Vancouver Impreza Club
Old 01-19-2006, 12:07 AM   #1
civilone
Member#: 92473
1997 WRX STI
Default HELP: Shift Boot Removal
I have recently bought a STi shifter trim, which is the aluminum trim labelled "STi' that comes stock on STi's. I have also done many searches on the forum and scoobymods, maybe I am not a good searcher. Now I am stuck after I took off the console. I know that I am suppose to use a dremel to widen the hole, so that the trim could sit right in. But before I can do that, I must removal the shift boot, and there are just 6 metal clips ( I don't know what they are called ) that are holding the boot in place.
I can't seem to remove it. Can you guys give me some advice on what they called and how to go about removing them? The clips circled in red is what I am talking about.
Thanks Very Much
March
civilone is offline   Reply With Quote
Old 01-19-2006, 12:15 AM   #2
Spy
Member#: 60062
2000 Impreza 2.5RS
2009 Norco Team DH
grab the plastic boot ring thing and just lighty pull.. get your fingers or widge a flat screwdriver underneath and slowly work them off... just dont twist cause you will break the little plastic sticks.. and they break fairly easily..
Spy is offline   Reply With Quote
Old 01-19-2006, 01:09 AM   #3
Ricewagon
Member#: 59703
2004 STi
always wrb
I think the plastic boot ring is glued down to the under part of the console too. It's been awhile since I did mine.
Ricewagon is offline   Reply With Quote
Old 01-19-2006, 01:26 AM   #4
buster
Member#: 41811
02 WRX
I seem to remember the clips are pretty flexy, small screwdriver to the inside and tweak them just enough to get them to release.
buster is offline   Reply With Quote
Old 01-19-2006, 01:35 AM   #5
Chizzow
Member#: 39451
2013 Sti hatchback
Wrb
just pry with a flathead as everyone else has mentioned, but pry slowly so it doesn't fly off.
Chizzow is offline   Reply With Quote
Old 01-19-2006, 02:10 AM   #6
civilone
Member#: 92473
1997 WRX STI
Thank you guys, actually, that metal clip has 3 mini clips holding it in place as well.
Now I am thinking of using a needle or a toothpick to do the job. Do you guys think that works fine too?
Old 01-19-2006, 04:01 AM   #7
Fleek04
Member#: 56738
2014 Scion FRS
Asphalt
I remember I just cut it off. Hahahahahahaha... Not the best thing to do but it works.
Fleek04 is offline   Reply With Quote
Old 01-19-2006, 04:25 AM   #8
Azn-Jap STI
Member#: 76796
03 ImprezWRX -WRB-
-IMAGE BUG!- 600RR
again march....
Azn-Jap STI is offline   Reply With Quote
Old 01-19-2006, 07:12 PM   #9
civilone
Member#: 92473
1997 WRX STI
Hell yeah Ricky.
Davy, you mean you just cut the whole black plastic thingy off? Then your boot won't sit in place after you put it back on, wouldn't it?
Old 01-19-2006, 08:45 PM   #10
Ricewagon
Member#: 59703
2004 STi
always wrb
Don't cut the plastic thing off. Pry off the ring clips, then slowly pry off the black plastic ring that secures the boot. You'll need that intact. Next, drill holes for the six bolts that coincides with the STi trim and dremel the console to fit the trim. Or do what I did and order an 04 STi console and put it all together. Hopes this helps.
Help: Custom shift boot (4EAT) cteve Interior & Exterior Modification 0 10-09-2009 12:31 PM
how do you remove the shift boot on an sti ryanpietro Transmission (AT/MT) & Driveline 4 02-18-2006 06:47 PM
Remove a Shift Boot MetallicAWRX Newbies & FAQs 2 09-12-2005 01:09 PM
Help: JDM v7 STi shift boot fitment issue Roamin'Coyote Interior & Exterior Modification 11 03-13-2004 02:08 PM
Removing shift knob from shift boot? JGard Interior & Exterior Modification 7 01-11-2001 06:32 PM
