with 15-16 psi my motor knocks at like 5k rpm. but with this stuff in it it dosent.
silvialost is offline   Reply With Quote
Old 01-19-2006, 03:20 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
after talking with him tonight i think he's got a MAP sensor problem. I seem to recall those older MAP sensors always going bad...is that correct?
Old 01-19-2006, 01:18 PM   #8
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Because the car is under greater load in 4th.
jamesfacts is offline   Reply With Quote
Old 01-19-2006, 01:48 PM   #9
xtian
Member#: 93248
95 20g powered gc8
i made a third gear pull just now.. and it did it right at 4k rpm! boost at around 12-14 psi. im really confused what to do now. this is no fun.. =(
Old 01-19-2006, 03:07 PM   #10
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
id do what they have suggested, i was gonna say that this has happened a bunch before to some guys on here, and then i realized they have all posted already. try what theyve suggested: check the MAP sensor, check the actuator, check your vaccum lines that go to and from the boost control, check the CEL and engine speed output, etc.
good luck!
Natoe is offline   Reply With Quote
Old 01-19-2006, 03:13 PM   #11
xtian
Member#: 93248
95 20g powered gc8
thanks.. ima try to swap out the ecu.. i have a gc8 ecu.. and see if it makes a difrence..
i currently have a gf8 ecu on the car (came with my motor w/ td04)
so swapping the ecu wouldnt be a problem right?
Old 01-19-2006, 03:15 PM   #12
Natoe
Member#: 90353
as long as the pinouts are the same it should be fine.. not sure what ecu's your talking about exactly
Old 01-19-2006, 04:06 PM   #13
spoonfedb18a1
Member#: 51273
1998 EJ20G RS 345whp
black
have u changed out the ignitors......(coil packs)...?
this could be ur problem, i had the same problem and also a friend of mine did also.
the coil packs are very hard to find also.
spoonfedb18a1 is offline   Reply With Quote
Old 01-19-2006, 04:11 PM   #14
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
I also have a JDM v2, and I have a similar problem I've been trying to figure out for two months now.
When it's still relatively cold, I can easily take it all the way up to red line, but after about 7-10 minutes of driving, it will start to cut out at exactly 4500 in any gear. I was chasing a boost leak for a while, but now I'm not so sure that's the problem. If I stay on the throttle, I watch the tach bounce between 4500 and 5000 without going any higher. I would think a leak would be more consistent, so I'm starting to lean towards an electrical problem.
I want to pull the CEL codes, but it seems that the CEL isn't connected to the right ECU wire. Does anyone happen to know where I can find a pinout diagram? It might be in the MY94 wiring manual I obtained, but it's all in Japanese, so I'm clueless. I just scanned it in yesterday if anyone who understands it can skim through and help me out:
http://www.stutteringdotdot.com/suba...g_JDM_MY94.pdf
-Rob
tweakling is offline   Reply With Quote
Old 01-19-2006, 05:18 PM   #15
xtian
Member#: 93248
95 20g powered gc8
well..i have new plugs .. if i heard it right i can use any coil on plug from any usdm wrx.. so i guess that not that hard to source.. (i dont have a coilpack)
on the side note: swapped out the ecu.. still the same problem.. =(
Old 01-19-2006, 06:23 PM   #16
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
coil on pack from usdm dosnt look compatible. i suppose it "could" work, but ....
u could try it. or get the proper JDM ones. i may have spares this week. do you have the speedo cable hooked up?
swapstar is offline   Reply With Quote
Old 01-19-2006, 06:47 PM   #17
spoonfedb18a1
Member#: 51273
black
like swapstar siad....i am pretty sure those usdm ones wont work b/c b4 i purchased them i looked into getting some usdm ones and on my friends 04 wrx......they look diff.
the usdm ones like more like blocks, and the JDM ones look kinda like a layerd wedding cake....lol( more roundish!
if i can think of anything else that could be ur problem i will let you know.
Andrew
Old 01-19-2006, 10:38 PM   #18
xtian
Member#: 93248
95 20g powered gc8
thanks man.. apriciate it..ill let u know if i need em..
Old 01-19-2006, 11:52 PM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by Scoobie Steve
Speedo work?
your chasing down the right problem here...I had the same thing...mech. speedo worked but ECU wasn't getting the signal...
Old 01-20-2006, 12:27 AM   #20
xtian
Member#: 93248
95 20g powered gc8
^^^how did u fix it? my tech said he didnt (re)wirewire the cluster(he dint touch it)..so everything is the same.. u think this is my problem? is there something to be done with the cluster..so send the "signal"?
Old 01-20-2006, 12:40 AM   #21
silvialost
Member#: 91021
1997 impreza
red
what kind of gas do you have in the car.
Old 01-20-2006, 12:43 AM   #22
xtian
Member#: 93248
95 20g powered gc8
93 octane
Old 01-20-2006, 02:45 AM   #23
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
its sounds like the ECU isn't gettign a vehicle speed signal, you need to figure out what wire coming from the cluster is the vehicle speed signal wire(if the speedo was mechanical to begin with)
Old 01-20-2006, 01:06 PM   #24
xtian
Member#: 93248
95 20g powered gc8
ok.. bringing back the car today.. so should i tell my tech to look for the speed signal wire? he told me he dint touch any wirrings from the cluster.. could that be it?
Old 01-20-2006, 02:06 PM   #25
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
which dash harness and guage cluster are you running?
v5 swap done but won't idle right acidrain088 Subaru Conversions 4 09-13-2007 03:51 PM
jdm swaps done, but need to reset ecu! help 99WRXEJ20 Subaru Conversions 6 07-02-2003 06:57 PM
Dual stage BC done, but FBC not working well. Help. fastsubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-08-2002 01:58 AM
OK, it's done. But I have some Questions. hayscoob Normally Aspirated with bolt-on Forced Induction Powertrain 32 03-25-2002 02:26 PM
Installed amp, but I have a problem. Help! Cjchaps Car Audio, Video & Security 8 08-27-2001 04:22 PM
