Old 01-19-2006, 10:26 PM   #1
BHawk
Member#: 61860
2004 WRX STi
Default Coolant Problem; so what do these symptoms add up to
The car smells like sweet like coolant in the underhood area for the last 2 weeks after every time I drive it. I noticed my coolant was low about a week ago and filled it up. Since then it has dropped about 3/8 of an inch from the full mark on the overfill tank. The coolant temp has stayed constant througout. I don't see a line leaking anywhere and I certainly don't smell any coolant in the oil. I am running a Cobb AP stage 2 with a turboback exhaust. Any thoughts?
In any case I am replacing the spark plugs this weekend as they could probably use it at 40,000 miles. I am also going to jack the car up and look around a bit more. I suppose I could buy a flourescent leak detection kit, but I don't really want to.
Anyway thanks for your input.
BHawk is offline   Reply With Quote
Old 01-19-2006, 10:35 PM   #2
ScoobyAficionado
Member#: 36575
'04 STi
Temperature is such a huge effect on the volume in your overflow tank that unless you verified the temperature at the before and after check, I woulnd't consider it critical.
I wouldn't expect this from someone in Savannah, GA, but I often get the coolant smell in the winter on extremely cold days when I floor it. Not much, mind you, but a little. I've always assumed that it's a little bit of coolant seeping past a hose clamp.
ScoobyAficionado is offline   Reply With Quote
Old 01-20-2006, 12:46 PM   #3
BHawk
Member#: 61860
2004 WRX STi
Recently it has been unusually cold so that could very well be the problem. I think that it is probably a very small nuisance leak. The car really has been rock steady other than just the smell. I was also thinking there could be a small crack in the turbo allowing some gas to escape. In any case at some point I will check the system with dye and let everbody know just in case someone else runs into the same problem.
Thanks,
Eric
So, what do you think Kato Kaelin is up to lately? upnygimp Off-Topic 7 02-14-2008 11:51 AM
what do sti rods hold up to? devildevil Built Motor Discussion 7 04-10-2007 12:02 AM
So what do you think she did to deserve this? Spheris Off-Topic 45 06-26-2006 04:03 AM
so what do you guys do for fun around these parts? HighWayDrifter Mid Atlantic Impreza Club -- MAIC 44 10-19-2004 12:36 AM
What do these symptoms indicate? 20mm Brakes, Steering & Suspension 7 04-04-2003 07:21 PM
