Old 01-19-2006, 12:25 AM   #1
ConradG.
Member#: 95930
2006 Subaru STi
World Rally Blue
Default Installed VF34, Problems loading 2.5
I installed my Vf34 tonite and when I went to load the Cobb 2.5 map it keeps giving me the battery voltage too LOW error code. I checked my battery and it was well above the minimum voltage. I cant really think of any thing that would be causing this except for my cord that hooks the AP up to the test port is kind of crappy, when you the end into the test port you have to put it just right or the AP wont start up, and if you move it just a little bit it restarts and goes back to the main screen(like if I was doing read live boost). Do you think that could have any thing to do with it? and if it does what could I do to fix it?
ConradG. is offline   Reply With Quote
Old 01-19-2006, 09:53 AM   #2
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
This is on a 06 Sti? From what I know there are no VF34 maps for the sti. The VF34 maps are for the 2.0 02-05 wrx.
Kitt is offline   Reply With Quote
Old 01-19-2006, 03:13 PM   #3
ConradG.
Member#: 95930
2006 Subaru STi
World Rally Blue
Sorry, this is on my WRX. Its an 05
Old 01-19-2006, 03:19 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Did you plug in the white intitilization connector?!?!
other that that it sounds like you have bad Cable/Diagport connection.
parker/slc/gc8fan is offline   Reply With Quote
Old 01-19-2006, 05:24 PM   #5
ConradG.
Member#: 95930
2006 Subaru STi
World Rally Blue
Yeah it ended up being a bad connector. Cobb sent me a new one asap and I got it all worked out. I guess its time to start modding the STi now.
Problem after 2.5 replacement swap, ej25 experts needed! shadymilkman129 Subaru Conversions 6 07-31-2007 02:26 PM
Problem after 2.5 replacement swap.. shadymilkman129 Normally Aspirated Powertrain 6 07-30-2007 07:12 PM
Erratic Idle After 14lb Flywheel Installation on Phase I 2.5 DOHC dan_j_b Normally Aspirated Powertrain 38 04-24-2005 12:44 PM
New Short Block on Warranty! Quality control problems on 2.5?? TSer Normally Aspirated Powertrain 4 04-05-2005 12:15 PM
Those who installed turbo in your 2.5 RS Tekken Normally Aspirated with bolt-on Forced Induction Powertrain 8 10-16-2002 02:16 AM
