Old 01-18-2006, 11:00 PM   #1
00LegacyGT
Member#: 105401
Default Running Battery Wire to Subwoofer
In my 00' Subaru Legacy im trying to run the battery wire through the firewall to my Infinity Subwoofer in the trunk. The problem is there are no grommets to run it through. I drilled a hole into the firewall and fed about 3ft of wire into it and it went no where.
Anyone know where/what to run the battery wire through?
Thanks
-Chris
00LegacyGT is offline   Reply With Quote
Old 01-18-2006, 11:10 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
YOU DID WHAT NOW?!
Man....
The grommet is reachable on the drivers side of the car, about 8" down on the firewall between the airfilter and the strut mount.
It's covered by a piece of rubber that pulls out. feed wire in and it comes out above the gas pedal
Whoever gave you a drill should be shot.
fibuz
Last edited by fibuz; 01-18-2006 at 11:24 PM. Reason: you tell me spell good i go run.
fibuz is offline   Reply With Quote
Old 01-18-2006, 11:18 PM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Old 01-18-2006, 11:28 PM   #4
00LegacyGT
Member#: 105401
lol awesome, thanks a bunch man.
Old 01-18-2006, 11:28 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
NO MORE DRILLING. Promise?
Old 01-18-2006, 11:33 PM   #6
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Thumbs up
I love the drawing.
Using this bit would be ok, right?
KD7000 is offline   Reply With Quote
Old 01-19-2006, 02:35 AM   #7
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
mmmm drill bits, make sure you lick it when your done. I heard somewhere that it grows hair on your chest.
Make sure that you run the signal wires (RCA's) at least 1ft to 2ft away from the power wire to keep from getting interference or distortion. lots of RCA's for subs are shielded but the freebee ones that come with powered subs are not at all.
~Justin
Kawikid20o2 is offline   Reply With Quote
Old 01-19-2006, 11:30 AM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Originally Posted by fibuz
That’s the clutch master cylinder grommet. If this dude’s got an MT then obviously that hole will be populated. There’s another grommet (easier to get to from the inside) further down which dumps right behind the brake-booster, on the bottom. From inside, if you pull the floor mat, then lift the top of the carpet it will be right there. There may even be a cut-out in the carpet padding to help access it…
I can’t believe you drilled from the within the engine bay not knowing what was behind. You probably punctured some portion of your HVAC system which stretches across the entire FW on the inside. Or even luckier you didn’t hit the bulkhead harness which is right there too…
PS: Use a metal coat-hanger to investigate where how each hole passes through the FW next time...
xcntrk75 is offline   Reply With Quote
Old 01-19-2006, 11:51 AM   #9
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
That grommet will only work if his car does not have a manual transmission. If he has a manual transmission, that is right were the master cylinder for the clutch goes, and there won't be a grommet there.
When I've done stereo installs into BE/BH Cars, I've always used the grommet to the left of the brake pedal. On the other side of the firewall, it outputs right below the brake booster. It's always worked great for me. See pic below. You'll have to remove a precut section of the sound deadening material, and then push the grommet out. I always put the grommet in backwords because I could never fit my hand between the top of the frame rail and the bottom of hte booster to put the grommet back on. At least you can get right at it from inside the car. Just cut a slit in the center of the grommet and run your cable through that. You don't want to leave the grommet out and then end up with road grime all over the inside of your car (or have the wire rub on the firewall and then short out which could possibly start something on fire if you don't have a fuse or circuit breaker)
Grommet Location
Piece of Sound Deadening Removed
wrx_driver_2002 is offline   Reply With Quote
Old 01-19-2006, 11:59 AM   #10
IDMO
Member#: 91819
2004 FXT
How do you guys run the cables from the firewall to the trunk? I'd assume you tuck them under the center console panels (where the plastic panels meet the carpet), then under the carpet in front of the rear seat and then under the rear seat itself and into the trunk? That's kind of how I ran my XM antenna cable anyways, is there an easier route?
IDMO is offline   Reply With Quote
Old 01-19-2006, 12:48 PM   #11
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
It depends on the size of the cable. What I usually do is run the RCA's down the right side of the car, and the power wire down the left side. I believe there was enough room along the side, under the carpet for 4ga wire and still not be able to tell it was there. I was always taught to keep the power as far away from the RCA's as possible, so that's why I run them on opposite sides of the car. I've never had a problem with interference that way, except for in a 1986 GL-10 Turbo that, for some reason no matter what I did I still got the alternator whine.
Old 01-19-2006, 01:24 PM   #12
IDMO
Member#: 91819
2004 FXT
I'm not going for trunk rattling, so it'd probably just be some 8ga power cable. Down the side would probably be easier, don't know why I didn't think of tucking under those side moulding things.
Old 01-19-2006, 03:39 PM   #13
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
Originally Posted by KD7000
I love the drawing.
No, the drillbit needs to look like this:
mranlet is offline   Reply With Quote
wire size from amp to subwoofer flampy Car Audio, Video & Security 5 03-06-2009 02:48 PM
running amp wires from battery to trunk help. ezzzey Car Audio, Video & Security 15 05-18-2007 03:32 PM
Running and routing wires to trunk (12 Volt Amp run, RCA's, Turn on lead, etc...) LESLIEx317537 Car Audio, Video & Security 2 08-16-2003 04:57 PM
help running speaker wire to the door makanouchi Car Audio, Video & Security 8 05-16-2002 02:03 PM
running speaker wire to doors elemental Car Audio, Video & Security 11 01-26-2001 02:58 AM
