Old 01-19-2006, 12:48 PM   #1
spooledwrx
Member#: 73611
Subaru Banner How to: install Megan coilovers?
I'm guessing I didn't search hard enough, but how do I go about
doing the install?
spooledwrx is offline   Reply With Quote
Old 01-19-2006, 01:12 PM   #2
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
Take out your current suspension setup, intall the Megan setup. Enjoy.
Aarron_M is offline   Reply With Quote
Old 01-19-2006, 01:18 PM   #3
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
^haha
coilovers are so simple. pull your wheels off. unbolt the two bolts behind the brakes. and then the three bolts on each tophat under the hood(front) and behind the rear seat back(Assuming its a sedan).
reverse engineer the rest. very easy. do it
StealthWRX is offline   Reply With Quote
Old 01-19-2006, 02:23 PM   #4
spooledwrx
Member#: 73611
Thanks for the tip ; )
I guess I can handle the install, Now I just have to find the right tools!
Old 01-19-2006, 02:26 PM   #5
subieworx
Member#: 47769
10, 12, 19mm sockets
19mm wrench
breaker bar
flat head screw driver
hammer (sometimes)
subieworx is offline   Reply With Quote
Old 01-19-2006, 02:44 PM   #6
SPIDEYWrX
Member#: 36109
19mm wrench
breaker bar
hammer (sometimes)
BIG BIG breaker bar
SPIDEYWrX is offline   Reply With Quote
Old 01-19-2006, 03:13 PM   #7
Handsdown
Member#: 29355
it's not interior, it's not exterior, it's not powertrain.
it's suspension!!!!!
but yeah. the two 19mm bolts that hold the hub knucles to the strut body will be a bitch. get some PB blaster or wd-40 and let it soak before taking a breaker bar to them.
Handsdown is offline   Reply With Quote
Old 01-19-2006, 05:24 PM   #8
spooledwrx
Member#: 73611
I hate bolts like that!
Old 01-19-2006, 06:12 PM   #9
NoCalSubie
Member#: 94301
Make sure you do alignment after. You've most likely need a camber bolts for the rears and the alignment guy can install it for you.
NoCalSubie is offline   Reply With Quote
Old 01-19-2006, 06:31 PM   #10
spooledwrx
Member#: 73611
Right-0
How much are camber bolts then?
Old 01-19-2006, 06:37 PM   #11
kcook
Member#: 78074
2005 STi
spooled , im sure someone can help u install them in ur area on this board. i would if i lived near u. thing is... coilovers are ez as crap to install. its 5 bolts, kinda self explanitory when u look at it.
who installed ur other parts u have on ur car???
kcook is offline   Reply With Quote
Old 01-19-2006, 08:51 PM   #12
spooledwrx
Member#: 73611
Im the kind of person who likes to know how the install is going to be
BEFORE I start taking parts off....
-I know a great guy back in Denver who installed my springs for me, but like most of you guys said, coilovers are much easier to throw on.
Old 01-20-2006, 12:14 AM   #13
veightkiller
Member#: 78967
2011 335i
listen to this guy his on teh fast lane
veightkiller is offline   Reply With Quote
How to: Install SARD 850cc Fuel Injectors WR^2X Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-18-2006 12:14 AM
How to: Install Alpine HU-Currently Have Sony gtwagon941 Car Audio, Video & Security 13 02-15-2006 01:35 AM
How to: Install a new clutch no_rex_yet Off-Topic 11 11-12-2004 02:45 PM
How To: Install WRX Turbo/IC on a 2.2L Pepo Normally Aspirated with bolt-on Forced Induction Powertrain 12 10-08-2004 11:18 AM
how to: install rear trailing arm bushings Scott F. Williams Brakes, Steering & Suspension 4 11-06-2002 11:37 AM
